Question about ASUS P5LD2 Deluxe Motherboard
Asus p5ld2 deluxe ranlike a champ until I added 2 additional 1gb sticks of RAM itbeeps whenthe power is turned on but will notboot
  • Jeffrey Groves
    Jeffrey Groves Jan 01, 2011
    What is the make and part number of the 1GB sticks of RAM that you added?
    Genius:
  • ASUS Master
  • 1,274 Answers
It doesn't like the ram obviously,
  • 240-pin DDR2 DIMM Banking: 4 (2 banks of 2)
  • Chipset: Intel 945P
  • DDR2 SDRAM Frequencies: PC2-4200 and PC2-5300
  • Error Detection Support: Non-ECC only
  • Graphics Support: PCI Express x16
  • Max Component Density: 1024
  • Max Unbuffered DDR2 SDRAM: 4096MB
  • Module Types Supported: Unbuffered only
  • Supported DRAM Types: DDR2 SDRAM only
  • USB Support: 2.x Compliant
  • make sure you installed the correct speed of ram, secondly if the ram speed is correct take out one sitck at a time, and try to boot, it's possible that one is bad from factory.
  • Posted on Jan 01, 2011
    Increase ram on p4p800-delux I865PE DDDR
    Go to this website: http://www.crucial.com/store/listparts.aspx?model=P4P800%20Deluxe&Cat=RAM and order the 2 sticks (1 order = 2 sticks). Replace your current two sticks. Don't use your old ones.
    Oct 22, 2012 | ASUS Computers & Internet
    Will Asus p5ld2-vm SE MOTHERBOARD support 1 tera-byte hard disk? i hav 2gb ram
    Yes it should. The issue is not so much with the motherboard supporting the hard drive. It is more the question of whether or not the power supply will support the power required to run it along with all of the other additions.
    Jan 03, 2010 | ASUS P5LD2-VM Motherboard
    How do you install 4 sticks of ram? I have 2x 512mb and 2x 1gb. Do I put the pairs in the same color slots?
    Yes, there are 4 slots, two colors....put the same ram configuration in the same color. RE: 1 GB sticks go in one color, 512 MB sticks go in the other.
    Oct 25, 2009 | ASUS A8N-SLI Deluxe Motherboard
    Problem adding Additional Ram to my Asus A8N SLI DELUXE system
    Just because BIOS is recognizing the RAM doesn't necessarily mean it is usable. Also, ASUS recommends that you have the same amount of RAM in each bank. Another point they make is that your motherboard does not support double-sided DIMM chips.
    I would refer to the manual for their specific instructions on proper RAM configuration:
    http://dlcdnet.asus.com/pub/ASUS/mb/socket939/A8N-SLI%20Premium/e2435_a8n-sli_premium.pdf
    If you are concerned that the memory stick might be bad, swap it out with one of your older ones, and see if your system boots and performs as it should. If not, then you know it is bad. My guess is that if you populate the memory slots with 4 gb, the system will recognize and make all of it available to you.
    Cheers
    Nick
    Jan 08, 2009 | ASUS A8N-SLI Deluxe Motherboard
    MOTHER BOARD DRIVERS
    All drivers are available here but chose your OS & download
    http://support.asus.com/download/download.aspx?modelname=P5LD2%20Deluxe&SLanguage=en-us............sodeep
    Jul 01, 2008 | ASUS P5LD2 Deluxe Motherboard
    My Asus mobo P5ld2 cant turn on
    Did you try to unplug all AC Power; remove internal surface battery; and then jumper the 'reset' pins from 1-2 to 2-3 ? Leave in this state for about 5 minutes- then replace battery; re-jumper back to pins 1-2- replace AC power cord. Sometimes wiping out the BIOS setup information and restarting/re-setting it up will do the trick!
    Apr 12, 2008 | ASUS P5LD2-VM Motherboard
    Upgrade from 512MB to 1GB
    The specs on the memory are correct, so you purchased the correct type of memory for this motherboard. If your getting no video when you power on with the 1gb stick, I would be willing to bet the 1gb stick is bad. Can you return it and try another stick?
    Mar 15, 2008 | ASUS P4B266 Motherboard
    Motherboard ASUS P5RD1-VM ram problem
    More people should complain with Asus support. Checking Asus forums, you'll find there's an obvious problem with a PCI-E video addon + 2 used memory slots. In my case, I had 2Gb (1 + 1), mb with bios version 1104, and it worked fine; when I installed a new PCI-E card, the system was very... very sluggish. Now I have uninstalled 1 memory, I'm using only 1Gb of RAM with the PCI-E card, and it's working well.
    Again: checking Asus forum, this is a reported problem, and a bios bug... Asus should release a new bios version, but they seem not to bother, as this is a relatively "old' mb...
    Feb 16, 2008 | ASUS P5RD1-VM Motherboard
    Slow data transfer rate
    Do you have this Bios version? P5LD2-VM BIOS version 1303
    Support new CPU's. Please refer to Asus website at: http://support.asus.com/cpusupport/cpusupport.aspx
    Your board came out around June-2005 so improvements are here. I'm not saying its all about the CPU & FSB but it may help.
    Jan 27, 2008 | ASUS P5LD2-VM Motherboard
    Asus p5ld2-wm and coroe
    Sounds like a RAM or power supply problem to me, check the ram... even if it is brand new
    Aug 21, 2006 | ASUS P5LD2-VM Motherboard
    ASUS P5LD2 Deluxe Motherboard Logo
    76 people viewed this question
    Top ASUS Computers & Internet Experts
    David
    David
    Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
