Question about ASUS P5KPL-AM SE Motherboard
MY COMPUTER WILL SHORTLY OPEN BUT AFTER 10-20 SECONDS THE COMPUTER DISPLAY WILL BLINK OR WILL SHOW A DISTORTED GRAPHICS THEN BLACKS OUT.
  • 80 Answers
Run in safe mode to see if you have the same problem. if it works fine try reinstalling the graphics driver.
if this wont solve your problem, Most probably there is a problem in graphics section. try installing a graphics card instead. before doing so u need to disable inboard graphics from BIOS.
Posted on Jan 10, 2011
My pc dont show any thing axcept blank display with i tried to change graphics
Maybe one of your memory chips is bad.
If it seems to boot up all the way except the display is blank try the steps below:
Borrow a monitor from a neighbor, friend, relative or co-worker and connect it to the computer. If the Borrowed monitor display the desktop then the original monitor is bad, but the video card inside the computer is ok. If the Borrowed monitor does not display then the video card inside the computer is bad.
If it does not seem to boot up all the way try the steps below.
When you plug in the power cord is there any lights whatsoever on the laptop, where the plug goes in or on the AC Adapter of the power cord?
When you press the power button do you hear fans running, hard drive spinning, lights on the computer, hear any beeps or lights constantly blinking, hear the DvD/CD drive click and the light on the drawer of the DvD/CD turn on for a second or two? If so the computer is trying to boot or may have booted, but the screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with the laptop and why it is not booting. Most times it's a motherboard issue when you hear beeps or blinking lights continuous. Most times the problem is with the memory or Video Card. Count the Blinking Lights or Beeps and take note of their pattern (1 Long or 1 Long followed by 2 Short).
Maybe you have a Static Charge Buildup. Remove the Power Cord, then Press and Hold the power button for 30 seconds. After 30 seconds plug the power cord back in and hit the power button to see if it boots.
Maybe your memory is bad or the memory slot is bad.
Remove the Power Cord, Open the Case and remove one of the memory chips. Set the chip aside then try rebooting the computer. If it boots, then you know the memory chip you set aside is bad so mark an x on it with an ink pen. If it fails to boot then move the chip to the next memory slot and try rebooting. If it fails take the chip out and set it aside, then put the other chip in and try booting it in both slots. If it boots, just to verify that the chip set aside is bad, mark an x on it and put it into the open memory chip slot and try booting.
Jun 07, 2012 | Intel Computers & Internet
A7600 GS TDH, Supplemental power supply problems, every time i load a game it also dosnt show the true graphics it shows some of it distorted, sometimes when i turn off my computer an restart it, i go to...
Hello there,
In Windows, it just comes up with a message saying it will be clocked down, so you just click "OK"? if molex is not plugged.
1. You should install the driver for the graphic card so it wont show distorted images, Microsoft display drivers are not reliable in gaming you may experience distortions.
2. Plug the molex or 4pin power to your card and observe if you will encounter the same problem after doing step 1.
3. If not try to test another PSU or acquire a new PSU that is powerful enough to run the card - not using the power cable could damage all your system.
Hopefully this information helps.
Happy Gaming
Thank you for using FixYa.
Aug 10, 2011 | Leadtek WinFast A7600 GS TDH GeForce®...
Hello, I have a ViewSonic N1700w. I have hooked it up correctly(all drivers downloaded, proper connections, etc.). When I turn it on the power led blinks until there is video or graphics to display. When...
it sounds like the inverter was defective, the monitor will be fine for few seconds then go off but power light still stay on with Green. You can contact with manufacturer for repair service if it still under warranty.
Mar 22, 2010 | Computers & Internet
Green light blinking , no display ,,
look inside for bad caps, see example of failed Viewsonic monitors here: http://s807.photobucket.com/home/budm/allalbums
You should have 5v and 12v in the power supply sections.
Jan 17, 2010 | ViewSonic : 19" Graphics Series Flatpanel...
Distorted display/aspect HP w1907
This is a common problem with wide screen format.
The way I overcome this distortion is to open a drawing program and draw a circle, some programs require you to hold down the shift key to produce a perfect circle.
I then go to the Display Settings and adjust the screen resolution to get the best display that fills the screen and that gives me the perfect circle.
If this does not work you may need to download the latest video driver for your graphics card and then adjust the screen resolution..
Aug 22, 2009 | HP w1907 LCD Monitor
Monitor displays image for second and displays black again
Your Monitor has a heat sink issue. A capacitor in the monitor is at fault and when it heats it tells the monitor to turn off the display to save the display from damage....Problem Cost to repair will supercede the cost to replace it...Wal-mart 15" monitor 119bucks --17" monitor 129...same at staples office supply (Poof) problem solved.
Mar 21, 2009 | Gateway FPD 1810 18.1" Flat Panel LCD...
Display problems
THE DRIVERS MAYBE CORRUPTED AND YOU NEED TO GET IT UPDATE OR RE AVTIVATED
Jan 19, 2009 | Ultra ATI Rage 128 Pro Graphic Card
Distorted Graphics
graphics board needs replacing. Hard to source but it is a modular replaceable unit. Access is directly under the keyboard.
Dec 13, 2008 | Dell Inspiron XPS M1710 Notebook
Samsung 172N 17" LCD monitor blacks out seconds at a time with increasing frequency and eventually displays scrambled graphics until system restart.
The problem I have is that when we connect the screen it wiorks fine then blacks out after 5-40min
It then flickers on and off iregularly and every now and then shows distortion and eventually just blacks out
I have two 172N monitors and both now show the same symptoms
We have used different VGA cables and different computers in different locations all with the same result
There is no external influence that we know
Oct 30, 2008 | Samsung SyncMaster 172N 17" LCD Monitor
3rd gen 8g brand new
check the hold switch is off and try again
if that doesn't work plug it into your computer
Jul 17, 2008 | Apple iPod MA446LL/A MP3 Player
ASUS P5KPL-AM SE Motherboard Logo
55 people viewed this question
Top ASUS Computers & Internet Experts
David
David
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
