Question about Nokia 5130 Cellular Phone
Phone is not getting started when i tried to start the phone it only display nokia and then turn off automatically
  • Nokia Master
  • 3,267 Answers
LOW BATTERY
Posted on Jan 01, 2011
My nokia 6600 mobile does not start 1or 2 hours later to try start the mobile and start but display show white and my mobile has swich off in some time automatic
hello !
try to formate your celular phone use this code to do that *#7370#
and follow the instraction given on sceen
peace
May 10, 2011 | Nokia 6600
My nokia 6300 does not start properly. When I switch it on it starts showing me the display sign but then switches itsel*** automatically.
try removing battery for ten mins then try again the try removing memo card if it remains you have to take it to a nokia care centre
May 20, 2010 | Nokia 6300 Cellular Phone
I have a problem with switching my nokia 3110 classic answer pls!
The Problem with Nokia 3110c – Switching off and automatically restarting This is what happens. Nokia 3110 hangs, gets switched off and restarts randomly. More often, it restarts around 3 times or so and then gets switched off.
Possible Causes and Solutions Cause 1 – Phone Memory Full – Nokia 3110c mobile phone has got 9MB of internal memory.
Solution – Keep the free space between 350 to 500 KB, so as to keep things running smoothly on your phone and prevent Nokia 3110c from restarting.
Cause 2 – Changing Themes – Some people have reported that the phone restarts automatically when they try changing display themes on the phone.
Solution – Don’t get your phone loaded with too many themes downloaded from the internet or atleast, don’t switch themes frequently. These themes, mind you, also load up things into your already falling Nokia 3110c phone memory.
Cause 3 – Memory Cards – Some people have reported that Nokia 3110c restarts due to some issues with the memory card.
Solution – Remove the card, get it formatted and then insert it back and then restore factory settings. This just might solve the issue.
Cause 4 – Transferring data via Blueooth / USB data cable (or) Updating Music Library – A few people have reported that their Nokia 3110c mobile phone restarts when updating the music library.
Solution – Don’t try updating of music library frequently or don’t often transfer data in/out of your Nokia 3110c phone.
Cause 5 – MP3 files
Solution – This may seem dumb, but consider converting all your MP3 music files to WMA and then store them on the memory card. Some users suggested this.
Also try this:-----
It ll work . you dont need to go 4 the firmware v5.05
If ur phone restarted 3 or 4 times and switched off automatically. Try this
method
1] Remove the battery and Micro SD card
2] wait about 5 minutes
3] Then switch On the phone WITHOUT the memory card
Now ur phone working well without restarting
4] Then you must restore Factory settings frm the Settings Menu
[default security code:12345]
{i know most of people have done this thing,but remember u have 2 go
with the correct order.Unless it will not work.OK}
5] Now apply a theme. The theme's size should be below 100kb
6] Now ur phone working fine without the Micro SD
7] Then wait about 5 minutes and Switch off ur phone
8] Remove the battery and insert the Micro SD
{Don t Format the memory card}
9] Switch On ur Nokia 3110c phone.
10] Now Keep ur free Phone memory space [Not the memory card's free space]
between 470kb - 499kb.
Now surely ur 3110c working fine about 5
months.During these time u can
1] Send/receive any file via bluetooth.
2] Enjoy Music,video, GPRS,Yahoo Go .....etc
3] Also u can Update music library anytime.
but remember below DONTs
1] Don t try to change themes.{u have to stick with a theme}
2] Charge ur phone in ON mode
3] Dont fully discharge the battery
4] Start charging ur phone when there is only a bar on Battery indicator
5] Dont erase calender notes
Make sure about above 5 Donts
Dont worry if ur phone restarted once.{U know the problem is restarting several times
and automatically swiched off.}
After 4 or 5 month there is a possibility to occur the problem again.
if so Follow the above steps again.
Good luck
To be frank, This mobile has this as a generic problem. As I told, The problem can come back again.
Thank you Sir, Have a nice day.
Sep 21, 2009 | Nokia 3110 Cellular Phone
My nokia 5310 will only display the Nokia logo the it will be off
if the problem u described is for real, m sorry to say that u need to format ur phone. Its because when u start ur phone, u see only Nokia logo. But inside, it prepares files which are required to start the phone & to keep it runnin for a long time. if any of these files gets corrupted or missing, ur phone wont start. so I'll suggest u, dont go here & there, go to Nokia Priority Care, and ask them to format it.
Aug 27, 2009 | Nokia 5310 Cellular Phone
NOKIA 3230 - 'Switch on' problem Hi, My nokia 3230 mobile got switched off on its own and I am unable to switch it on since few days. Even the logo "Nokia" is not appearing on switching the power switch....
Hi ,Try to charge your mobile with another same model battery, switch it on.. and keep it swiching on for five mins,, and try with your battery .. its really works.. this is all because your battery charge limit is gone under minimum
May 30, 2009 | Nokia 3230 Cellular Phone
Nokia 6681 Restarts automatically
Type *#7370# and give phone security code. This is a soft format. If no result, go to a better mobile servicing center. Make a whole flash (mobile phones OS repair). Still have problem, change UM chip. Keep informing.
Feb 19, 2009 | Nokia 6681 Cellular Phone
No Beep Sound in call waiting
try reflashing the phone to correct the issue
May 13, 2008 | Nokia N72 Cellular Phone
What can I do for start nokia 6125 ? or how can I format nokia 6125 ?
This is phone's software problem and it will not be put right by formatting etc. It seems that are corruption in it's system files and needs reflashing. Technician with smart software repairing tools only can do this for you.
Jan 10, 2008 | Nokia 6125 Cellular Phone
Nokia 6600 does not open
aapko apne cellular phone ka software update karna hoga
Sep 18, 2007 | Nokia 6600
Nokia 5130 Cellular Phone Logo
50 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
