Question about Indesit W 123 Front Load Washer
Some times it spins and other times wont - Indesit W 123 Front Load Washer
  • 3,267 Answers
The fact that it does not fill completely can be related to a problem with the water-level switch, that regulates the water level.
See from Repairclinic:
"This switch is usually a diaphragm device with a small, clear tube attached between the switch and the bottom of the washer's outer tub. As the water level in the tub increases, the pressure on the air in the tube increases. When the pressure reaches a certain level, it activates the switch, shuts off the water, and signals the timer to begin the agitate cycle. If the switch is defective, it may prematurely signal the water to shut off. If so, you probably need to replace the water-level switch."
However, when it is only the switch the mashine usually completes the cycle, but with less water than normal.
A possibilty is that either the timer is faulty or there is a problem with the water supply.
Check that water is coming from water supply with regular pressure, and that hoses back there are not obstructed.
More likely you will have to replace the timer.
See again from Repairclinic:
"When the cycle doesn't advance, it's probably the timer or a cold-water supply problem:
  • It's the timer, if your washing machine fills with water and begins agitating, but the timer never advances--or if the washer is in a spin cycle and the timer won't advance. Then you need to replace the timer.
  • It may be a cold-water supply problem, if the washing machine fills with water, agitates, drains, and spins, but then doesn't fill with rinse water. See There's no cold water."
  • You can find parts at the following websites, you need to input your model number. If the part is not listed contact them
    Posted on Jan 01, 2011
    HOW fix myadmiral washer model AED4475tq0
    check the clutch may be slipping and for good measure check the door switch with multi meter for continuity
    Jan 14, 2015 | Admiral Washing Machines
    60 degree wash wont spin
    Would it not take time to heat up water to 60 degree temp before it starts to spin ?
    May 03, 2014 | Zanussi Washing Machines
    Admiral top load washer wont spin
    Are you saying the machine completely quits? Or it still drains and all just not spinning after the first time?
    Jun 15, 2012 | Maytag Washing Machines
    Maytag Performa agitates, but wont spin corectly.
    If you are having a problem with your top load washer then check out this tip...
    Washing Machine2_bing.gif does not Pump or Spin
    http://www.fixya.com/support/r4617986-washing_machine_not_pump_or_spin
    If you are having problems with your front load washing machine2_bing.gif then checkout this tip...
    Front Load Washing Machine2_bing.gif not draining and or not spinning
    http://www.fixya.com/support/r4784376-front_load_washing_machine_not_draining
    heatman101
    Jun 07, 2010 | Washing Machines
    My ge washer wont spin by itself. i have to take
    it sounds to me like your motor is defective, maybe, just the start switch, but best to replace motor...Bruce
    Oct 10, 2009 | GE WDSR2080D Top Load Washer
    Wont spin does everything else but spin
    Your spin cycle control seems to be bad. This is also called your timer. Check for power supply by pulling off your top panel and checking for power everywhere.
    Apr 17, 2009 | Crosley CAWC529JQ Top Load Washer
    I have a roper washe rmachine it wont spin
    washing machine wont wash nor spin when time to rinse
    Nov 22, 2008 | Roper RAS8445KQ Top Load Washer
    Pioneer PD-F907 CD wont play most of the time
    MOST LIKELY IT SOUNDS LIKE THE MOTOR THAT SPINS THE DISC - NEEDS REPLACING
    Jun 26, 2008 | Pioneer PD-F907 CD Player
    Indesit W 123 Front Load Washer Logo
    Top Indesit Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    Darren Moxam
    Darren Moxam
    shaun taylor
    Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
