The lid of my hitachi fully automatic washer model SF-70EJ does not open the following lights blink- spin and water level. please tell how to open the lid.
3 Suggested Answers
ginko
  • 19396 Answers
SOURCE: my washing machine hitachi make model no SF-70EJ
Hi.
Most spin problems are consequence of drain system faults.
The first part to check is drain system. Check the drain hose at the back and the drain filter attached to the pump. See article at the end for more detail.
Most machines' timer boards do an additional check on the lid switch before starting the spin part of the cycle. If the lid lock light is flashing and the machine does not spin the lid switch is probably defective.
The lid switch is tested jumping its contacts or reading Ohms at switch terminal. A two-terminals switch must read continuity (low impedance) when door is closed and must read open (infinity of Ohms) when door is open. If the switch is a three contacts, the third contact is called "heater". In that case there must be continuity between the three contacts with lid closed. If the model instead of a simple switch uses a wax motor, then the lock cannot be tested by jumping contacts. The lock motor must be tested reading Ohms and checking that impedance is the same as indicated in service manual.
If lid switch and drain system are OK, then the pressure switch must be tested.The pressure switch detects the water level and among other things determines when to advance the cycle to spin.
If all the above is OK, then the motor and motor control unit (if present) must be tested.
Please read the solution in the article below for more:
If you have no spin ...
You can find parts and diagrams for most appliances using the links listed on this page: Where do I find parts and diagrams for my appliance?
Regards.
Ginko
Posted on Sep 04, 2011
probro12356
Where can I get hitachi fully automatic washing machine sensor in Kolkata???
Posted on Mar 20, 2015
A GE stackable washer/dryer that is stuck on spin?
Good Day,
your machine is normal is washing cycle?
if yes.do the same
for the fully automatic washing machine mostly have drain pump, please check the filter of your drain pump, if clog your drain pump of some hair pins,cotton buds or coins or any small item,that the cause of water stuck,and it will long time draining or totally not running the drain pump.and its cause of stop of cycle of washing machine in rinse time or spin time,because after washing the pump must be on to remove water before start the next cycle.
Nov 02, 2013 | Washing Machines
My washing machine hitachi make model no SF-70EJ having problem with spin please give assistance what to do
Hi.
Regards.
Ginko
Sep 04, 2011 | Washing Machines
Hitachi washing machine. Model:SF-P90DJ Fault code F9
my hitachi model SF-120 HJ is washing machine cleck c2 n c4 warning stop f9..........
Jul 29, 2010 | Washing Machines
Kenmore washer Model# 11024642300
Dear Customer
Please perform the following checks
Does it drain and spin if not lift the lid and close it slowly did you here a click? no click check lid switch. if it drains but wont spin and the motor is running most likely a bad motor coupling. fills and nothing but it dose drain and spin look a the water level switch. need more info model # Please rate this,Thank u
Dec 16, 2008 | Kenmore 24032\24036 Top Load Washer
Washer will not spin or completely drain
you could have problem with door lock. or lid switch. this part senses if the door is close.
if it is not functioning, it would interpret it as an open door and will not spin.will not drain either.
tnx 4 using fixya,
drcool
Sep 23, 2008 | Washing Machines
Sears 110.23812100 washer leaks when spinning
There is a pause after the pump out that shift the tranmission into spin also if you open the lid the unit will go into spin before it pumps out completely . They have since fixed this issue...The newer models work offf the pressure switch to tell the unit when to go into spin only after the water level switch is open telling the machine there is no water left in the unit
May 28, 2008 | Washing Machines
Hitachi SF-H900TPX Washing Machine not working properly
Open machine's service panel and check whether the motor spins. Let us know with your results and we will see how could we assiste you further.
Aug 31, 2007 | Washing Machines
Door Lock Clicks/Makes noises Washer does not agitate/spin
Sounds like very worn motor brushes to me, as its trying to turn the drum but has'nt the power needed to maintain any momentum,and the blinking door light is because of the bad cotact from brushes to motor.About £20 for a set of brushes or get an engineer to fit new brushes,but get a price first.
Apr 18, 2007 | GE WSXH208A Front Load Washer
Washing Machines Logo
59 people viewed this question
Top Washing Machines Experts
