Question about Vacuums
No steam although motor is running. - Vacuums
Steam mop not putting out steam although it is heating up
Well, if you have heat and there is water in it then this is one of two things. The delivery hose is clogged either too or from the heating unit or the heating coil is not getting hot enough. Look for dripping water that is not turning to steam while it is running. That would eliminate the clogged problem. Then you could look at the heating temperature at that point.
Jun 03, 2016 | Vacuums
My Shark hand held steam cleaner sc 505 is not building up pressure, steam is leaking from lid
Throw it out, get a hoover floormate, best machine I ever had. My Shark steam/vac now resides at the dump after steam clogging problems and not being able to remove the hose to blow it clear.
Mar 17, 2014 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Shark S3101 Steam Mop won't produce steam
You have to use distilled water in the steam mop. regular water clogs it up and causes it not to work.
Nov 27, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Hi. my mop is leaking water where the steam should be coming out, although the device is producing steam (which is escaping from the water reservoir)
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it may not be getting steam to the head...
Euro-Pro Shark Steam Mop Problem
Here also is a link to get any of the
Shark Manuals that you need.
heatman101
=-=--0
Feb 19, 2011 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Hi there, There is no steam coming from my mop, although the power light is on. Please help so I can get it working again.
heatman101
Dec 16, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
Steam does not get out although when I pu my hand
There are types of water that will not work in this mop...
Here is a tip that I wrote about the Euro-Pro Shark Steam Mop and why it maynot be getting steam to the head...
Here also is a link to get any of the Shark Manuals that you need.
heatman101
Mar 07, 2010 | Euro-Pro Shark Steam Mop - Gray/ Purple...
McCulloch Steam Cleaner Problem
does your motor run if not there is a service switch to the motor inside the unit that has to be adjusted
May 16, 2008 | McCulloch MC1275 Steam Vacuum
MY HOOVER Steamvac F5906-900 does not run
There is a switch, but could be a bad cord, or the motor went bad.
Jan 06, 2008 | Hoover F5906-900 Upright Steam Vacuum
Vacuums Logo
23 people viewed this question
Top Vacuums Experts
AskDyson
AskDyson
D. Floyd Kolb
D. Floyd Kolb
Are you a Vacuum Expert? Answer questions, earn points and help others
