I bought a Luxor TV No V19LCDDVD-875 over a year ago initially we tried to set it up with a small ariel and could only get one Channel. Now have installed a proper loft ariel have tried to set it up and it will only get BBC1 and T4 we have tried to press Menu button and nothing happens - can you please tell us how to set this up as we cannot make head or tail of the instructions!!! Very many thanks
SOURCE: My Sanyo Tv (model dp327460 is Busted
You should try and download the users manual if you do not have one...I remeber seeing in it that after hooking every thing up, you have to do the channel search twice before the unit will work properly..This is highlited in the manual with correct hookup diagrahm..
Posted on Aug 10, 2007
SOURCE: Polaroid HD flat screen TV with DirecTV
I have Polaroid TV Monitor HDMI LCD 15.4" no power light on TV, blank screen, the power adaptor is Ok 12VDC supply. I need suggestion; in any possible problem or parts busted?
Posted on Mar 24, 2008
  • 6 Answers
SOURCE: no digital yet tried to retune but greyed out.
Just got through to Samsung support. Turns out the freeview card had frozen and needed a reset. To do this put tv on standby. then press in serries these buttons on the remote: 'info' 'menu' 'mute' 'power' TV will then turn on with a default screen. Press 'arrow down' button untill you reach option 12 'reset' . then push the 'right arrow' and tv will reset and start in plug and play mode and commence a scan when you've set the time. Just retuned mine and its back to normal. Hoorah!!! :-)
Posted on Oct 05, 2009
  • 3 Answers
SOURCE: bbc1 1nd 2 not on my freeview TV after several
reset the TV to factory settings and try again
Posted on Feb 13, 2010
  • 68 Answers
SOURCE: Hi, I tried setting up my TV last night and all I
You must check your input signal...how is signal being sent to your' TV....set TV to THAT input type
Posted on May 20, 2010
Factory settings on Luxor tv
You should after factory settings ,when you tune the correct channel you must press store ,and if your doing it manual you must press store after each channel is found. That's should do the trick.
Sep 21, 2017 | Luxor Televison & Video
My luxor model16-914-tvb TV will not set channel s when self/auto tuning keeps coming up and says no antenna connection. Know the airal connection is OK as have tried lead that we used on smart tv
So if you have confirmed that your antenna is good and delivering sufficient signal strength, then the issue has to be with a defective front end or tuner section. Usually located on main board of set.
Sep 03, 2017 | Luxor Televison & Video
Luxor TV won't connect to preset tv channel apps. It keeps saying it needs to be connected to an aerial but it shouldn't because these apps should work through the wifi. Help please?
Did you get any advice elsewhere. My Luxor tv is doing the same thing. I don't have aerial input. Hence why I bought a smart tv. Netflix and YouTube are fine.
May 26, 2017 | Luxor Televison & Video
I have the Luxor smart tv,says it has built in freeview but I can't get it to find channels, help me please? Do I need an ariel? Thanks
Of course you need an antenna of some sort . usually an outdoor type works better than any indoor one will .
May 13, 2016 | Luxor Televison & Video
How do you connect luxor 50inch smart tv to bluetooth. My phone finds the tv but i cant see how to type in pairing code
How do you connect luxor 50inch smart tv to bluetooth. My ...
www.fixya.com/.../t26003543-connect_luxor_50inch_smart_tv_bluetoot...
4 hours ago - first turn on bluetooth and goto bluetooth settings and goto authentication and turnoff it.then bluetooth is connected ... when it asked for the pincode ...
40inch luxor tv - YouTube
? 0:29
https://www.youtube.com/watch?v=XrVJZtkV4sc
Aug 25, 2011 - Uploaded by jasonmctavish24
I bought this tv, now the picture is good for blu rays and my xbox etc. But it says 'DAVE' in really faint ...
Dec 11, 2015 | Cell Phones
Luxor tv
Sounds like the main system control memory IC has damaged. Replace the same and check. It is a very small IC, having 8 solder terminals. Very cheap, and easy to get. Will look somewhat like this.
Jul 01, 2013 | Televison & Video
Menu controls
sometimes pressing either both channel or both volume buttons willl get you in the setting
Jun 18, 2012 | Televison & Video
HDMI Output with my Onkyo 875 Receiver
Hello, the TX-SR875 does not support up-converting from component or S-video to HDMI. Is the model number correct? You stated the receiver is "brand new". This model is from 2007. Thank you, Onkyo USA
Mar 23, 2017 | Onkyo TX-SR875 Receiver
Televison & Video Logo
128 people viewed this question
Top Televison & Video Experts
Electro Med Services...
