Question about Skull Candy Lowrider Headphones
Only the left ear is working and right isnt. what do i do?
  • 3,267 Answers
The connecting solder has come off, better buy a new one
Posted on Jan 01, 2011
Just moved to new location and hooked up i com. Am only getting sound in left ear. Have rechecked everything and all connections seem sound???
this is an oxmoron you cant have checked every thing
left and right ear audio on CBs come from a common mono signal
so the right ear signal is missing or the headphone on the right ear piece is busted
sherlock....
Nov 27, 2014 | Icom Ptt Over Ear Mic / Ear-phone For...
Left ear piece is not working
There could be a broken wire or connection in the left earpiece.
Jul 08, 2014 | LG Tone HBS-730 Bluetooth Headset- Black
The left ear is louder and much clearer than the right ear
Tried the knife, made it 10% better but no wax to clean, bc a small rubber circle is under the net... 3 good hard plucks made mine work again. Don't be afraid to pluck it hard, I tried it before softer, which didn't work initially. Reassemble, twist it's neck counter clockwise (right ear) and pluck HARD.
Feb 11, 2014 | Motorola Mobility S11-HD Bluetooth...
I have an Asus P5QL PRO Motherboard and I'm trying to connect the FP audio and I need some help on how to connect it up properly. On the heaphones lead I have 4 connectors: EAR R EAR L RETURN...
Hi
Pin arrangement for Front panel Audio is usually:
Pin 1 Left MIC-IN Pin 1 right GROUND
Pin 2 Left MIC VVC (or MIC Power, or MIC BIAS) Pin 2 Right empty
Pin 3 Left R EAR (or R OUT) Pin 3 Right R RETURN
Pin 4 Ground or Empty Pin 4 Right empty
Pin 5 Left L EAR (or L OUT) Pin 5 Right L RETURN
This arrangement should apply to both the HD AA/FP or the Standard AC'97 Headers.
I hope this helps
Aug 28, 2011 | ASUS P5QL PRO Motherboard
I don't have the directions how do I work it i have ThermoScan and want to use on 4month old
How to use Braun ThermoScan 1. Always make sure a new, clean lens filter is in place to help ensure an accurate reading. The thermometer will not function without a lens filter attached (see Changing the lens filter). 2. Press the /mem button. The LCD (liquid crystal display) is activated, showing all segments. When the ready symbol is displayed the thermometer is ready for use. 6 To help ensure an accurate temperature reading, use the following technique: If you are right handed, hold the thermometer in the right hand and take the temperature in the right ear. If you are left handed, hold it in the left hand and use the left ear. 3. Perform an ear tug to straighten the ear canal. This gives the thermometer a clear view of the eardrum. Children under 1 year: Pull the ear straight back. Children aged 1 year to adult: Pull the ear up and back. An ear tug is best performed by using your free hand to grasp the outer edge of the top half of the ear. To take your own temperature, wrap your free hand around the back of your head and grab your ear from behind. 4. While tugging the ear, fit the probe snugly into the ear canal as far as possible and press the activation button. Release it when you hear a beep. This is the Temp Beep that confirms the end of measurement. 5. Remove the thermometer from the ear canal. The LCD displays the temperature measured. 6. Replace the lens filter after each measurement: press the ejector button and put on a new, clean lens filter. 7. A new measurement can be taken as long as the ready symbol is shown. If no button is pressed within 2 minutes, the thermometer will turn off automatically. 7 Note: In the following situations, it is recommended that you take three temperatures in the same ear. If they differ, use the highest reading. · Infants in the first 90 days of life. · Children under three years of age who have a condition such as a compromised immune system and for whom the presence or absence of fever is critical. · When you are first learning to use the ear thermometer until you are comfortable with the technique and are obtaining consistent readings. Important: As with any type of thermometer, slight temperature variations ( ± 0.3 - 0.5 °F / ± 0.2 - 0.3 °C) can occur, if consecutive measurements are taken. Temperature taking hints · The right ear reading may differ from the reading taken at the left ear. Therefore, always take the temperature in the same ear. · The ear must be free from obstructions or excess earwax buildup to take an accurate reading. · External factors may influence ear temperatures, including when an individual has: - been lying on one ear or the other - had their ears covered - been exposed to very hot or very cold temperatures, or - been recently swimming or bathing. In these cases, remove the individual from the situation and wait 20 minutes prior to taking a temperature.
Mar 04, 2011 | Braun IRT3020 Thermoscan Ear Thermometer
Turtle beach x1-other people can't hear me
check if any of the wires are loose inside the thing that turns up the volume. the left and right ear wires are inside of that. i had the same problem with the right ear, all i had to do was solder the wire back on the chip.
Jul 25, 2009 | Voyetra Turtle Beach Ear Force X1 Headset
How to install bobbin
In the shuttle area there is a silver round piece- called the shuttle race cover. It has a black ear on the right and a black ear on the left. Push the right ear to the right, and the left ear to the left and the silver ring should come out. Behind the silver ring is the bobbin case stuck in the hook. Remove that, jiggle it, move it, just work the bobbin case out of the hook. Now put the hook back in the machine. In the machine there is a driver that looks like a half moon. Your hook looks like a half moon- make a full circle out of both of them. Re-install the race cover, pushing the left ear to the right and the right ear to the left to secure the race cover, and your problem should be solved.
Jul 07, 2009 | Necchi Sewing Machines
Bobbin don't turn
Jul 01, 2009 | Brother SE-270D Computerized Sewing...
Identifying left and right ear for sound
Hi Jscreamer
Turn the balance control from left to right, The sound should fade from left to right in the same direction you turn the balance control. If it does not, then you got em on the wrong way about. They often fit better the right way around too.
regards
robotek
Jun 08, 2008 | Audio Players & Recorders
Skull Candy Lowrider Headphones Logo
Top Skull Candy Audio Players & Recorders Experts
 Grubhead
Grubhead
Owen Barnes
vimal
vimal
Are you a Skull Candy Audio Player and Recorder Expert? Answer questions, earn points and help others
