Question about Sanyo PDP-32H1A 32 in. Plasma Television
Sanyo PDP - 32XS8DA Won't power on - red indicator turns blue when pressing "on' button (remote) - after 5 secs goes back to red.
  • Sanyo Master
  • 6,993 Answers
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board.
I do not think it needs replacement, rather some defective capacitors are causing this issue.
Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes)
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors).
After replacing these capacitor(capacitors) most likely the normal operation will be restored.
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
I hope this helps.
Posted on Jan 01, 2011
  • max perron Oct 15, 2012
    100% fix .two bulged capacitors sighted. fitted 2 new ones for $2. you are an legend thanks
Find activation code for pioneer
My pioneer 5020FD Kuro tv. when I plug power to the unit, a blue light blinks 8 times pause 2 sec. and blink 8 times repeating this and if i press power button it clicks red light and makes a clicking sound and goes back to the blue light blinking again, it did this once before and the picture came on fine until i turned it off and now it just blink the blue code.
Dec 10, 2014 | Pioneer PDP-5020FD 50 in. Plasma HDTV
PDP-4340HD keeps turning off.
Continuous blinks of standby light indicates a fault in the IIC data bus. The main board is likely to be faulty. If you wish to know more Check this link.
Feb 03, 2013 | Pioneer PureVision PDP-4340HD 43 in....
WHEN I TURN ON MY SANYO 32xs8da stand by light flashes
Check the power supply for a couple of bulged caps that need replace, or just replace the power supply module.
Mar 04, 2011 | Sanyo PDP-32H1A 32 in. Plasma Television
How can I get the 3-digit device code for a Sanyo TV Set? I lost the list!!
Hello
Three digit universal remote code for Sanyo are:
004/ 013/ 049/ 108/ 110/ 180/ 209
Four digit universal remote codes for Sanyo are:
0049 0097 0110 0004 0268 0012 0108 0180
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
OK.
Feb 20, 2011 | Universal Remote Control Remote Control
WHAT IS CODE FOR TV SANYO?
Hello
If you wants to get into the service mode of Sanyo TV. do one moung the folloing procedure. If you are in need of universal remote code for Sanyo follow the extented solution. Your post is not clear, that is why I answers for both.
To get in to the service mode adjustments
[1]
Unplug the power cable.
* Press and hold the {MUTE} button on the remote control while plugging the power cable back into the outlet.
* Keep pressing the {MUTE} button until the TV powers on with the Service Menu displayed.
* Use the {CH+} {CH-} buttons to select menus.
* Use the {VOL+} {VOL -} buttons to change settings.
* Some menus might have sub-addresses. Use the numeric buttons {0} to {7} to adjust sub-item data.
* Press the {MENU} button or turn the TV off to exit.
[OR]
* Press and hold the {VOL -} button on the TV
* Keep pressing the {VOL -} button until
Universal remote codes:
Three digit universal remote code for sanyo are:
Four digit universal remote code for Sanyo are:
Direct Code Entry
OK.
Jan 25, 2011 | Televison & Video
How do i program my ge remote to my sanyo tv
1. turn on device
2. press setup (underneath on/off) till red light stays on the take finger off the button
3. press and quickly release device button (tv,vcr,etc.) the red indicator blinds off once
4. press the on/off button (up to 300 times) until the device is to be controlled turns off the red light blinks off with each button press
5. press and release enter to install code
Sep 14, 2010 | GE JASRM24912 Remote Control
How do i program a wii controller
Under battery cover on wii remote is a little red button. Under disc slot is a little flap where sd card goes in, next to this is a red square button. Press both red buttons at same time for 5 secs. Blue lights on wii remote will flash and everything will be fine.
Dec 02, 2008 | Nintendo Wii Console
Supertooth one user manual
Charge your Supertooth one via the car charger or by attaching a usb/mini usb cable to your computer usb port. Need to charge for 4-10 hrs. Indicator light glows red (needs charging), orange (charging) or green (charged)
Power on: Press green button for 1 second. Indicator light blinks blue. A beep will be heard
Power off: Press green button for 1 second. Indicator light turns red. A beep will be heard
To pair with your mobile phone:
1. Press green button on Supertooth for 5 secs until indicator light blinks red/blue 2. Access bluetooth menu on your phone. Turn bluetooth on. Execute a bluetooth search. 3. Select ST ONE from list 4. When phone requests password enter 0000 and press OK 5. The handsfree kit is now ready for use 6. Clip Supertooth on sun visor of your car so that the microphone and control buttons are directed towards you.
To make a call: Dial number on phone. Supertooth will automatically connect. Indicator light is steady blue during call
To end a call: Press red button for 1 second
To answer a call: Press green button for 1 second. The bluetooth indicator will turn a steady blue.
To increase/decrease volume. Press volume buttons repeatedly up or down. They are situated between red and green buttons.
Hope this helps.
Nov 22, 2008 | Cell Phones
Sharper image universal remote
1) Turn on TV;
2) Press TV on the remote control;
3) Press and hold SETUP, until the red LED indicator blinks twice;
4) Enter 9-9-1-1 on the numeric keypad;
5) Press POWER on the remote;
6) If the TV doesn't respond, repeat #3, #4, #5.
Feb 17, 2008 | Televison & Video
Open Questions:
See all Sanyo PDP-32H1A 32 in. Plasma Television Questions
Sanyo PDP-32H1A 32 in. Plasma Television Logo
309 people viewed this question
Top Sanyo Televison & Video Experts
 Grubhead
Grubhead
Are you a Sanyo Televison and Video Expert? Answer questions, earn points and help others
