Question about Samsung Televison & Video
Got given a Samsung SP42Q2HL and only one scaret input works properly the other 2 are dark in colour when using them all so can you connect up a hd sky box upto it using the component inputs?
    Brigadier General:
  • 8,909 Answers
The protocol for scart sockets is, Black in colour = all pins connected and both in and out are supported. Blue in colour = only video in and audio in connected.
If you wish to use RGD, if the tv supports it, use the black socket. Some support S Video input.
Component inputs are not supported with scart as a general rule.
Posted on Jan 01, 2011
We have a 40" LCD Samsung with HD. It was working
If you are using Component Video for connection, this is an EASY fix. The component video cables were installed in the wrong order. Make sure the cables are connected to the right colors as it is very easy to mistakenly cross the Green and Blue cables. Using a flashlight will help so you can see them easier. Don't forget to check that the cables are in the right order on your accessories, too! Hope this helps.
Dec 19, 2010 | Samsung LE40R73BD 40 in. HD-Ready LCD...
Panasonic tx-32lx60a colour gone all red/dark
Ur Main Tuner signal board is dead.Replaced this board will fix this problems.Tries websites Shopjimmy.com,Ebay.com to buy a refurbish Tuner signal board for the replacement.
Mar 13, 2010 | Sony KLV-S32A10 32 in. HD-Ready LCD...
I need a wiring diagram to connect a samsung tv, sky+HD, DVD recorder, Wii and Playstation 3...thnx
all you have to remember is out of one into the other IF got Ariela on house that goes into sky then out of sky in to DVD recorder and out of that and into tv
on back of sky hd if you are going to use HDMI cable put cable into sky box and other end into tv ( you will have ot put tv on HDMI input/source)
or use scart lead in stead
THIS DEPENDS ON HOW YOU WANT TO CONNECT PLAYSTATION
everything else is colour coded
Nov 08, 2009 | Samsung 37" 720p Flat-Panel LCD HDTV
TV displays green colour on face, everything else fine
Was the color wheel replaced recently? If not and you are connected to a HD cable or satellite box using component cables. Make sure they are seated properly or connected correctly.
Nov 05, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung LE26R7 4BD, approx 4 years old, colour distortions
Check all of your cables on the back of the tv and your sources such as Cable,Sat box and DVD palyer to make sure they are fully inserted into the input and output connectors. Some times Component cables will work loose and you end up with a missing color. Temprature changes can affect intermittant connections. If that does work then you have a bad Main bd.
Jul 02, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
Bad picture/colours on Samsung LCD TV
loretta change your power pack
entwined  try another cable
Aug 21, 2008 | Samsung LE40R72BDX 40 in. HD-Ready LCD...
I have a samsung sp42q2hl, which on the front of the tv say's it is a hdtv ready, and yet i cannot watch high defenition images or movies, also there is no hdmi inlet at the back so i'm not sure how you...
Hi.
Use component to connect this will give yu HD picture,
On the back of the set you will see A group of 5 phono sockets Blue, Green, Red, These carry picture,
Then Red, White, these carry stereo sound.
Component video improves the picture quality even more by not only separating the color from the black-and-white portions of the picture but by further splitting the color information into two color-difference signals. When the picture signal is split up in this way, you get an unfiltered, uninterrupted image, with better resolution and greatly improved color saturation. And this is why component video is the predominant method of hookup from HDTV set-top decoders to HDTVs.
So this is how your set can produce HD picture from Hd source.
http://dysonmanuals.llc.nu/
Jun 22, 2008 | Samsung Televison & Video
Cant get sound from speakers
That is because you didn't have the audio input connection right.
1. HDMI cable going from the Samsung tx72 output to Your Samsung TV HDMI input 2.
2. Non HD directv box Left and right audio output should be connected directly to the Samsung DVD receiver under Satellite input.Select"Satellite"for the sound from your Samsung tx72.You are good to go!
Joe
Feb 03, 2008 | Audio Players & Recorders
Using the component 2 outlets
please read your owners manual for the samsung ptv to determine the best input to use and possible proper settings to adjust in your menu's.
Nov 15, 2007 | Samsung HCL4715W 47" Rear Projection...
Televison & Video Logo
119 people viewed this question
Jerry Greenberg
Jerry Greenberg
