Question about Motorola Cell Phones
INCOMING IS THERE. NO OUTGOING. WHEN DILLED AND PRESSED A NUMBER MESSAGE IN THE SREEN IS 'CONNECTED'. BUT ACTUALLY NOT CONNECTED. MESSAGES SENT ARE FAILED TO SEND.
  • 384 Answers
May be your balance is low
or
you sim validity is over .
Posted on Jan 01, 2011
Able to recieve text messages but unable to send text messages
You need your message centre number for outgoing text messages. You can find the number by going on your networks website or by phoning you networks customer services.
Hope this helps and please rate
Mar 19, 2011 | HTC 7 Mozart Cell Phone
How to record Outgoing Message on Answer machine of BINATONE FUSION 2210 DECT phone? Thanks
hi,
if you want to record outgoing message on Answer of BINATONE FUSION 2210 DECT phone, his the step you will follow.
to turn A/M on press R then 5.
to turn A/M off press R then 6.
if you want to record Outgoing Message, press R then 1.
After beep record your message.
Press 0 when you have finished your message, then C to return to standby mode.
To listen to incoming messages, press R then 8.
New messages are then played back.
Press 4 to delete message.
thanks for using fixya
Jun 05, 2010 | Lands Phones
Email settings
you must have email account, also the POP address, and the SMTP with your username and password ready
Set up email account
1. Select Menu > Messaging > Email > Settings > New account > Add.
2. Enter a name for the email account, for example, Home or Office. Select OK.
3. Select Connect using > Edit and select the data account you created earlier to use with this email
account.
4. Select Email address > Edit. Enter your email address. Select OK.
5. Select Connection type > Edit. Select POP3 or IMAP4. POP3 is the most common.
6. Select Incoming server > Edit. Enter the name or the IP address for the incoming server. Select OK.
7. Select Username > Edit. Enter the incoming server username. Select OK.
8. Select Password > Edit. Enter the incoming server password and select OK. Leave this blank if you
want to be asked for the password each time you check new mail.
9. Select Outgoing server > Edit. Enter the name or the IP address of the SMTP server you use to send
email messages. Select OK.
10. Select Advanced settings.
11. Select Your name (not mandatory) > Edit. Enter your name and select OK. This will appear in outgoing
email messages.
12. Select Signature (not mandatory) > Edit. Create a signature to add to your email messages and
select OK.
13. Select Download S&R. Choose what to download when receiving new email messages:
• Subjects only – receive information such as sender and subject before downloading the whole email.
• Up to size limit – receive the whole email. Select Size limit to set the maximum size to download
when receiving new email messages.
• Subjects & text – Only for IMAP4 users. Receive the subject and text but not attached files.
14. Select Check interval (not mandatory). Choose how often you want the phone to connect to your
email server and check for incoming email messages.
15. Select Push email. Only for IMAP4 users. Select On for full email notification functionality or Off to
disable the functionality. See Using push email for full email notification functionality on page 7.
16. Select Allow connection > Edit. Select Any network or Home network.
17. Select Copy outgoing (not mandatory) > Edit. Select On if you want email messages sent from your
phone to be sent to an additional email address of your choice. This way your sent messages are
copied and can be saved for future reference.
18. Select Encryption > Edit. Choose whether your email messages should be encrypted.
19. Select Outgoing. username. If requested, select Edit enter the outgoing server username.
20. Select Outgoing. password. If requested, select Edit enter the outgoing server password.
21. Select Incoming port. If needed, change the port for the protocol you are using.
22. Select Outgoing port. If needed, change the port for the SMTP protocol.
and the other is
To write and send an email message
1. Select Menu > Messaging > Email > Write new.
2. Select To: to add recipients and select Add. There are three ways to add an intro sentence:
• Select Enter email address. to enter an email address.
• Select Contacts look-up to retrieve a recipient from Contacts.
• Select an email address from the last used recipients.
3. To add more recipients, select To: > Edit select Cc or Bcc and select recipients to add. When finished
selecting recipients select Done.
4. Select Subject: to write the subject.
5. Select Text: to write the text.
6. Select Attachments: and select the attachment to add. Add more attachments the same way.
7. Select Continue.
8. Select Send to send the message or More to view options.
To receive and read email messages
1. Select Menu > Messaging > Email > Inbox.
• Select Send&rec when the inbox is empty or
• Select More > Send & receive to download new messages.
