Question about Gigabyte 7VM333M-RZ (GA-7VM333M-RZ) Motherboard
Audio jumpers missing. Where do I place them
    President:
  • 1,851 Answers
I thing that you mean the jumper settings for the front panel audio. In this case these are the details:
In case you need further details you can take a look at the motherboard's manual at this official link.
In case of a problem or clarification, don't hesitate to post me a reply before rejecting my answer.
If you are satisfied, rate my solution with the "thumbs" or (even better) add a testimonial.
Thanks and regards
Please kindly rate this solution
Stelios
direct FixYa link: http://www.fixya.com/users/technical114
Posted on Jan 01, 2011
I'm refering to jumpers on the mobo itself. The only one that was on it was the cmos jumper. There are places where other jumpers could go. I thought that perhaps I had accidently knock one off
Jumpers can go on Hard drive, but it is no longer usefull since with SATA connectors, you don't have to specify with a Jumper which one is the master or slave HD.
Feb 28, 2013 | Acer Aspire M3100-U3401A Refurbished...
Some componets has remove from the charging system place,so want the solution to replace them (schematic)
I've solved many times by making jumper.Actually I want to know the place where the components were missed.Just make jumper all the coils and remove the IC.(Glass ic. filter)May be this can help you good luck
Sep 09, 2011 | Nokia E63 Cell Phone
Computer will not keep time or date. battery has been changed twice
hi. somehow, you seemed to have a jumper missing next to the battery. put the jumpers on the rightfull place and there is no need to be changing bateries
Nov 16, 2010 | ASUS P5LD2 Deluxe Motherboard
I have a 661fx m7 motherboard my audio is not working i have build the machine myself do i have to connect anything to the motherboard or does the on board audio just work on its own
Try doing this with jumpers on the mother board. http://www.hardwaresecrets.com/imageview.php?image=222 Look for this pin outs carefully as there are few others that look the same. Remember in the link, its 9 pins with 1 missing at a certain place, look for the same that matches. Put jumpers where you see its greyed out.With the jumpers installed, it will carry sound the the rear jacks of the Computer. See if that helps.
Nov 09, 2009 | EliteGroup 661FX-M7 (661FXM7V11)...
Need jumper settings, and manual to download.
Your card is broken.
Standard the card doesn't carry any jumpers. The only possible place for a jumper is on JP2-2 to disable the joystick.
May 27, 2009 | Creative Labs Sound Blaster Audigy 2 Sound...
Intel d865 glc mother board sound card is not woking
you first verify that front audio pin jumper place in motherboard
if you are not using front panel audio so insert jumper in front side audio attachment see manual for more detail
Feb 02, 2009 | Intel D865GLC Motherboard
Audio is not functioning
nearly by sound ic you can found 6 jumper setting
your front audio jumper place there after that your rear audio input/output can work
Dec 13, 2008 | Intel D845GLLY Motherboard
Aopen ax4bs no audio device found.
I've tried this and your right. It is the Jumper Caps missing causing your audio not to work. It should work. Maybe your diagram is up side down? Or maybe it is the wrong jumpers?
Oct 24, 2008 | Acer AOpen AX4BS-V (91.89J11.001)...
Missing part
Hi, Sorry to tell you but this motherboard supports ONLY SDRAM memory. There is no way that a DDR memory will fit into this motherboard. What you can do is add another SDRAM memory for better performance.
Apr 28, 2007 | Syntax SV266A SKA KT266A Motherboard
Gigabyte 7VM333M-RZ (GA-7VM333M-RZ) Motherboard Logo
516 people viewed this question
Top Gigabyte Computers & Internet Experts
David
David
Tony
Matthew Spark
Matthew Spark
Are you a Gigabyte Computer and Internet Expert? Answer questions, earn points and help others
