Question about HP LaserJet 1600 Printer
My HP Laserjet 1600 i completely dead. I've checked mains, shifted mains cable but nothing happens when I turn it on. Is there any fuse inside? Is the problem the fuser unit? If so how to the replace it? Any suggestion what to do? E.Andersson Sweden
  • effegbg Jan 04, 2011
    Thanks for help. I found a good description how to dismount the printer and checked the 2 fuses on the AC supply board. They were both ok. So it seems that the only way to solve the problem is to shift the AC board. (The printer was relatively cheap to buy so I don't think it's worth trying as there is no 100% guarantee.)
  • HP Master
  • 4,924 Answers
I dont think the fuse is the issue ..though it can be in some cases...If there is no power at all usually it is an issue with the power supply unit ..and need to be changed..(ac adapter if this i sthe case..and do not have a internal power supply )
Posted on Jan 01, 2011
No power to 2001 yamaha 1600 road star. battery good, fuses good, starter relay good.
Hi, David and the usual suspects are:
1. Ignition Switch not in the "ON" position.
2. Engine Run Switch in the "OFF" position.
3. Discharged battery, needs to be 12.5 volts or better and be able to pass a load test if necessary, check battery terminals for damage or corrosion, check the battery cables at "BOTH" ends for loose, corroded, or broken connectors, "INSIDE" and outside the cable harness, perform connector wiggle test and check cables with an ohmmeter if necessary.
4. Bank angle sensor tripped and ignition/light key switch not cycled to the "OFF" position and then back to the "ON" position.
5. Faulty ignition switch.
6. Faulty starter button.
7. Faulty kickstand or clutch pull in switch/sensor.
8. Security alarm needs a reset.
9. Starter control circuit, relay, or solenoid faulty.
10. Main fuse or circuit breaker may be blown or faulty.
11. Electric starter shaft pinion gear is not engaging or over-running starter clutch slipping.
For more information about your issue and valuable "FREE" downloads that you will need please click on the links below. Good luck and have nice a day.
Re Electrical Starting System Failure Road Star Forum Yamaha Road Star
ROADSTAR FUEL PUMP INTERMITTENT FAULT
http://www.electrosport.com/media/pdf/fault-finding-diagram.pdf
http://www.vsoc-eastanglia.org.uk/xv1600.pdf
http://www.starmotorcycles.com/assets/service/manuals/2006/LIT-11626-19-45_Road_Star_1266.pdf
Jun 18, 2016 | Yamaha Motorcycles
Honda cbr 600 f4i dead
follow the positive cable to the starter relay there might be a fuse there
Jan 11, 2013 | 2004 Honda CBR 600 F(4)i
I crossed the pos and neg terminals while jump starting my bike and now nothing happens when the key is turned on. What happened?
You have probably killed the battery and all the electronics on the bike. Get the bike checked by a qualified bike technician/electrician.
Feb 12, 2012 | Honda VT 600 C Shadow Motorcycles
My Bernina Activa 220 won't turn on. This has happened before, and I've always tried plugging/unplugging, switching outlets, etc. In the past something has eventually "worked" and once...
Could be almost anything ! Do the usual simple checks - fuse in the mains plug (should be 3A), have you got another piece of equipment (radio etc.) that uses the same 2-pin plug for power - use it to check that the mains cable is OK. If the mains cable is OK, it maight be the switch on the power supply module or the power supply module itself ('L'-print), but could be more ... check if the sewing light or display backlight is coming on, but if completely dead, your only solution is to get it checked-out by a Bernina service agent.
Nov 05, 2011 | Bernina Activa 130
Are there any main fuses on a 2001 plymouth neon
Have you checked the starter solenoid. Your battery + cable connects to this then + cable runs from it to your starter. You also have an ignition switch wire connected to this. Just follow your cable from the battery and it will lead you right to the part. Some times these will break inside or the contacts go bad inside and therefore you will not get power to start the engine, but you will have power to turn on lights or whatever other accessories.The part is about $15
May 11, 2010 | 2001 Plymouth Neon
03 Matrix completely dead!
check main fuses, circuit breaker check, check and clean terminals, check for corrosion in battery cables
Sep 17, 2009 | 2006 Toyota Matrix
I cannot get into my honda 2002 crv. Both electric keys don't work. Can unlock only drivers side with the keys. Try to open any other door ... nothing ! Put key in ingnition absolutley nothing !! as if...
Honda uses a main fuse under the hood near the battery, if the car is completly dead, no lights, no horn. then I would start there.
Follow the red positive cable from the battery to each stop, you should locate a fuse. If the cable goes directly to the starter, then look for the power distrubution box, check for the main fuse or breaker there.
Hope this is of some help.
Ed
Apr 19, 2009 | Honda CR-V Cars & Trucks
2008 nissan sentra has occasional starting issues. this has happened 4 times since we bought the car. car runs fine, sometimes will not start when key is turned. everything is dead....no lights inside, no...
Could be bad battery or Somthing going on with the main fuse box.  Another thing to check is your ground wires.  If they are loose, you can not complete the circut.
Mar 03, 2009 | 2008 Nissan Sentra
Laserjet 2100 Won't turn on!
Yep, the power cable can be faulty, test a different one on a different socket. Try also playing with the power connector on the printer.
If the power cable is fused, like for example in UK, then check the fuse.
If it still does not give any sign of life, then there is a fault on the power supply board, inside the printer, usually the power supply fuse. Part is about $45 refurbished/$55 original .
If the problem is not the fuse you will need to get a technician testing on board component, and probably replacing a faulty resistor or capacitor.
Sep 26, 2008 | HP LaserJet 2100 Printer
HP LaserJet 1600 Printer Logo
53 people viewed this question
Seeker5211
Seeker5211
