Question about BenQ SP820 Projector
How do i rotate the picture on benq sp820 - BenQ SP820 Projector
Benq GP10
rotate image features not avalable in BenQ gp 10
Feb 03, 2014 | BenQ Office Equipment & Supplies
My lamp is not igniting??! how do i fix??
Hi Carl,
It sounds like you may have an issue with either the bulb or power supply. In either case, you will need the help of a professional service center. Feel free to send me an e-mail at david@digitronelectronics.com and I can have one of our techs contact you. Home
Jan 22, 2014 | BenQ SP820 Projector
BENQ LCD TV WITH FADE PICTURE
Hello
There are two main reasons for this fault. If the CCFL lamps emits less light, due to long time of use. The second one is with the t'Von board [Timing Control Board].
You haven't given the exact model number of your BenQ TV here. If so, I might send the pictures of these components. OK.
Feb 07, 2012 | BenQ Televison & Video
Ballast error status - lamp voltage too high
You need to replace the balast as the voltages are buringing the bulb out and this is caused by a balast that is bad. The baslast is what the bulb connects to this has a sensor on it that relays voltages and heat back to the main control unit.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Oct 23, 2009 | BenQ SP820 Projector
BLOWN WOOFER
there are always good replacement options. just send the woofer size and your budget and choices can be made. you can also have the original reconed.
cathy@spekaerex.com
Jun 10, 2009 | Soundcraft SP820 Main / Stereo Speaker
Driver scanner benq 3300u
If you have a BenQ Scan to Web 3300U, just plug in the scanner to your USB port on the computer and plug the power into the power bar. XP will recognize that you have connected the scanner to your pc. It will install the scanner immediately.. Go to MY PICTURES. The top option on the left hand side of the screen will be "to obtain pictures from a scanner or a camera". Click on this.. It will tell you that you have a flatbed#23 . Click on next. Using the preview button, scan the document. Using your mouse, make the scan box fit your picture or document. Then click on scan. Save your scan job . You can then view your scan job.
Dec 24, 2008 | BenQ Scan to Web 3300U Flatbed Scanner
Benq inverter board schemtic
Post me a picture of the board and I might be able to Help.Normally transistors 2Sc5707 are defective.
Samir.
viziks@gmail.com
Aug 20, 2008 | BenQ FP71G 17" LCD Monitor
Drivers
how can i install my benq c500 webcam in my pc
Jul 08, 2008 | BenQ DC C500 Digital Camera
BenQ digital camera dc3410
check out the benq website, they might have the software up for download.
Jan 02, 2008 | BenQ DC3410 Digital Camera
BenQ SP820 Projector Logo
139 people viewed this question
Top BenQ Office Equipment & Supplies Experts
jasbo
jasbo
Tom Chichester
Are you a BenQ Office Equipment and Supply Expert? Answer questions, earn points and help others
