Question about Panasonic Toughbook 28 Notebook
I pressed function key and keys kjliom has changed to numbers how to change back
    Master:
  • 397 Answers
Hit the numlock key- sounds like you turned on the numlock and it made it to where your keys are now acting as the numberpad
I’m happy to help further over the phone at https://www.6ya.com/expert/susan_42b401e0b1603d8a
Posted on Jan 01, 2011
How to solve the error of canon iR2016 photocopy system error E003?
How to reset E000, E001, E003, and E007
Canon IR2016, IR2020
Enter the service mode by pressing "additional function" key, "2" and "8" keys in that order. SSSW will display. Press "OK" key.
Change Bit switch 1, bit 0 (might display as the first one on the left using number keys) status, (change 1 to 0 or 0 to 1).
Press "OK" then Press "Stop" or "Additional Function key" to end service mode or restart the machine.
Canon IR2270/IR2870/IR3570/IR4570/IR5070/IR5570/IR6070/IR6570
Enter the service mode (Press "Additional Function" key, Press "2" and "8" simultaneously, press "Additional Function" key again).
Go to COPIER----FUNCTIONS-----CLEAR----ERR. Here you can reset all error codes on by one.
Canon IC-MF6530/6550/6560/6580
No reset procedure is required, replacing the fuser is the only repair.
Canon D860 series
Press Additional Function key and the "#" key in that order. Go to Printer (number 7), select "Set", Select "Printer reset" and press "set".
Canon Printer Support Phone Number
Dec 06, 2017 | Canon Office Equipment & Supplies
Need to take number lick off
NUMBER LOCK
You have press the NumLk key (number lock) and this changes the right hand keys to a number pad.
Press the NumLk key (also doubles as the ScrLk key to toggle the Number lock). it is near the F12 function key. When the NumLk has been enabled a LED light is turn on to indicate this function has been selected. Press the NumLk key again to turn off the Number Lock and Num Lock LED indicator..
Jan 12, 2013 | Computers & Internet
My words key turned into number key
NUMBER LOCK
Press the NumLk key (also doubles as the ScrLk key to toggle the Number lock). it is near the F12 function key. When the NumLk has been enabled a LED light is turn on to indicate this function has been selected. Press the NumLk key again to turn off the Number Lock.
Dec 21, 2012 | Advent Netbook
Keyboard on Laptop QX BA69-00912A is not producing the letters / numbers pressed
NUMBER LOCK
Dec 09, 2012 | Samsung R519-53S Notebook
How do I change Name of sender?
1. Press: function, 3,#, #
Display shows: your own number
2. Press: start
3. Enter your fax number (max. of 20 digits)
by pressing the number keys.
• To insert a space between digits, press
the # key. To enter "+", press the * key.
• If you make a mistake, press the SPEED
DIAL key to backspace and clear the mistake.
4. Press: start
5. Enter your name by pressing the appropriate
number keys as shown below.
• To enter two letters in succession that
require the same key, press the
SPEAKER key after entering the first letter
• To change case, press the REDIAL key.
Press # or * to scroll through symbols
and special characters.
6.When finished, press: START
STOP
Dec 06, 2012 | Sharp UX 60 Fax
Number lock, how to use it
NUMBER LOCK
Oct 24, 2012 | Dell XPS M1730 Laptop
My keyboard is messed up. i am pressing the FN button but when i let go it goes back to turning letters into numbersers
Sep 02, 2012 | Toshiba Computers & Internet
The function key is always on, on the keyboard. How do I change it back to a normal keyboard?
Press the NumLk/ScrLk button at the top right corner. That will turn off the 9-key number and symbol buttons. The Function key dosn't get stuck, just the number lock key.
Oct 18, 2010 | Panasonic Toughbook 19 Laptop Convertible...
Hi, i need change number of ring to fax into panasonic 8020e
yep. you can only change it through fax service mode. here check it out:
To enter the Fax Service Mode
  • Press “FAX/EMAIL” key.
  • Press “FUNCTION”, and then “7” keys.
  • Press “MONITOR” four times, then press “*”.
  • Enter the desired code number, or press the “V”, ”/\” arrow keys.
  • Go to function parameter setting, and then press START key
  • Press '4' and then '5' keys or press 'V' to select #045 mode.
  • Enter a number (1 for 1 ring, 2 for two rings...), and then press START key to save.
  • To exit the Fax Service Mode press “STOP” key.
Jan 11, 2010 | Panasonic DP-8020E Black and White Copier
Panasonic Toughbook 28 Notebook Logo
67 people viewed this question
Top Panasonic Computers & Internet Experts
Oloyede Monsuru
micky dee
Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
