Question about Refrigerators
I have a White-Westinghouse (TYPE RS26VGSW2) refrigerator which is working on 220/240V 50HZ and I want some parts to fix it. Where can i find them? Thanks in advance
3 Suggested Answers
  • 172 Answers
SOURCE: We have water under our
You have a stopped up drain. The drain is located in the bottom of the back of the freezer. Go in thru the inside of the freezer, remove the back panel and you will see the small opening in the back bottom. It will be frozen up with ice also. Defrost the ice off the drain and try to get hot water to pour down the drain until the drain is clear. I use a flexable piece of hose to blow through the drain until the clog is gone. This will eliminate the water leaking down under the crisper drawers. Good luck and I hope this will FixYa.
Mike
Posted on Sep 24, 2008
murdozzz
  • 41 Answers
SOURCE: My kelvinator fridge stopped working,
what is the model number and long serial number inside the fridge ???
Posted on Apr 16, 2011
Model RJ215M. Where can I get a replacement shelf and crisper drawer?
try the manufacturer service agent spares
try refrigeration repair shops that may have parts from wrecked fridges
try e-bay -fridge spares
Jan 30, 2016 | Westinghouse Refrigerators
Replace lamp in Westinghouse RJ390P refrigerator
Refrigerator Repair - Replacing the Light Bulb (Frigidaire ...
? 1:39
https://www.youtube.com/watch?v=7yE0ZZBNISU
Nov 8, 2012 - Uploaded by PartSelect
Refrigerator Repair - Replacing the Light Bulb (Frigidaire Part # 5303013071) ... Kelvinator, Tappan, White ...
Refrigerator Light Bulb (part #5303013071) - How To ...
? 1:23
https://www.youtube.com/watch?v=1AQTDSn4VFw
Dec 20, 2013 - Uploaded by AppliancePartsPros
Follow these simple step-by-step instructions to replace theRefrigerator Light Bulb 5303013071 on ...
Jan 14, 2016 | Westinghouse Refrigerators
My fridge is not cooling at all but the light is still on and frezzer is still working. Help
The cold air that you receive to your refrigerator comes from your freezer, so when you normally have a problem with a refrigerator not cooling you would check the freezer first. The first thing I normally check is to see if the evaporator inside the freezer is frozen or full of ice. Some times you can actually see ice build up on the Pana in the back of your freezer. Is the fan running in the freezer? if there is no ice build and the evap. Fan is working then I would check the compressor and the condenser in the back of the fridge. Are they running? If your freezer is iced up you most likely have a defrost problem and would need to call a service tech. To find out which part is causing it. If the fan in the freezer is bad you might be able to do it yourself. If it's the compressor or condenser motor you would need to call a tech as well.
Mar 07, 2015 | White-Westinghouse White Westinghouse...
Westinghouse ice maker quit working
Is it your ice maker, or possible the blades that crush the ice or dispense the cubes? What can happen in the latter case is that during the storm the ice melted and pooled in the cutter mechanism. Then, when power was restored, the blades were frozen solid. To fix, investigate taking out the cutter mechanism and letting it thaw and drain. Then reinstall and use frequently for the first few days to prevent refereezimg.
Feb 26, 2014 | White-Westinghouse White Westinghouse...
Westinghouse fridge freezer model RS6437*4 FRIDGE SIDE KEEPS FREEZING UP
Could you please check that model number again? The number you posted came up as a range. The model number should be listed in the refrigerator section.
Oct 17, 2012 | White-Westinghouse White Westinghouse...
Part #: 4900211680 fuse in a Westinghouse LTV-32w1; it blew a while back and I am trying to fix it.....I did not see any capicitor problems but I was wondering if anyone can tell me what type of fuse the...
The white body fuse is the ceramic body type fuse, the rating of the fuse should be printed on the circuit board next to the fuse.
It can have shorted out bridge rectifier, shorted MOSFET, etc. You can try standard glass body fuse just to find out if it just has bad fuse. You can get ceramic body fuse from www.mouser.com or try Radio Shack.
http://s807.photobucket.com/albums/yy352/budm/WESTINGHOUSE/Westinghouse%20LTV-32W1/
Basic LCD monitor and TV troubleshooting guide:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors pictures: http://s807.photobucket.com/albums/yy352/budm
Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague
Parts: www.shopjimmy.com
Parts: www.interliquidparts.com
Capacitors kit: http://lcdalternatives.auctivacommerce.com/Default.aspx he can make you a set of caps.
Or www.digikey.com, just make sure to use caps with low ESR, 105c, high ripple current and long life rating such as PANASONIC FM or FC series.
Jul 12, 2011 | Televison & Video
Westinghouse RJ275M 194l fridge with top 81l freezer doesn't keep the fridge cold anymore. Freezer is fine. is it the thermostat?
If the upper compartment, the freezer part is open on the ends and the rest of the refrigerator is cold enough, that can't be fixed. If the the box is closed on the ends seperate, check the flow control of air if it has one, check the thermostat and set it till things nearly freeze in the lower non frozen section. If all this doesn't work and you can't keep the ice cream turning to milk, gotta get a new refrigerator.
Nov 25, 2010 | Westinghouse Refrigerators
Timer problem
There are a few reasons why the refrigerator part will not cool...here are a couple of tips that will help you to figure out why the refrigerantor is not cooling...
Refrigerator2_bing.gif not Cooling or Fridge not Cooling
http://www.fixya.com/support/r3662945-refrigerator_not_cooling_or_fridge_not
How to Defrost Refrigerator Defrost Timer Problem
http://www.fixya.com/support/r3771673-defrost_refrigerator_defrost_timer
heatman101
Jul 18, 2010 | Westinghouse WRS3R3EW 33" 22.6 Cu. Ft....
Frigidare White Westinghouse Refrigerator
this would suggest that the compressor has got no oil in it.there is a possiblity that the compressor can be changed.but a what cost is generally dependant on the size of the appliance.roughly it will cost in the reigion of about $500.
Jul 17, 2007 | Kenmore 24872 Top Load Washer
Refrigerators Logo
108 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
