Question about New Home 104D Mechanical Sewing Machine
New Home LOCK 778
New Blades required where are they obtainable
  • 323 Answers
Any sewing machine store should have or be able to obtain these blades for you. You should only need one because one of them is a carbide steel blade(Very Hard). It will have a dark color on the cutting part of the blade.Replace the other one.
sewman7
Posted on Jul 10, 2008
I have a Baby Lock BL4-736D serger. I need the cutting blades replaced. Can I do it myself??
Yes and the instructions are in the book that came with your machine, and there may have been an extra blade with your machine when you got it.
Apr 20, 2017 | Baby Lock Sewing Machines
Overlocker the blades wont cut where can i but new blades
You may be able to find a replacement blade. Search the internet for:
Make + Model + the word "blade"
or contact manufacturer support.
Most of the time, only one blade can be replaced by a lay person. The other blade requires some technical skill (to assure accurate placement and timing), so you will most likely need to take it for service. Consult your owner's manual.
Apr 23, 2016 | Sewing Machines
I know how to open and get into my Designer Se and found the blade in part broken and not able to see hoe to reinstall the new one I have
Am guessing this is a serger. There are usually two blades in a serger (overlocker). Usually one blade can be changed by the home user, the other blade sometimes requires a technician.
Consult your owner's manual. It may have specific instructions about replacing the blades.
Nov 12, 2015 | Sewing Machines
Where do I put the oil in my overlocker?
You don't specify the make/model - it is always best to obtain a manual for you rmachine to ensure that you are oiling in the necessary spots to ensure longevity.
Generally though, you would open up the front flap/s of your overlocker and brush out around the lower loopers and blades to remove all the lint build up before starting a new project. Then add a drop of oil to any of the metal on metal moving parts in this area. The blades also benefit from a small drop of oil.
Try sewusa.com for sewing machine and overlocker manuals.
Mar 04, 2011 | Sewing Machines
Husky lock 509. My machine does not cut . There is something wrong with the blades
Be sure the blades are "raised" properly - did you have them lowered so you could sew without cutting? Maybe they are not locked back in place. Is the machine set for rolled hem? Re-set it for regular overlocking. Even if the blades were blunt, you should still be getting some sort of cutting happening. Blades are reasonably easy to replace yourself but getting hold of replacement blades can be tricky.
Oct 11, 2009 | Husqvarna Sewing Machines
New Home SR2100 manual
Janome Dealers should be able to get this manual for you.
sewman7
Dec 27, 2008 | Dual Sew 2100 Mechanical Sewing Machine
Need replacement cutting blades on my simplicity serger easy lock 804
Allbrand.com or go to Google, type in: "Replacement blades for a serger". Hope this will help. I have the same serger. --Tricie
Jan 05, 2008 | Simplicity Serge Pro SW432 Mechanical...
New Home 104D Mechanical Sewing Machine Logo
110 people viewed this question
Top New Home Sewing Machines Experts
Tally Girl
Tally Girl
Nava Hirshenson
Nava Hirshenson
Level 1 Expert
Are you a New Home Sewing Machine Expert? Answer questions, earn points and help others
