I am unable to find a HDMI port on the above tv. is there one? if not is there anything i can get to connect it?
  • 734 Answers
To get hdmi, you need a dvd/vcr recorder with hdmi. Then a hdmi cable to goto vga or component video and stereo connectors. If your TV has only RF input, then you need a rf converter(channel 3 or 4) from component video and stereo connectors.
Posted on Jan 01, 2011
How to properly connect the channel Master antenna tuner to my TV so that I can connect an antenna to the tuner. I have the CM-7001. I'm connecting through the HDMI port on the tuner to the HDMI port
Confusing question! The CM-7001 is meant to be used for displays or monitors that have no means of connecting an antenna and don't have a built-in tuner. HDMI to HDMI would be the correct way and make sure you select the proper HDMI port. Or use the other video and audio cable connections.
Sep 03, 2014 | Channel Master CM-7001 ATSC Antenna and...
Guys, Recently i got LG 22" LCD TV. It has VGA port and HDMI port. When i connected my CPU cable toLCD via VGA port it didn't show anything, :"( i checked input MENU on remote then it shows only 4...
HDMI [High Definition Multimedia Interface]. VGA [Video Graphics Array]. AV [Audio Video]. By these definitions itself talk to you about the inputs your TV have; and it do not support VGA. Output from PC is VGA. Without a VGA input with the TV, you can't connect the PC to TV. I think I'm clear. http://electronicshelponline.blogspot.com/
Jul 09, 2014 | Televison & Video
Unable to Connect Laptop to Samsung LED TV
VGA is analog - HDMI is digital
if u have a cable w/o a converter it won't work unless your video card supports digital signal output through VGA port function. Please consult with your laptop's user manual for more information.
Dec 10, 2013 | Compaq Presario Notebook
M4a88T HDMI port does not work
Is the TV turned on and set to the input that you have the HDMI cable connected to?
Have you tried other HDMI ports on the TV?
Have you tried it with another HDMI cable?
Have you tried it with another TV?
Dec 22, 2012 | ASUS M4A88TM LE AM3 AMD 880G HDMI Micro...
What kind of wire do I need to connect my samsung laptop to panasonic viera hd 3d plasma tv?
Most TVs will have HDMI and RCA component and composite jacks. Some TVs will also have a VGA port. Your laptop will have a VGA port. (If the laptop is fairly new, it may also have an HDMI port.)
Not all TVs will support an HDMI signal from a computer, so the VGA signal is often better. However, that limits you to SD (anything with HDCP will fail.)
Very few TVs ship with the HDMI or component cables. However, there are some vendors who do package the HDMI cable with their TV. Without knowing which exact model of TV and laptop, I can only make a few suggestions. I know that the TCP42ST30 (Plasma 42") doesn't have a VGA port.
Look at your laptop for any external monitor port. VGA ports are generally blue female ports with 15 holes (D-Sub). If your TV has a matching VGA port, get a standard VGA monitor cable.
If you have the VGA port on the laptop but not on the TV, you can try a converting from VGA to HDMI. (You may need a DVI to VGA adapter and either a DVI to HDMI cable or a DVI to HDMI adapter.) Note: this gives an analog signal (RGB format) to the TV. You'll also need to make sure that your VGA port is active (in the BIOS for some computers) and then set your computer to send the signal to the external monitor. It is best to turn off both the computer and the TV before connecting the two. Then turn on the TV and set it to the correct input before turning on the computer. (In Windows 7, I set the video signal for the external monitor by right clicking on the desktop and selecting Graphics Properties. Set the signal to the external monitor and click Apply. Then click OK (in the external monitor's screen).)
If this doesn't work, you need a VGA to component video converter. (Not a VGA to component video cable - those are for projectors that read the RGB signal.) See http://www.ramelectronics.net/audio-video/video-converters/vga-rgb-hv-to-component-video/c10000-c11200-c11215-p1.html .
Some laptops come with an HDMI, mini-HDMI or a DisplayPort option. For the latter two, you will need the appropriate cable with that end and the HDMI connector on the other. Then connect the TV and the computer as described above. (Note: my TVs accept a computer signal at the HDMI port labeled HDMI/DVI. However, you need to make sure that your TV understands this signal. It isn't the same format as that from a set-top box. My laptop has VGA and HDMI out; the desktops have VGA, DVI and HDMI (on one).)
If you add a comment with the model of your TV and laptop, I'll be glad to give you more specific options to connect the TV and the computer.
I hope this helps.
(A DVI port is a digital video out option with ~21 pins and is usually white.)
Feb 03, 2012 | Panasonic VIERA Televison & Video
My proscan 32lb30q won't allow me to switch inputs to HDMI. It will only allow me to go between composite and tv channels. I'm trying to set up my laptop to connect. It's not a connection/cable problem,...
First, verify that your computer is sourcing video through the HDMI port rather than looking for an input from it.
What happens if you try to select an HDMI input on the TV with no HDMI cable connected? It should select the port, then complain about "No signal." If you get that, turn off the TV and computer, connect the HDMI cable, turn on the TV first, then the computer.
There are certain HDMI input chips on the market that are very vulnerable to static electricity damage, and some cheap HDMI switches will conduct a static discharge from the switch mechanism to the HDMI lines (a friend blew two chips that way, then he realized both times the input went out when he used the switch). Use a direct cable connection if possible, and avoid putting a fingertip into the free end of an HDMI cable when the other end is the only one connected. Symptoms of static electricity damage may include "no signal" when an active signal source is connected, or some sort of data format error message. I don't know if your TV is programmed to lock out bad ports; I would think there would be some sort of fault indication to go with the lockout.
Jul 09, 2017 | Proscan 32LB30QD 32 in. LCD TV
If hdmi cable sends audio and video info from my laptop to my tv why can't I hear anything? I have video but no audio. the Audio all say hdmi/high def audio and are working properly
Have you "muted" the sound on your computer?
Have you "muted" any of the outputs (MIDI, speaker) on your computer?
Have you "muted" the sound on the TV's built-in speakers?
Have you "muted" the sound on any external speakers that are connected to your TV?
Does your TV have _more_ than one HDMI port? Have you tried them all?
Got a friend with a TV with a HDMI port?
If so, connect your laptop via THEIR HDMI-cable to their TV.
Also, connedct your laptop via YOUR HDMI-cable to their TV.
Jan 09, 2010 | HP Pavilion dv5-1002us Laptop PC
Playstation wont connect with av cable
is it just the tv screen saying no signal? if so you may still have your tv in HDMI mode if not then you need to go into the television settings
Dec 03, 2008 | Sony Playstation 3 (PS3) Console
Can i connect toshiba satellite a205 to tv?
Yes VGA carries RGBHV--RGB and Horizontal and Vertical Sync information along with DDC info where available.
Now is that port on your TV a d-sub 15 pin standard VGA connector?
http://en.wikipedia.org/wiki/VGA_connector
If it is, then yeah you should be able to output VGA from a PC to the TV with a proper cable.
However if the TV has DVI or HDMI connections on it, it's better for you to connect it that way. DVI/HDMI is a digital signal and if it's a digital-based display tech TV, then you're better off using that. Also if the TV does resolution above 1360x768 (i.e. if it does 1080p) you can get higher resolution by going via DVI/HDMI...
Dec 01, 2008 | Toshiba Satellite A205-S4617 Notebook
Televison & Video Logo
37 people viewed this question
Top Televison & Video Experts
Electro Med Services...
