Question about Ricoh Caplio R4 Digital Camera
My computor is Vista and I cannot connect my R4 CAMERA TO IT
Trying to transfer pictures from camera to computor but unsuccessful. windows vista is operating system. please advise
Consider NOT connecting the camera to the computer.
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive. Or you can use any photo cataloging program.
Nov 15, 2010 | Vivitar ViviCam 4345 Digital Camera
How can i download my picture in camera to a computer
Does your camera have a USB port if so connect cable to computor & switch on camera your computor should recognize a new hardware device and a pop up box will appear giving you the option ofimporting your pictures.Or take memory card out of camera & plug into a card reader then into usb port on computor,If you are using windows click on my computor & click on icon for the memory card & choose copy.
Aug 13, 2010 | Canon Cameras
Transfer problems
Do what the pros do...use a card reader.
Apr 22, 2010 | Nikon Coolpix 5700 Digital Camera
Can not connect camera on to computor
I would make sure I had enough system resources to run the program check to make sure you aren't having a problem with the driver for the camera software it may need updating in order to properly work. you can uninstall the provided software and reinstall it. Also try connecting the camera before you turn on computer (NHW) should recognize and notify you that new hardware has been found have your disk ready and let your new hardware wizard guide you through the rest of setup. you can always ask me to further assist you good luck and much success. wutxtye0rjd9d9ekmodqt1eoxkvn9hr9qjz1l3dabggyud7sdgr36czsrfxqenadhnijx9nfayi+sz1sug0aaaaasuvork5cyii=
Apr 21, 2009 | Sanyo Xacti VPC-T700 Digital Camera
Windows vista doesn't recognise my camera
You need a software update for the camera to work with vista....get it here:
http://www.ricoh.com/r_dc/download/sw/win/01.html
Mar 05, 2009 | Ricoh Caplio R4 Digital Camera
Gateway DC-T50...can't view or transfer images to my computer
how do i transfer pictures from my camera to my computor which has as its operating pro. vista?
Feb 09, 2009 | Gateway DC-T50 Digital Camera
Cannot download pictures from my camera to computor
You don't need a driver.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Windows Photo Gallery or Picasa.
Dec 23, 2008 | Fuji FinePix A345 Digital Camera
Installing software for new canon digital camera
Apparently Windows Vista does not require the software and worked without installing it. Regards Trish
Jul 28, 2008 | Canon COLOR IMAGE SCANNER
I have a new lap top which is Windows Vista and my camera is compatable with Windows 98, ME, and 2000, how do I down loan the information to the new computor.
CONNECT THE CAMERA AND WHEN IT SAYS THAT NEW HARDWARE FOUND..DOWNLOD DRIVERS.....ASK FOR CONNECT TO NET....THATS ALL
Apr 04, 2008 | Cameras
Ricoh Caplio R4 Digital Camera Logo
59 people viewed this question
Top Ricoh Cameras Experts
Fred Block
Fred Block
Are you a Ricoh Camera Expert? Answer questions, earn points and help others
