Please help me! copier xerox dc 1080 code u9 error problem
  • 2072 Answers
SOURCE: Error code U9
That code normally means you need to do some cleaning to the machine. The majority of the time it is caused by High Voltage arching.
1. Open the right hand door. About mid way down you will see an opening with a very fine wire in it. just a little thicker than a hair. Take a Q-tip with some alcohol and clean that wire. Also gently brush that area BEFORE cleaning with a q-tip to remove as much ink frmo the channel as you can.
2. Towards the top of that door, there is a metal strip, looks like a saw blade, has triangular points on it. I would assume it is pretty black now and not silver. Take a brush and clean that. then gently take a cloth dampened with alcohol and wipe it , very gently until you get it reasonibly clean.
3 Remove the drum cartridge and look for all the contact points. Mostly the ones on the lower right side. Clean all the ink ( toner) from that contact area and look around for all the other contacts to that cartridge.
I would say there is a 90 percent likelyhood this is your problem.
Low line voltage and line spikes can cause this problem, But far less likely.
Posted on Feb 07, 2008
  • 2072 Answers
SOURCE: Error 3-397 Xerox DC 12
A 3- problem is a communication failure between the processor and one of the modules.
Other then a service call, switching the machine off, removing the power cord for about 2-3 minutes and returning power to the machine, there is not a lot you can do.
You could have just some software corruption that a complete power down would resolve. A connector could have become lose on between one of the modules and the main processor.
Or one of the boards itself is bad.
Once you power down and power up the machine, if that doesn't clear the problem, a service call is in order.
Can be a fickle problem.
Posted on Feb 22, 2008
checkitright
  • 1362 Answers
SOURCE: xerox 5328 copier error
U9-3
Xerographic process problem.
The Exposure sensor detected low Exposure Lamp intensity. Switch the Main Power Switch off then on in order to clear the Status Code. Go to the U9-3 Xerographic Process Problem RAP
U9-4
The Main PWB sensed that the Toner Dispense Motor was not running. Perform 20-3 U Codes Clearance . Go to the U9-4 Xerographic Process Problem RAP
U9-5
The CSDC zero point was too high during auto setup. Perform 20-3 U Codes Clearance . Go to the U9-4 Xerographic Process Problem RAP U9-5 Xerographic Process Problem RAP .
Posted on Aug 11, 2008
  • 2072 Answers
SOURCE: LSU error code
Do you have the old cartridge? Because the message you are getting makes no sense if you can copy and not print.
The chip on the cartridge may be corrupting the machine software.
I will explaine why I say this. LSU fault, is a failure of the laser unit within the printer/copier. If it had failed, you should not be able to copy or print, The machine should not function. The laser unit is what makes the image on the drum. So neither print or copy should work if that was a true LSU code.
Did you purchase a cartridge made by another company other than Xerox? If so try returning it.
As I say, an LSU code should make the machine totally unpoerable, not partially functional.
I would try the old cartridge if you have it to see what happens.
Let me know if you have tried swapping cartridges and I will look into this more for you.
Posted on Sep 17, 2008
SOURCE: xerox dc 12 copier system faulit 9-354
Hi ,
Sir I am have dc12 mech
its giving error code 9-354.
send me the solution as soon as posible.
Posted on Oct 27, 2008
Hi sir i have a xerox dc 12 giving error code 10-500 after replacing a new web cartridge
This code means that printer is not detecting the cartridge. you can try to to remove it and re seat it or it could be faulty, her is a list of all of the codes.
http://www.metrouk.co.uk/pdf/xeroxdc12faultcodes.pdf
Hope this helps.
Sep 16, 2014 | Xerox DocuColor 12 Printer
My xerox pro 420 have U9 error?
The U-9 code means the main control unit/switch board has a problem, replace the board.
Jan 22, 2011 | Xerox 1 YEAR ON-SITE SERVICE AVAILABLE ON...
Xerox dc 12 error code 9-357
9-357 Black Toner Dispenser Broken.
Dec 19, 2009 | Xerox DocuColor 12 Color Copier
Xerox u9-5 code on a 5028 copier
Hello sir; There is a reset procedure require;
hold down 0 while you turn on the power, then enter 20 press start enter 3 press start. turn power off and on.
Aug 19, 2009 | Xerox Office Equipment & Supplies
Paper Jam 8-112 when power on Xerox DocuColor DC 1250 Printer
You it is necessary to make sure visual(optic) to see the sensor(pick-off) of that node(knot;element), which(who) you is informed.Byvat that conk or клинят sensors(pick-offs) of the passing, electronics in this case her(its)(her) fault is practically excluded. Extremely(Most) seldom(rarely) such быват.I work(operate) 18 years I had 1 or 2 times, but only mechanical damages much(highly;very much) often were. The Sensor(Pick-off) conks or клинит, when remoove the stuck paper. I am simply(merely) run away that reason in sensor. Good luck you!
Aug 07, 2009 | Office Equipment & Supplies
WORKCENTRE PRO 420 U9 CODE
Hello sir; The U-9 code means the main control unit/switch board problem, replace it.
Feb 07, 2009 | Xerox WorkCentre Pro 423 Copier
Rank xerox 5328 U9
if its a u9-1 code it is the lamp that is faulty. Sometimes it can be the connections either end of the lamp but normally the lamp itself. It will probably cost as much to fix as it would to get a new one to be honest
Nov 03, 2008 | Xerox 5830 Copier
Xerox 5328 copier error
U9-3
U9-4
U9-5
Aug 09, 2008 | Office Equipment & Supplies
44 people viewed this question
jasbo
jasbo
