Question about Dryers
My whirlpool AWZ 135 electric dryer door won't open
  • 55 Answers
SOURCE: Whirlpool AWZ 3303 Tumble Dryer
http://www.whirlpool.co.uk/ifudocs/501930700361GB.pdf
Posted on Mar 25, 2008
SOURCE: Whirlpool AWZ 650 condenser dryer
MY FILTER LIGHT IS ONN ALL THE TIME, HOW DO I CLEAN THE FILTER...WHERE IS IT, IS IT THE ONE BELOW THE FRONT DOOR THAT PULLS UP AS IN THAT CASE I'VE CLEANED THAT?
Posted on Aug 27, 2009
rogrrabbit
  • 986 Answers
SOURCE: Whirlpool AWZ 7303 tumbling but not drying.
blower wheels will get loose in dryers. Sometimes they will get a whole lump of lint in them or you can hear a rattling noise in the dryer, this is the blower wheel, its worn out and it can cause the fuse to blow too,or it can half *** work and take fifty forever's to dry the clothes.Or it could be just that the dryer needs a good blowing out .I use a lawn blower to get all the lint out of the dryer as well as the vent pipe and vent to outside. I take the filter HOUSING out and wash it also. That is, I remove the housing and clean is good! Making sure that the dryer is properly flowing air is a good thing!
Posted on Sep 12, 2009
SOURCE: have to replace broken belt on a whirlpool awz
Double the belt and slide it between the two arms of the tension pulley. Then slip the belt over the drive motor pulley. The belt will be pushing against the tension pulley from underneath.
Posted on Sep 30, 2010
SOURCE: whirlpool tumble dryer model NO- AWZ 121/3-belt replacement
how do i replace my belt on my tumble dryer
Posted on Jan 01, 2011
Awz 8676
Try this link http://tumble-dryers.tech-specs.com/whirlpool-awz-8676-n30037723
Aug 29, 2014 | Whirlpool Dryers
Whirlpool awz 8666 all programs working but no hot air
Is this a washer or dryer? If it's a dryer, is it gas or electric? If it's electric then reset the breaker (both) in the box. Need more information
Jan 06, 2014 | Whirlpool Washing Machines
Whirlpool AWZ 410 washer dryer is not generating any hot air when drying. The dryer drum is tumbling but with cool air only.
Unplug the unit and take the top with the screws holding the lid on. Take a look at all of the wires on the top of the machine. You might notice broken/burnt wires on the safeties that are close to or that directly activate the heating element located in the blower housing located at the top of this washer/dryer condensing unit.
Nov 26, 2013 | Whirlpool LER4634J Electric Dryer
Electric dryer will not start
If the filter chute or vent to outside is clogged the skinny white fuse mounted on the blower next the the control t-stat melts. This kills power to the door switch circuit. The door switch circuit stops the motor whenever the door is opened using a door switch. If the door switch lever is broken or the door switch is broken she won't rune either. Now here is my home movie and whirlpool dryer page:
DAN'S DRYER REPAIR PAGE
Apr 28, 2013 | Whirlpool Dryers
Whirlpool awz 7303 dryer will not heat
If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 28, 2010 | Whirlpool Dryers
How to clean a whirlpool awz7913 condenser tumble dryer heat exchanger
how do i clean my heat exchanger on the whirlpool awz 7913 condenser tumble dryer?
Jan 19, 2010 | Whirlpool Dryers
Whirlpool tumble dryer model NO- AWZ 121/3-belt replacement
Jan 09, 2010 | Whirlpool Dryers
Door latch broken on my Whirlpool AWZ 650 dryer
it is very easy to replace you just have to lift the top to press the clip and push it out please rate
Jan 03, 2009 | Whirlpool LER4634J Electric Dryer
You can usually download from Whirlpool website
Jun 23, 2008 | Whirlpool LER5636P Electric Dryer
Whirpool AWZ 480 dryer
It could be as simple as a door switch adjustment. Get it fixed under warranty.
Sep 12, 2017 | Whirlpool Dryers
Dryers Logo
91 people viewed this question
Top Dryers Experts
