Question about IBM ThinkPad T43 Notebook
When started all i get is a dark screen - IBM ThinkPad T43 Notebook
  • 11,361 Answers
  • Bud Martin
    Bud Martin Jan 01, 2011
    More likely to be bad inverter baord, but you need to verify as suggested by cmptr. I use test lamp for testing the monitor.
    DO NOT USE DMM to measure the output voltage on the output pin of the inverter, the firing voltage is about 1500~1800v, it will blow your meter input circuit and you may even get a bad shock since your meter probe and insulation are not made to measure anything more than a 1000v.
  • IBM Master
  • 2,385 Answers
Hello
To solving the problem of Dark Screen of Laptop there are a few things to determine to see what the problem is.
The first thing I would advise to be done is to check your laptop with an external monitor to make sure that it is not the video chip that went bad. So connect your laptop to an external monitor and see if you get a picture (you might have to press the fn and one of the f1 , f2 , f3 etc....keys together to switch the output to an external display , If you get a picture on the external monitor you know it is not the motherboard , (whew, was getting scared already). If you don't get a picture on the external monitor make sure it is plugged in correctly and that you pressed the correct keys to have the output signal go to the external monitor. If you are sure you did all of the above steps correctly , then shut off the computer and try pressing down on the keyboard while powering up the laptop and see if you get an image. Sometimes if a computer has a loose connection between the GPU (Graphic Processing Unit) and the motherboard it will result in no video or flaky video , so try pressing down on the keyboard while powering on and try see if you get video. If you get a video output then you will know that it is a flaky video chip and that will have to be fixed.
Inverter is usually at the bottom of the screen. Now back to if you got a picture on an external display. Once you got a picture on the external monitor and established that it is not the video chip or motherboard you will have to try to determine if it is the lcd screen itself or if it is the inverter. The inverter is a small electronic board that controls the voltage that is sent to the backlight (the light bulb of the laptop screen) of the lcd screen. If the inverter breaks or dies then no voltage gets to the backlight resulting in no video output signal to the display. In my experience, I see that most of the times it is the inverter that is the problem and that is a pretty easy fix , you just have to get the correct inverter that supplies the right amount of voltage and you will be back in business. But in some instances it is the backlight (light bulb) that went , and to repair this is more difficult and more time consuming. One way to see if it is the inverter , is to test the two prongs of the inverter with a voltage meter and see if they are giving off the correct voltage (please read up more on this method , as inverters have high voltage output , so you have to know what you are doing , so I strongly advise to read up on this more prior to doing it. Another simpler way is to shine a flashlight on the lcd , if you see a faint image then in most cases it is the backlight that needs to be replaced. If you don't see an image even when shining the flashlight then it is most likely the inverter and it should be an easy fix.
On a last note if you determined that it is the backlight that is faulty , although it is fixable it requires more time and experience then just replacing the inverter , and if one is not experienced you can damage the lcd screen itself as well , so generally if the backlight is faulty either have a laptop repair shop replace the backlight , but only one who has experience. Or another option is to buy a new lcd panel and install it either yourself or proffesionally. Generally it is not very difficult to replace a lcd panel but there are some models that are more difficult so try to ask a laptop repair shop about your specific model
Hope this helps, if so do rate the solution
Posted on Jan 01, 2011
I have a 75" Samsung LED TV, and the top position of the screen is going dark, is that a power supply issue?
Samsung TV half the screen goes black or dark - YouTube
? 0:38
www.youtube.com/watch?v=Mmu5wq6LVgM
Jan 28, 2012 - Uploaded by DaReal2Face
Samsung TV half the screen goes black or dark. ... My samsung 40" - 14 months old does this on the top half of the screen. .. ****** 12 month ...
Sep 28, 2015 | Samsung Televison & Video
Vizio LCD SV420XVT1A-has a red screen when starting then red bleeding through dark
Got to go to settings to change the color of your tv screen and see if that helps
Jan 23, 2015 | Vizio Televison & Video
Screen dark
when on sattelite screen (it starts on that screen) push left button to diminish screen brightness. The screen should return to a non-perfect, but readable state. No idea what is causing this problem or how to definitively resolve it.
Feb 28, 2014 | Garmin GPS 12 GPS Receiver
Dell Inspiron 1525 laptop screen goes dark
Hey Lea,
Try the steps below to see if they will resolve this issue that you are having with your computer. If this does resolve the issue you can email me. My email address is listed below in my sigfile.
1) UNPLUG THE LAPTOP
2) REMOVE THE BATTERY
3) HOLD DOWN THE POWER BUTTON FOR ABOUT 30 SECONDS TO 2 MINUTES
4) THEN PUT THE BATTERY BACK IN
5) START IT UP..
Thank You,
Dell-Jesse L
Dell Social Media and Communities
email jesse_leonard@dell.com
Apr 13, 2013 | Dell Inspiron 1525 Laptop
Compaq dark screen
Sounds like the screen is burned out. You need to replace it.
Jun 25, 2012 | Compaq Presario CQ60-206US Laptop Charger...
Screen keeps going into darkness at start-up
Hi
The screen kept winking out because the brightness setting was too dark, something to do with the tolerance perhaps?
I just made it brighter and all was well!
Dec 29, 2009 | Formac Gallery Xtreme 2010 20.1" LCD...
When switch in on laptop it goes screen dark why
I'm not really sure I understand.
You apparently are able to turn the laptop on.
How long before it goes dark?
If it goes dark right after the Windows splash screen, then I would suspect it's a video driver problem. Try starting it in safe mode to rule this out.
If the screen does not go dark in safe mode, you've located the problem. You'll have to uninstall any video card software and download the correct drivers.
Nov 28, 2009 | Sony Computers & Internet
Sony KDF-42WE655. Screen goes dark.
Replace your lamp if you had it more the 3 years.
Nov 08, 2009 | Sony Grand WEGA KDF-42WE655 42" Rear...
Screen goes dark after a few seconds
try fn+f7 that Toggle external monitor,and disconect external monitor before starting
Jun 13, 2009 | Lenovo 3000 N100 0689 Notebook
Acer Travelmate LCD screen went dark
The same thing happened on my HP. I ended up buying a LCD screen off ebay. That corrected the problem. New screens cost $150+. You can get one off ebay for half the price.
Jan 16, 2009 | Acer TravelMate 270XV Notebook
IBM ThinkPad T43 Notebook Logo
158 people viewed this question
Top IBM Computers & Internet Experts
Computer Links
Are you an IBM Computer and Internet Expert? Answer questions, earn points and help others
