Question about LG RC389H DVD/VHS Recorder
What is the purpose of the input sockets on an LG RC389H DVD/VCR Combo. Can I connect them to an LCD TV output and record the tv's output? The tv signal comes through a HD set top box
  • 6 more comments
  • Alan Jones
    Alan Jones Jan 01, 2011
    Sorry, I'm not sure I understand you. The output sockets on the tv are of the RCA type, as are the input sockets on the dvd
  • Alan Jones
    In addition to my previous comment, I can record from the tv using the dubbing sockets on the front of the vcr, but only those channels that are not through the stb, by using the red,white and yellow rca plugs. I want to record the feed from the stb to the tv via the tv out sockets
  • Alan Jones
    What does "yes you can nut" mean?
  • Alan Jones
    Sorry but I can't understand what the previous reply meant. Can anyone else help please?
  • Alan Jones
    Alan Jones Jan 02, 2011
    A connection diagram would be much appreciated
    1.Hisense LCD tv Model HSLC4833AB
    2.LG HD TV Receiver Model:LST-6100P
    3.HDMI
    4.Antenna coax
    5.S video
    In addition, can you tell me what the tv output sockets are for?
    Thanks
    Alan
  • Alan Jones
    Thanks for the explanation. Hope you have a good night's sleep.
    I look forward to the diagram tomorrow. And a Very Happy New Year to you
    Alan
  • Alan Jones
    Alan Jones Jan 04, 2011
    Hi there, I was hoping you would have had time to do that diagram for me by now. Hope you didn't part too much over the New Year
    Alan
  • Alan Jones
    Alan Jones Jan 06, 2011
    Thanks BElectric. A very clear understandable explanation including a diagram, (and we won't mention the cricket! Even Warnie appears to have scored an own goal - excuse the mixed met)
    President:
  • 1,140 Answers
The purpose of the INPUT sockets on the DVD/VCR is for recording, but this cannot be done by connecting it to the TV OUTPUT. A TV cannot "send" its picture to another device for recording.
In order to record, the DVD/VCR input sockets will need to be connected to corresponding OUTPUT sockets on the set-top box or a connection directly to the aerial/co-axial cable. This can be done by inserting a co-axial splitter on the aerial cable before it reaches the set-top box. The DVD/VCR's built-in tuner will then need to be tuned before you can record. You will also need another cable from the OUTPUT sockets on the DVD/VCR to the TV for playback.
There are many different ways to configure this. Much depends on what OUTPUTS and INPUTS are available on your set-top box or TV.
If you would like me to "draw" some diagrams of possible set-ups for you, I can, however you will need to let me know the following details:
1. Brand and exact model number of TV
2. Brand and exact model number of set-top box
3. How is the set-top box currently connected to the TV
4. How is the set-top box currently connected to the DVD/VCR
5. How is the DVD/VCR currently connected to the TV
This information is required so that I am able to work out which sockets are currently being used and which ones are still available for setting up the DVD/VCR.
Hope this helps. Please post back with the above information if you need further assistance.
Regards,
BElectric
Posted on Jan 01, 2011
  • 4 more comments
  • DILLIGAF
    DILLIGAF Jan 01, 2011
    A brief conclusion of what I wrote above: In order to record from the set-top box, the set-top box MUST be connected directly to the DVD/VCR using the correct input on the DVD/VCR.
    I can draw a specific setup diagram for your actual equipment if you can supply the information requested above.
  • DILLIGAF
    DILLIGAF Jan 02, 2011
    Hi there. Thanks for all of the information - I will answer the simple question now, but the diagram will take a little longer. I was about to switch off for the night, so I will have to do this in the morning. I hope that's OK.
    The output sockets on your TV can only output channels from the TVs own built in tuner. These can be output to and recorded on your DVD/VCR - I think you already discovered this.
    The TV cannot output the channels from any other source, i.e. your set-top box (STB). This is due to the way in which video signals are processed and distributed within the TV. If you had a direct antenna connection or a direct cable feed (no STB), you would be able to record all of the TV channels on your VCR using the TV's output sockets. This is because you are using the TV's built in tuner.
    The STB has its own built in tuner. The signal from the STB cannot be sent to the VCR via the TV. Therefore, in order to record from the set-top box (STB), the STB must be connected directly to the DVD/VCR. It is also necessary to use the correct connections on the back of the DVD/VCR as some of the inputs are DVD exclusive - they won't work with the VCR functions. I will explain this more with the diagram/s.
