Question about Hotpoint 24 in. DF55 Free-standing Dishwasher
Hotpoint dwg60 does not fill with water - Hotpoint 24 in. DF55 Free-standing Dishwasher
  • Hotpoint Master
  • 3,247 Answers
If the water overflow circuit has been triggered then it can lock the inlet valve. Check if the float device at the base of dishwasher is moving up and down when pressed.
Alternatively, the inlet valve may be faulty.
Posted on Jan 01, 2011
Hotpoint aq7L149i washing machine flashing lights ?
Hi Jason.
The most likely reason for your problem is that the water inlet valve is faulty. This is why the machine won't fill.
It is a simple fix for a serviceman.
Good luck.
Nomess
Nov 21, 2014 | Hotpoint Washing Machines
Will this machine work with just a cold water supply
It should work with a cold water supply WF865 hotpoint if it has one connection on the back it is a cold fill machine all new machines are cold fill only hot fill has gone now. hope this helps.
Dec 27, 2010 | Hotpoint Ultima WF865 Front Load Washer
Hi my hotpoint wma63 fills with water for a wash, then empties
motor tacho not being sensored...motor or pcb fault...chopper board faulty bottom front right in machine.
Jul 31, 2010 | Hotpoint Washing Machines
Hotpoint aquarius drum fills to top with water
will it stop when you stop the cycle? if so your pressure switch could be the problem however if that does not stop the water you intake water valve is most likley the problem
Feb 06, 2010 | Hotpoint Aquarius WMA42 Front Load Washer
Machine fills with water then stops with H2O flashing in the display
Check water inlet valve (valves) for no fill or low water pressure.
Please rate my suggestion.
Thanks.
May 05, 2009 | Hotpoint Ultima WF860 Front Load Washer
My Hotpoint dishwasher won't fill with water. I have not used it for quite a while and last time I've used it (about a year or two ago) it worked fine.
abviosely check that there is water going into it but also check the float switch. There should be a bobber type of thing that goes up and down when the water fills in there. Move that up and down to see if it's stuck. You should here a click of a switch when doing that. If that doesn't do it let me know.
Mar 22, 2009 | Hotpoint 24 in. HDA2000Z Built-in...
Hotpoint wd440 aquarius
Not all programes fill with hot water.Try on 95 degree wash if it takes hot water ,you are dialing a prog,that does not take HOT.
Oct 31, 2008 | Hotpoint Aquarius WD63 Front Load...
Hotpoint ultima 1200 washer/dryer
Have suffered the same problem. Suggest you remove back (after turning off electrical supply) and look at the water outlet pipe - you may have a sock or two in this - remember to reattach outlet and secure in position.
Aug 15, 2007 | Hotpoint Ultima WD72 Front Load...
Hotpoint 24 in. DF55 Free-standing Dishwasher Logo
91 people viewed this question
Top Hotpoint Dishwashers Experts
AcmeUK
Level 1 Expert
Are you a Hotpoint Dishwasher Expert? Answer questions, earn points and help others
