Question about Westinghouse 22" Widescreen LCD Flat Panel Monitor
My monitor wont turn on but it gets the power light on how do i fix it?
  • 3,267 Answers
You are not getting video signal from the cpu, check your smps
Posted on Jan 01, 2011
Monitor wont power off
The blue light probably simply means that the computer is not turned on, but the monitor is. Just turn off the monitor, and the blue light should go away.
Mar 16, 2014 | Computers & Internet
My monitor hp w1858 wont turn on
Your monitor may have developed a power supply problem since being refurbished
Jul 04, 2013 | HP Refurbished 18.5" Widescreen Monitor...
AL 1706 troubleshouting monitor wont turn on green
If your monitor shows a yellow light and it won't turn green, the problem most likely lies with the computer. If your computer is not sending a signal to the monitor, then you have a computer problem. One way to test this is to turn the monitor off and the computer off, too.
Turn the monitor on and if it is working, it should display a message telling you that there is no signal. If you see that message, you can assume the monitor is working. If you do see it, now turn on the computer and see if the message changes.
If you turn the monitor on and you get no message, you can assume the problem lies with the monitor itself.
If you have access to another monitor, hook that one up to test the computer output.
You can now either get the monitor fixed or the computer fixed, depending on which one is bad.
May 31, 2011 | Acer Computers & Internet
Monitor says no signal
Fix the power cord firmly! hold it and fix it such that you wont get a shock! also fix the cord from monitor to CPU firmly! I prefer you to turn off you computer..clean the power cord by blowing the dust on sockets and pins and then fix it firmly and turn on computer again! Make sure power is not running in the cord while you clean it!
Oct 17, 2010 | ASUS VW193T Monitor
My 194wt worked great for 3 years, now it wont turn on at all. is this the normal life of this monitor ? how can i fix this ?? ive confirmed 120v at power inlet and some dc voltage on various mini pins on...
Same problem as above. Had mine for 2.5 years and worked fine until I tried to turn it on this morning - won't come on at all. I have tried another power cable and verified that another monitor works on the old one.
Oct 03, 2009 | LG L1915S 19" LCD Monitor
Wont turn on, nothing.... Power supply is good
Replace the power-cord.
Wait until midnight, and turn out all the lights in the room, so that's dark in your computer room.
Turn on the monitor, and see if you get any light and/or any lamps (green? yellow? red?)
Try a different monitor attached to your computer.
Try your monitor on a different computer.
Sep 10, 2009 | Polyview PT-525A Monitor
The power buttom on my Dell E228WFP 22 not working
MY MONITOR JUST WENT OUT AND I GOT 2 RED LINES ON EACH SIDE OF SCREEN SO I UNPLUGGED IT NOW IT WONT POWERUP AND LIGHT IN BUTTON WONT GO ON
Feb 27, 2009 | Dell E228WFP LCD Monitor
The monitor light does not turn on!
Connect another external working monitor to the computer, if the other works then get lamps and inverter replaced.
May 25, 2008 | ViewSonic VA520 15" Flat Panel LCD Monitor
Monitor wont turn on, green power light on
Hi you can inspect that what's wrong with your monitors. After you turned it on and the screen went black, you have to check that if you can see the image on the screen or not by shining a flashlight into the screen, not directly but find the best angle to the screen and take a look very closely. If you can see the icons or any image, there will be a minor problem. This is because of the lamps inside screen. Some of them were broken and it is very easy to replace. If you cannot see anything on the screen, there'll be some problems with inverter board. If you have soldering tool and want to fix it by yourself, check the caps first. It may cause this problem. Some caps might show leaking or burn spot on the board because of too high temp. If you don't have soldering tool, you better go get a technician to do so. Hope this help!! If anything I can help you with, feel free to let me know.
Thank you,
Mar 08, 2008 | IBM ThinkVision L170 17" LCD Monitor
Westinghouse 22" Widescreen LCD Flat Panel Monitor Logo
Top Westinghouse Computers & Internet Experts
Matthew Spark
Matthew Spark
Iqbal Husain
Iqbal Husain
Are you a Westinghouse Computer and Internet Expert? Answer questions, earn points and help others