    Hopefully this explains what that TV's output sockets are for. If you have any further questions about this, please ask. I will post back with the diagrams asap in the morning.
    Happy new year to you!
    Regards,
    BElectric
  • DILLIGAF
    No problem. Please don't post any further comments until you hear back from me in the morning. I have to reply to all comments within 4 hours or your problem will be returned to the "unsolved problems list and will most likely be picked up by someone else.
    Also please note, my comments may soon start to appear on a second page. If you receive a notification of a new message from me and you are unable to find it, please scroll to the bottom of my last visible message, then click on "View More Comments" in the light-blue bar directly below.
  • DILLIGAF
    DILLIGAF Jan 04, 2011
    Hi Alan,
    My apologies for the delay - unfortunately New Year did reach a slightly excessive level followed by a sudden influx of replies from people from people who had either forgotten or ignored their minor technical problems over the Christmas period causing me something of a backlog. I am doing your diagrams right now and will post back with them shortly.
    Don't forget to click on "View More Comments" to see my future messages.
    Happy New Year to you!
    Nick / BElectric
  • DILLIGAF
    DILLIGAF Jan 05, 2011
    Hi Alan,
    Once again, I apologise for the delay.
    I have now completed your setup diagram. It would have been too small to be legible if I had pasted the diagram within this message, so I have uploaded the diagram to Flickr for you:
    http://www.flickr.com/photos/57298187@N02/5325229815/sizes/l/in/photostream/
    Unfortunately, I was unable to find a decent diagram of the socket layout for the DVD/VCR, so the connections are simply shown as TO/FROM the corresponding sockets on the TV and set-top box. I have verified which sockets are present on the DVD/VCR and which are the correct ones to use with the set-top box. Colours are arbitrary and only intended for easier reading.
    I am just writing some notes to accompany the diagram and will post these within the next 30 minutes - really!
    Regards,
    Nick / BElectric
  • DILLIGAF
    Setup Notes:
    (Arrows on diagram indicate direction of signal flow)
    1. Set-top box to TV
    The current HDMI cable connection you are using will give the best quality HD video and audio. No change required.
    2. DVD/VCR to TV
    There are several methods of connecting these two devices. HDMI would give the best quality HD, but there is no spare HDMI input on the TV. I have assumed you are already using a separate RCA audio cable (red/white) with your S-Video connection to the TV as S-Video cables do not carry an audio signal.
    Component A/V (3x RCA - red/green/blue) would improve the DVD playback quality over your current S-Video connection. On some DVD/VCR players, Component OUT only works for DVD playback. I was unable to verify this for your player but, if this was the case, you would need another connection to the TV for VCR playback. As you have playback from both the DVD and VCR using the S-Video and RCA audio cable, there is no real need to change it.
    3. Set-top Box to DVD/VCR
    The DVD/VCR does not have a built-in digital tuner, so your current Antenna/Co-ax connection is redundant and should be removed. Devices with digital tuners, e.g. your set-top box, will have the DVB symbol (looks more like DV3).
    The only suitable outputs on the set-top box, with corresponding inputs on the DVD/VCR are the RCA type (red/white/yellow) audio/video sockets. Making this connection will allow you to record directly from the set-top box, although you will only be able to record the channel selected for TV viewing. In order to record from a different channel to the one you are viewing, the DVD/VCR would require its own dedicated digital tuner (i.e. another set-top box) or you would need to replace your current player with one which has a built-in digital tuner.
    To record from the set-top box to DVD or VCR you will need to ensure that the input source is set to "AV1". This can be done by pressing the "AV/INPUT" button (below "POWER" on the DVD/VCR remote control until "AV1" shows on the display on the front of the player.
    Hopefully, I've covered everything here. If you have any questions, just let me know and I will answer them as best I can. Similarly, when you have everything setup correctly, if you are having any difficulty recording, just let me know.
    5/344 . . . not looking too good for your boys is it ;)
    Regards,
    BElectric
  • 3,267 Answers
Yes you can nut This does not record in NTSC format.
you can use either HDMI or A/V cables for this job
  • Sudeep Chatterjee
    Sudeep Chatterjee Jan 01, 2011
    This unit does not convert between PAL and NTSC. To record in PAL this unit must receive a PAL signal. To record in NTSC this unit must receive an NTSC signal. This signal can come from your STB itself by channeling the TV signal first to combo
I have just bought a 40 inch HD LCD TV, I want to purchase a combo VCR/DVD HD to be able to record channel 11(the new free to air channels HD). Big W gave the model No. RC 689 D to me but they were not...
