Question about Yamaha Music
Half of the display is unreadable. The right half shows vertical lines.
  • Yamaha Master
  • 5,603 Answers
Somewhat common problem. The LCD needs replacing. If under warranty do so immediately.
Posted on Jan 01, 2011
  • marten_lundg Jan 02, 2011
    OK. How do i take the instrument apart to replace the display?
    Its a DGX-620. There is a lot of screws undeneath, how many of these has to bee removed?
The chords i strum dont show on display or sometimes the strum bar dont match up
are you in "A" _ 440? digital tuners are set in a440 as a default. if your playing chords and are down half a step. Or improperly tuned (ie: your intonation is out?) I assume you are playing guitar? then it would have trouble picking up proper signal. - if this answer doesnt help. try more specifics. what are you playing ? what display are you referencing. etc. Good luck!!
Apr 23, 2015 | Music
Mm6 dark screen
only few technician could do some repair with the screen card or the connections fron screen to cards very complicated usually the screen goes off totally only few could do it luckily by chance.
you need to change the screen i suppose
Aug 30, 2012 | Yamaha MM6 61Key Synthesizer Keyboard
Broken sitar tuning peg
by now I hope you've bought or made a new peg. with any tension on it, the splintered wood, broken at an angle, won't hold long enough to tune the string. either make one out of a dowel rod, with the tapered end sanded to fit tightly, or use a brand new one made of plastic.
Aug 06, 2012 | Mid East Sitar Sympathetic Tuning Peg,...
DGX620
If the backlight is on and just half of the display data is there, it is probable the conductive strip has come away from the display or the contact portion of the board where the conductor strip lays on the circuit board.
If it is under warranty, contact Yamaha. If it not under warranty, you can try to fix it, but once adhesive lets go, it is diffeicult to get them to premanently readhere. A repair shop that is Yamaha authorized is able to get the New parts from Yamaha that fit.
Apr 10, 2012 | Yamaha 88 Key Portable Grand w/stand
I have annew yamaha mm8, it's showing only half screen, how can i repair it ?
Since it is brand new, IMMEDIATELY exercise your warranty rights as the LCD will probably have to be replaced.
Dec 26, 2010 | Yamaha MM8 MUSIC SYNTHESIZER
I don't no how to record in split layer. And do I twerk this keyboard
I don't know what you are using to record with but if you are recording audio try sending half of the split right and the other half left or use two separate channels to record each half. Mix as needed. If you are recording midi using a DAW assign each half of the split to a separate midi channel and assign the receives to separate channels in your DAW. If you are recording onboard your manual should have the solution and you might just have missed it so far.
Oct 25, 2010 | Roland FANTOMG8
Yamaha YPG625 screen shows only vertical lines
I brought the keyboard into a local service technician. He told me that he had to remove about 50 screws but the solution was simple. He unplugged and reconnected the ribbon connector. It apparently was not making good contact.
Oct 02, 2008 | Yamaha Full-Size Keyboard
Music Logo
116 people viewed this question
Top Yamaha Music Experts
Matthew Spark
Matthew Spark
Mike
Are you a Yamaha Music Expert? Answer questions, earn points and help others
