Question about Canon EF-S 17-85MM F/4-5.6 IS USM Lens
Canon 17-85 err 01, please sent detail with pictures thank you
advance
  • 107 Answers
SOURCE: Error 99
Assuming that other lenses function normally on the camera, the "Err 99" can be caused by a failure of the aperture component in the lens. Error 99 is a generic error, so unfortunately it does not indicate exactly what is wrong. There are other factors that can cause the failure, but there is a good chance that the aperture is not functioning correctly. You can try cleaning the electrical contacts on the lens, if this does not work you may need to get the lens serviced. Check with Canon, or check the web for other repair service providers. David Millier Advance Camera Repair
Posted on Mar 06, 2007
  • 57 Answers
SOURCE: ERR 01
Try remove the lens, it may be faulty.
Posted on Apr 04, 2009
SOURCE: err 01 EF-S 17-85MM
Needs new Zoom flex, Has to be replaced by a repair shop and readjusted. Tony
Posted on Jun 04, 2010
  • 11 Answers
SOURCE: Problem shooting AEB with EFS 17-85 F/4-5.6 IS USM
Your flex cable to the Iris is broken. Have a look at my gallery at http://www.pbase.com/barry_2718/efs1785mm
Posted on Jun 24, 2010
Tri3mast
  • 747 Answers
SOURCE: have a canon 17-85mm USM lens. when taking photo
That's a really odd fault and to be so specific in focal ranges is a further oddity which makes me wonder if it's the mount having a slight bit of movement (slop) in it.
I have that very lens and use it regularly about a year ago I sent it to Canon for some minor service when it came back it had a different "feel" the lens was tighter in operation.
Would it be possible you need to clean the gold contacts on both the lens and body (I know you said it wasn't the contacts) with a red rubber eraser making sure not to get the rubber dust into the sensor area. Then watch the lens as your shift through your focal lengths to actually see if the lens is moving slightly between the lens and body. Make sure the lock is in tight with a distinct click, if all this fails then I'm sure a trip to Canon is in order, it's a great lens and worth the repair.
Posted on Jan 06, 2011
My Canon EOS Rebel XS only takes pictures indoors (ERR. 01)
You didn't say which shooting mode you're using, but I'd bet you're in Manual mode and have dialed in a completely wrong aperture/shutter speed combination for bright lighting conditions. For example, 1/60th of a second and f2.8 in bright sunlight would be "burning out" your image, so the camera may be giving you an error message. Try using AUTO or PROG setting and see if the problem persists. If it does, try a different lens. You may have an incompatible mount, or one of the contacts may be damaged. If all else fails, try your lens on another Canon camera.
May 14, 2017 | Canon EOS Rebel XS 35mm SLR Camera
Error 01 in canon eos 5d
Err 01: Lens to body communication error
1.The camera to lens communication is somehow being interfered with could be a problem within the lens itself, possibly the camera body, or something as simple as a smudged fingerprint on the lens mount contacts,
2. Check the lens and the contacts
3. Also check below link if you need a canon eos 5d service manual
http://goo.gl/1rXwuc
thanks
Apr 26, 2012 | Canon EOS 40D Digital Camera
How to repair err 01 on canon 1000d "Communication
So, have you cleaned the contacts? Remove the lens and using a cotton swab lightly dampened with rubbing alcohol, clean the contacts on the lens and the camera body where they meet.
Oct 15, 2011 | Canon EOS Digital Rebel XS / 1000D IS...
Hi sometimes it takes a picture with no problem but sometimes I get err 99 or err 01. Any ideas?
Hi! Welcome to Fixya
Err 99 could mean several different things, such as... Memory Card, Lens or Lens contacts....
Here's what you can try:
Remove the memory card an enable "shooting with out memory card" and see if you still get the error. If it works your memory card is bad. Try another lens if you can. Clean the lens contacts with a pencil eraser (be careful not to get eraser dust in the camera body or in the lens). Worst case scenario is, Err 99 could be related to the shutter failing which would mean a trip to Canon.
Thank you for choosing Fixya!
Feb 08, 2011 | Canon Rebel XT / EOS 350D Digital Camera
Hey! I purchased a Sigma lens 70-300mm macro ____ and after I've attached it to my Canon 450D a take one or several pictures I get the "Err 01" problem, that "the communication between the camera and...
According to Sigma, your lens should be fully compatible with your camera although there will be the usual 1.6x crop factor as the lens is designed for a full frame sensor. This would not cause your Err 01 fault though so you should return the lens to your dealer for refund or exchange. Failing that, consider claiming on Sigma's one year international warranty. The warranty is ONLY valid if your lens was supplied with the Sigma Warranty card. All new Sigma lenses supplied through official resellers include the Warranty Card. You can find more details about where to send your lens for a warranty repair by clicking here.
Good luck, and please take a moment to rate my reply.
Sep 16, 2010 | Sigma AF 70-300mm f/4.0-5.6 DL Macro Super...
Err 99 keeps coming up
It is due to some kind of electrical (contact) failure.
For more details and common causes of Err 99 read the following article:
http://www.lensrentals.com/news/2008.12.31/canon-err99
May 16, 2010 | Canon EOS 40D Digital Camera
Err 01 on Rebel XSi
shutter struck, if the battery has no enough charge the shutter motor will not rotate fully,charge the battery and try.
Aug 31, 2017 | Canon Digital Rebel XSi Digital Camera
HI. Every I attempt to take a picture with my cam, I get a "Error 01" message. Please advise. Thank you
Err 01: LENS COMMUNICATION DESCRIPTION: This error occurs in the following conditions: When electronic communication with the lens cannot be established, after the EOS D300D is powered ON or when the shutter button is pressed halfway. When the lens diaphragm cannot be controlled during shutter release.
REMEDIAL MEASURE: Clean the electronic contacts on the lens with a clean, soft, dry cloth and check the mount interface switch on the body's lens mount for dirt or other damage. If this does not solve the problem, try another Canon EF lens or have the EOS EOS D300D examined by a qualified service technician. This error is similar to Error 84 on the D30.
rate me on this one...
thanks!
May 09, 2009 | Canon EOS 40D Digital Camera
ERR 01
Apr 01, 2009 | Canon Rebel XT / EOS 350D Digital Camera
Canon EF-S 17-85MM F/4-5.6 IS USM Lens Logo
158 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Doberman
Are you a Canon Camera Expert? Answer questions, earn points and help others
