Question about British Telecom BT Freestyle 7100 Cordless Expansion Handset
I can not recive calls or make calls the line is dead I have checked everthing and I can get broardband
I had the same problem when I purchased a 710 for my mother in law. Worked in my house but not hers. The phone does not come with a BT box to phone connection line so that was a clue. Through a process of elimination I discovered that her connection line did not work with the 710, although it was ok with her old phone! I purchased a BT to RJ11 line extension lead from Maplins - all is now ok. I can only assume older connection leads are different than newer ones!
Posted on Jan 30, 2011
My phone line is ok as i have sent and recived phone call using a plain ordinary telephone however i cant send or recive faxs. if anyone has any ideas i would be greatful
If your fax machine has a handset pick up the handset and see if you get "dial-tone" thro the handset of the Fax machine. If you don't then you may have lost the (NCU) pcb, You should always install a fax machine on a "surge-protector" to protect both the Hydro and the Fax line. **The silly thing to check is to make sure the fax line is being plugged into the "line" plug on the back of your machine.
Sep 02, 2010 | Office Equipment & Supplies
No ring tone. Can't make or recive a phone call
check the cable has been put in the line socket on the fax and not the tel socket as this is a common mistake and that will stop you getting the ring tone]
Feb 09, 2010 | Sharp UX-P115 Plain Paper Thermal transfer...
I cannot receive calls from land lines, only other mobiles.
go to the calls setting then find calls recive option and turn it to recive from all i think it is seted on recive only from contacts if not solve then tell me again.thats it
Nov 04, 2009 | Sony Ericsson K800i Cellular Phone
What do you need to connect xbox 360 to laptop got a router do i need a modem and a adsl line as the laptop is wireless broardband.
you must have a modem and a dsl line..
connect the dsl line to the modem..
then modem to router...
router to xbox..
throught LAN connection..
Oct 25, 2009 | Computers & Internet
My cell phone battery is dead but when people call it, it still rings? why is that
ur battery might have sum charge
if u dont want to recive calls switch ur phone of or remove battery
Sep 26, 2009 | Cell Phones
I cant recive nor send mms messages
call your carrier and tell them you need your new phone configured. they'll send a few texts to it and it'll be done.
call from another line if you can when you do this.
good luck
Jun 12, 2009 | Dual Electronics N99i Cellular Phone
Sky broardband router
NOPE, you don't need to buy another one. It will work on ANY high speed connection in the world.
Feb 18, 2008 | NetGear DG834G Router
Telephone connection problem with DSL
unplug everthing from all jacks in the house. call your # a couple of times. if the line rings, plug everything in 1 at a time, but call again after each hook up. if the line goes dead or is busy, that phone you just plugged in is the problem. [ a short in the phone, computer, answer machine, or any piece of equipment plugged into the phone line.] if the line is busy when everything is unplugged, call your phone company. there maybe a problem with your inside wire.there also maybe a box [called a nid] inside your basment/garage or on the side of your house, where you can plug your phone directly in, bypassing all the jacks in your house
hope this helps.
wg
Feb 13, 2008 | Lands Phones
Can't make or recive calls
here is link to the instructions
http://www.uniden.com/products/productdetail.cfm?product=TRU8885-2
first, test the actual socket using a good normal phone.
if no dial tone, get phone company to test the line.
if line ok, fully charge handset for 10 hours, if still faulty, follow the procedure to de-register and re-register your handset with the base unit.
Jan 17, 2008 | Uniden Cordless Phone
Calls
check at top of ur lcd if there is writen L2 then ur mobile will not recive or make call change it to line L1 will ok.
Mar 11, 2007 | Motorola Mobility RAZR V3
British Telecom BT Freestyle 7100 Cordless Expansion Handset Logo
226 people viewed this question
Top British Telecom Lands Phones Experts
David Burbee
David Burbee
Andrew Taylor
Andrew Taylor
Are you a British Telecom Lands Phone Expert? Answer questions, earn points and help others
