65" RCA TV
The problem is that we were gone for a few days and a circute blew which had our TV and Directv connected to it. So now when we turn the TV on it says "The search for data has failed please check your TV connection". Well nothing has been moved or unplunged and everything is the same except that we can't watch TV or cable till we figure out how to reprogram, fix or what ever needs to be done.
    Sergeant:
    Champion:
  • 250 Answers
If you have DirectTV your dish is out of alignment. If you had winds or a storm it probably moved the dish. If it moved even a hair you won't get programming. Have someone watching the tv where it's looking for signal and go out and push a little on the dish and have them yell out when it starts receiving data. It really won't take much movement for it to come back on.
Posted on Jul 08, 2008
There has got to be a way
I have this model..was trying to hook it up to a directv hughes receiver. After a day of trying and many curse words I found that using this hookup works . Hook up your satellite connection to you tv as usual...Now plug rca cables(red, yellow white) into the corresponding holes on the BACK of the Directv receiver ..now plug the rca cables into the FRONT of the Magnavox player...you will only use find holes for the white and yellow(that's ok) Now hook up up the dvd player to the tv using the rca connection back of dvd/vcr player..or if your tv only has a coax connection you will need a rf modulator available at walmart etc. You will run the dvd/vcr on L2. The key is the connections to the FRONT of the dvd/vcr player..I hope this helps..:)
Aug 03, 2009 | Philips Magnavox DVD/VCR Dual Player
How do I hook up a daewood vcr to a TV through a Direct TV
If you are trying to connect a VCR to your television and still have Directv, this is the way to do it. Disconnect your Directv receiver from your television, Then connect the VCR to the television either through coax or RCA cables. If using the coax cable connect the out to tv on the VCR to the television. If using RCA cables connect the RCA OUT to the television AV1 connection. Once that is done, connect tha Directv receiver to the VCR using either coax or RCA cables. the Directv receiver only has RCA outputs so, if using RCA cables connect to VCR in. Remember that in order to see the Directv the VCR needs to remain on and it must be on the channel line in. If using coax cable connect to the VCR where it says in from antenna. Remember that if using this method your VRC does not have th remain on to view Direct. If you're trying to record Directv, then your VCR need to be on the same channel as the Directv output channel either channel 3 or 4. If trying to record Directv using RCA connections the VCR needs to be on the AV settings. If you have any futher questions please feel free to call me at (361)510-0339
Jonas Lopez
Jag Satellites/ Directv
Installer and Technician specilist
jlopez.jagsat@sbcglobal.net
Mar 02, 2009 | Daewoo DV-T47N VCR
Reciever problem
How do I connect direct tv to denon and then get sound
If the RCA TV has HDMI input connect as follows:
1. Connect an HDMI cable from the Directv box to an HDMI input on the Denon.
2. Connect an HDMI cable from the HDMI out-put on the Denon to the RCA TV
3. Select input the DirecTV is connected to at the Denon, at TV select HDMI input Denon is connected to TV.
4. On front of denon press the input mode button to select auto
If the RCA TV has Component input (Green,Red,Blue) connect as follows:
5. Connect Component Video and Audio cables from the Directv box to a Component Video and Audio input on the Denon (TV, DBS,VCR).
6. Connect a Component Video cable from the Denon to the RCA TV Component Video input.
7. Select input the DirecTV is connected to at the Denon, at TV select component input Denon is connected to TV.
8. On front of denon press the input mode button to select aut
If the RCA TV has Composite input (Yellow) connect as follows:
9. Connect Composite Video and Audio cables from the Directv box to a Composite Video and Audio input on the Denon (TV, DBS,VCR).
10. Connect a Composite Video cable from the Denon to the RCA TV Compositet Video input.
11. Select input the DirecTV is connected to at the Denon, at TV select composite input Denon is connected to TV.
Feb 25, 2009 | Audio Players & Recorders
Connection problem with Denon 589 and direct tv
Feb 08, 2009 | Denon AVR588 Receiver
I have a 27" color flat screen tv by Samsung which I bought from Best Buy in Lakeland, FL 4 yrs ago never had a problem til now. I had a power outage in my home but the tv wasn't on nor was the...
Try to use your directv box with a different A/V connection to the TV and see what happens?
EX. If you have a basic directv box using coaxial cable connection,try to use RCA(yellow,red/white) cable to a RCA input behind the tv.
solutiondoct
Nov 22, 2008 | Televison & Video
"UNUSABLE SIGNAL"
l have a 42 in tv rca connected from a direct satellite and i have no picture or sound tryed different connecters only black screen with unsable signal
Jan 07, 2008 | RCA HD65W140 65" Rear Projection...
Surround sound
Make sure the RCA cable is going from an audio OUT on TV or DirecTV box to a red/white (non-digital) audio IN on surround sound or home theater system.
Dec 29, 2007 | Insignia NS- 27" TV27 TV
Screen colour missing
this problem could be a few things. first if you know how touse a volt metter go to the crt pcb on the end of the picture tube. Try to measer the voltage on the collector of the red drive transistor. If when the red color goes away and the voltage shoots way up past 150 or so volts then the red drive is disapearing from the video jungle ic or through one of the componets from it. If the voltage drops way low like less then 65 to 75 volts or less then theres a cold solder connection between the b+ feed resistor that suppys the b+ to the drive transistor the driver power supply sourse.. In an extremely rare case would the Picture tube be at fault but certainly could be. Good Luck OOps almost forgot it could als be a bad connection on the crt socket as well..
Apr 05, 2006 | RCA 27F530T 27" TV
Televison & Video Logo
54 people viewed this question
Top Televison & Video Experts
