Question about Garden
I have got a homelite ZR Series Z 830 SBA whipper snipper an when I started it today I found that the shaft is not moving
SOURCE: stihl whipper snipper wont start..
I have a Sthil and the wiper snipper it starts but when I increase the power it seen to either stall or flood plesae help
Posted on Nov 04, 2010
rycgl
  • 1545 Answers
SOURCE: I have just replaced the
You probably have the counter weights from the shaft hitting the bottom of the piston skirt. To remedy this, you will have to pull the piston/connecting rod off of the shaft, turn it around and install it the other way. If you notice, the piston's skirt is longer on one side than the other in most cases.
Posted on Jan 09, 2011
roadtech7
  • 293 Answers
SOURCE: What is the exact fuel
It depends on how old it is, the older its is the more oil is needed. 30 years ago it was 20:1 and now they run 50:1.
Hope this was helpful.
Posted on Jan 18, 2011
  • 144 Answers
SOURCE: I have a two stroke
Hi tracey4t, I will try to give you a few suggestions. You might have to adjust the idle speed screw that is located top on the carburetor where the throttle cable is hooked. There you will see a screw with a spring that if you turn it clockwise you increase the idle speed, and if turned counterclockwise will decrease the idle speed. It could also be a carb adjustment of the low or idle speed mixture needle, if there is one on your carb. In the past few years, most carburetor makers have eliminated 1 or 2 of the adjust needles. These ports are now inside the carb and are fixed, not adjustable. If you have a low speed needle or the 2 needle adjustments, they are positioned about the center of the carb. They have springs on them. They are marked by L or H on the carb body, and the low one is usually the one closest to the engine. Turn it out or counterclockwise to add more fuel to the mixture. Do this 1/8 of a turn at a time while the engine is running. The engine should turn faster if that is what is needed, keep doing this until max. RPM. If that does not increase the idle speed, try turning it the other way. If that does not work, then it could be a number of things, but I think this will work. Hope this is helpful to you. All the best and good luck. Denis.
Posted on Feb 25, 2011
  • 3074 Answers
SOURCE: i have just got sa
take the spool off and then you will see a nut, it is left handed threaded, on the top side of the head unit there is a plug/bolt/screw remove that and wedge a flat tip screwdriver into the gears and remove the nut, replace with new unit tighten replace plug and it is a done deal. Good Luck Tim
Posted on Mar 22, 2011
I have a stihl 2 stroke petrol whipper snipper. It seems to have over heated at the reel end. I have smoke and grease spewing out at that end (metal neck at the reel end) have I fried it?
Sounds like you have a straight shaft trimmer version that have got bad bearing(s) that needs replacing. It probably will take the whole gearbox as a replacement item.
Jan 20, 2015 | whipper snipper stihl fs 38
Whipper snipper revs but head doesn't turn
Englebert the most common thing would be that the inner shaft has sheared off. Remove the head and see if it spins then.
Dec 29, 2013 | Garden
Sthil whipper snipper fs38 won't engage the starting pull mechanism, it turns but won't grab drive coupling
remove the recoil cover and check the dogs that engauge the starter to the flywheel
Jul 28, 2012 | whipper snipper stihl fs 38
What is the correct fuel oil mix for a homelite whipper snipper
I believe Homelite calls for 40:1 (2.6oz. oil to 1gal gas) mixture, but if you are using a good current brand name two cycle oil, 50:1 (3.2 oz. oil to 1 gal gas) would be safe also.
Feb 08, 2011 | Homelite Mighty Lite Lawn Trimmer
The carburettor needs an overhaul or replacement.
take carby down to any mower shop ...most brushcutters use same carbys...
Mar 20, 2010 | Homelite Expand - It Brushcutter...
How do i replace a shaft for ryobi whipper snipper
I never heard it called a whipper snipper before but I am on this side of the ocean. you should be able to go to www.ryobiuk.com. Put in your model number and you should find a parts list for it.
HTH
Good Day. mate
Oct 22, 2009 | Ryobi Garden
Homelite whipper snipper is hard to start and its new petrol mix is correct
I took mine back to Bunnings and the guy there said they had a number with this problem and have found that priming the bulb 20 times not 10 as per the manual, is the fix.
It certainly fixed mine
Sep 14, 2009 | Homelite Garden
Cord stayes out motor not running
Take it back to place of purchace.
We get these all the time if its the cheap bent sharft with starter between shaft and motor. the easy start spring gets jammed and needs replacing.
Dec 26, 2008 | Garden
Garden Logo
48 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