2. Select a message and select View to read it.
To reply to an email message
1. Select Menu > Messaging > Email > Inbox. Select an email message in the inbox. Select More
> Reply and select:
• Yes – to include the original message in your reply or
• No – to exclude the original message.
2. Write your message select OK > Continue.
3. Select Send to send the message or More to view option
Mar 08, 2010 | Sony Ericsson W350A Cell Phone
Samsung Impact pnone. Cannot send a text message. When I try,an error comes up saying "network settings unavailable". Incoming and outgoing calls work, as well as incoming texts. In the messaging menu the...
go to message setting, text message, text meassage center, then try changing to another center, ( i've got 3 dif centers to pic from but only the first one lets me send text messages)
good luck
Jan 18, 2010 | Samsung Cell Phones
I have not been able to "send" ANY MESSAGES since last night. I can receive messages but not SEND. It is almost 4:00 and I still cannot find ANY HELP FROM YAHOO. the message that pops up when it is...
  1. From the Tools menu, choose "Accounts."
  2. Select the "Mail" tab.
  3. Click the "Add" button.
  4. From the Add menu, click "Mail."
  5. In the text box labeled Display Name, type your name and click "Next."
  6. In the Email Address box, type your Yahoo! Mail address (be sure to include "@yahoo.com") and click "Next."
  7. Under "My incoming mail server is a…" select "POP3."
  8. Type "plus.pop.mail.yahoo.com" in the Incoming Mail (POP3, IMAP, or HTTP) Server box.
  9. Type "plus.smtp.mail.yahoo.com" in the Outgoing Mail (SMTP) Server box.
  10. Click "Next."
  11. In the Account Name box, type your Yahoo! Mail ID (your email address without the "@yahoo.com").
  12. In the Password box, type your Yahoo! Mail password.
  13. If you want Outlook Express to remember your password, check the "Remember password" box.
  14. Do not check the boxes labeled "Log on using Secure…"
  15. Click "Next."
  16. Click "Finish."
  17. Select 'plus.pop.mail.yahoo.com' under 'Account,' and click 'Properties.'
  18. Click the “Servers” tab.
  19. Under “Outgoing Mail Server” check the box next to “My server requires authentication”
  20. Click the 'Advanced' tab.
  21. Under “Outgoing mail Server (SMTP)”, check the box next to “This server requires a secure connection (SSL). Enter port number “465” in the “Outgoing mail (SMTP)” field.
  22. Under “Incoming mail (POP3)”, check the box next to “This server requires a secure connection (SSL)". The port number in the “Incoming mail (POP3)" field should automatically change from 110 to 995. If it doesn’t, make sure the port number is set to 995.
Mar 13, 2009 | Computers & Internet
Outgoing message does not go with Outlook 2007
It sounds like your SMTP settings are incorrect, if you are using a POP3 service, it can connect and download your email, but most ISP Mail SMTP servers dont allow outgoing mail from another ISP.
Example, I have a charter.net email account but I have wireless hometown as my ISP, so I have to set my POP3 settings to my charter.net account (incoming messages) and my SMTP settings to wireless hometown smtp server for (outgoing mail)
Mar 10, 2009 | Microsoft Office Outlook 2007: Windows
Mail sending problem in outlook express 2003
Tried to take backup of messages was not able to copy the dbx files
- Rename folders.dbx
- Was able to send/receive messages without any error
May not able to retreive some messages in sent items, deleted items folder
>lets create new identiy
http://support.microsoft.com/kb/209169
Dec 06, 2008 | Microsoft Office Outlook 2003 for PC
Can't sent text message
This is a common problem. Contact your SIM card service provider and ask him that the message center number. Note it down the message center number. Go to message settings in your mobile and go to message center and type that number and save it. Switch off and switch on your mobile once, and try sending messages. Hopefully it should work. Thank you.
Sep 06, 2008 | Sony Ericsson J230i Cellular Phone
Messages not sending
Check Setting - Message Center Number is the problem, must be correct.
Jun 18, 2008 | Nokia E50
Cell Phones Logo
18 people viewed this question
Top Motorola Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Motorola Cell Phone Expert? Answer questions, earn points and help others
