Question about Hitachi 65S700 65" Rear Projection HDTV
Double focused, red and green, bow in picture top and bottom
Hitachi 65inch projection HDTV.6 years old. The picture is double focused with green and red around everything and there is a bow in the picture at the top and bottom in the middle of the screen.
  • Baluka Jul 08, 2008
    Thank you for your quick response. I know it's not the auto focus cause i tried that and it did work but the problem was still there. I know nothing about tv's so i will pass on your suggestion to a friend who does know tv's and is coming out thursday to take a look at it.
  • 58 Answers
Hi
You have a convergence problem
If the set has auto focus and will not complete its cycle.
The Auto focus module is bad, (expensive)
If it completes and the problem is still there.
Then check for bad conv. drivers (stk****) or cold solder joint on one or more of the 3 drivers pins.
Guy9
Posted on Jul 08, 2008
Hitachi projection tv 53uwx10ba - the Convergence ICs were replaced. When the PDKP bridge between convergence board and 2nd board is plugged in, it makes a noise. Kept that unplugged, the picture is...
Did set have this problem before you replaced the STKS?
I know these sets very well. If problem is different in any way from before you replaced chips.......double check all soldering or one of the new chips may be defective.
The more you tell me the better I can help.
regards, SD TECH
Aug 18, 2010 | Hitachi 53UDX10B 53" Rear Projection...
Akai model pt5598hdx/sms
it would sound like your convergence amp power board has failed at the shop we would replace then it would need a serviceman alignment
Jun 17, 2009 | Akai PT5598HD 55" Rear Projection...
Hitachi ultra vision green and purple double vision picture about
Convergence is out, need convergence board repaired, usually bad stks, 392-110s
Jun 07, 2009 | Hitachi 60V500 60" Rear Projection...
I have a double picture on my 6 year old Hitachi Projection tv.
Required info are available in service manual with details and schematics.
You can buy service manual from Manual Zone for your Hitachi 51F500 TV.
Thank you.
Dec 11, 2008 | Hitachi 51F500 51" Rear Projection...
Double image/ out of focus with green and blue seperation
Your tv is crt-based and is out of convergence. In other words, the settings for keeping the Red, Green and Blue images aligned have drifted and must be reset. This is common with CRT projectors and CRT rear projection tvs.
Refer to your owners manual for instructions on re-aligning it.
Apr 18, 2008 | Hitachi 51UWX20B 51" Rear Projection...
53swx10b bowed picture
Double check your work for errors such as solder bridges or incorrect resistor placement. Look carefully anywhere solder could have dripped or splattered to cause the bowing. If you entered the digital convergence mode to touch it up, you will have to re initialize the magic focus for it to function. Good luck
Mar 12, 2008 | Hitachi 53SWX10B 53" Rear Projection...
Out of focus
Rach, if it doesn`t move from green to red to blue in Magic Focus then there is a problem with the convergence IC`s and probably one or more support resisters. These components will have to be replaced, questions? ask away, BMW Rider
Dec 14, 2007 | Hitachi 57F500 57" Rear Projection...
Hitachi 61SDX picture got dim shows Code 3
use the advanced options page and reset the factor blue and red convergence defaults then do re apply the auto color defaults color at first it seemed very red (which is good because red was the missing factor in the green picture) but after reseting all the color and tints to the normal ranges I then reset the color auto correct again and all seems fine.
Nov 17, 2007 | Hitachi 61SDX01B 61" Rear Projection...
Rca d52w2052 d523c10df itc222
The issue is the Deflection board. The Fl1231 is open. The Deflection board needs replaced
Nov 11, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
Hitachi 65S700 65" Rear Projection HDTV Logo
268 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