The VCR/DVD combo that you purchased will be able to record what you wish to a VHS tape at low quality or to a DVD at a higher quality.
  1. Coax cable (round and screw on) from the antenna to VCR/DVD
  2. Coax/AV/HDMI cable (only need 1) from the VCR/DVD player to TV
  3. TV on and turned to the input matching the cable you used in step 2
  4. Turn on VCR/DVD and use the remote control included with this unit. Not the TV's
  5. Turn it to the channel 11 on the VCR/DVD
  6. Put in a VHS tape or DVD-R to record onto
  7. You will be able to hit record whenever the show comes on or used timed recording in the menu to schedule it ahead of time
Sep 14, 2011 | LG RC389H DVD/VHS Recorder
How do you connect a polaroid lcd tv to a polaroid vcr/dvd combo?
does it have HDMI INPUT/OUTPUT? OR Audio video input/output? First you must have a cable for either of those two. HDMI (from the lcd tv) to HDMI (vcr/dvd combo).
audio/video input (from the lcd) to audio/video output (from the vcr).
hope this helps.
Jul 06, 2011 | Polaroid TLX-01911C LCD TV
How do I hook up dvd to tv
If your TV has the standard analog audio and video inputs (yellow, red and white jacks) or for better image (S-Video rounded 4 pin jack or component video red, blue and green jacks), you'll only need the corresponding cables, and also your TV could have HDMI port (digital video and audio signals), you should use this connection, all depends of what type of outputs provide your DVD/VCR, in the case your TV set doesn't has any of mentioned inputs, you still could use the antenna input and connect its matching output from DVD/VCR , tuned at VHF channel 3 or 4.
Feb 12, 2011 | LG RC897T DVD Recorder/VCR Combo
I'm getting no output to the tv and I did triple check the connections. I'm using basic RCA cables.
I had the same problem myself. To fix it,I went into the menu for my Television set and changed the setting to VCR/DVD ... then I used the remote for the LG combo and changed that setting to AVI 1 using the 'input' button under the #9. It would not show on the front of my LG combo but did show on the TV screen. The problem is that your combo and television are not communicating with one another,like speaking 2 different languages.
Nov 20, 2010 | LG RC897T DVD Recorder/VCR Combo
Operation manual for a LG RC389H DVD RECORDER
The manual is available from LG:
http://www.lg.com/au/tv-audio-video/video/LG-dvd-vcr-combo-RC389H.jsp
click on the support tab and you'll find the manual listed on the right side of the web page (it's done as a frame).
I hope this helps.
May 07, 2010 | Televison & Video
Can't record tv shows
Output of combo to input of TV, and you need the cable / antenna attached to the combo to record what you want to see.
Jan 11, 2010 | Philips DVDR3545V/37
Connect jvc combo vhs/dvd recorder to satelite and tv
If your satellite box has two sart outputs. Scart1 should go to the Tv Scart 2 to the input on the Video. Then the output scart socket on the VCr should go to Scart 2 on the TV
Sep 23, 2008 | Televison & Video
Hook-up
first you do connect cable to your > combo VCR / DVD player & recorder then connect to > to your TV:
cable coax output or if that cable have video/audio ouput is going to INPUT >to combo VCR / DVD player video / audio output is going to INPUT > to TV,.that's the time you can record and playback;
click below for more information in hooking up:
DVD Players/Recorders: Home Theater Setup, Installation & Hook Up ...If i have helped,please click fixya,it is the only way i get paid for my work ,also please consider leaving feedback...
Good luck ,and Thank you in advance:
Jul 15, 2008 | Televison & Video
Connections for DVD Recorder/LCD TV/ SKY PLUS
Connect the AV output of the Sky box to the AV input of the Panasonic combo.Look at rear of the Combo and you will observe input and output RCA connections.Using RCA leads, hookup the Av output of the Panasonic to the audio/video input of the Sony tv. Power up Appliances, and you should be OK.
Apr 11, 2008 | Panasonic DMR-EZ47V DVD Recorder/VCR
LG RC389H DVD/VHS Recorder Logo
318 people viewed this question
