Question about Microwave Ovens
I have a creda europa solar plus double oven and want to replace it with a BOSCH HBM56B550B will the power supply I have be enough for the Bosch?
    Brigadier General:
  • 8,909 Answers
What you must do is calculate the total power required by the Bosch cooker. Convert it into Amperes and copper cable is roughly 10 Amperes per 1.50mm cable. What size cable feeds you cooker at present? Or
Is the maximum power calculated for the old cooker the same or more than the new cooker. If it is and the old cooker was installed by a qualified electrician observing local electricity codes, no problem get it fitted, if not consult a qualified electrician.
Posted on Jan 01, 2011
I have a Bosch built in microwave, HMT35M653B but it went dead today. How can I get a repair manual for HMT35M653B?
Hello and welcome new user of fixya! I found a link to the bosch support page: Bosch Home Appliances Customer Service Support Repair Parts. Try giving them a call or a shooting them an email. Best of luck!
-Mr. W
Feb 25, 2015 | Bosch HMT35M653B Exxcel Stainless Steel...
Bosch hmt9666 microwave plate stopped spinning while being used? Can't seem to find replacement part. Help needed
Try www.bosch.com contact customer support and the technical department, also check www.ebay.com type make and model of the microwave oven and scroll through the list.
Jun 15, 2012 | Bosch Microwave Ovens
Bosch hmt8656gb microwave doesn't always start
The problem is in the keypad control board and usually means it must be replaced to fix the problem, and the part alone is expensive.
Jun 02, 2012 | Bosch HMT8656GB Microwave Oven
My Bosch microwave (built in HMB5050 has stopped heating all of a sudden. Everything else appears to work fine but it does not heat. What is the problem?
I have the same issue, plus mine shuts down after 30 seconds. There are a few other similar issues on here, with solutions including unplugging it for 10 seconds, replacing a fuse, and replacing half the internals. Please post your fix if you find one!
Jul 28, 2011 | Bosch 500 HMB5050 Microwave Oven
Hmv9305/01 microwave @ 13months old the magnetron blew, authorized bosch repairman, replaced using bosch magnetron. warranty for 90 days jan of 2011 same problem, why does this happen? should i ditch...
With all due respect, what are you doing to it?
If you use it with nothing in the cavity, that will kill the magnetron otherwise it will last for years and years.
Very unusual and Bosch is a well respected name.
If there is a probem with the oven, Bosch will replace it so take it up with Bosch.
Apr 01, 2011 | Bosch HMV9305 Microwave Oven
A power surge at the clients house took out surge fuses on some bits of kit. We have repaired them. Now we are left with the bosch micowave with no power. Any suggestions?
If it has an invertor for the HV, return it to a Bosch Agent for repair but if it is a standard transformer, check the transformer supplying the control board.
Hope that helps.
Mar 02, 2011 | Microwave Ovens
Problem with the Bosch HME9760 / HME9750 800 Watts Microwave Oven Small pop when i went to open door, and now looks dead. 13amp main fuse all ok, so i assume its an internal thermal fuse or something...
Dead appliance, power on wall outlet.
YOUR SAFETY IS PARAMOUNT!
Attempt this only if you are competent.
If your appliance has absolutely no functions at all, remove it from the mains supply, remove the case and see where the mains lead goes in to the appliance and follow the cable until you find the main fuse.
ONLY USE THE SAME TYPE AND RATING OF FUSE TO REPLACE IT.
The usual cause of this fuse failure is the door switches are contaminated or sticking. Check the door switches before putting power back on to the appliance.
Hope this helps.
Jan 06, 2011 | Bosch HME9760 Microwave Oven
Hi the plastic latch on the left hand side of door has broken off. where can I get a spare part and how easy is it to fix?
It should be straight forward enough to repair/replace.
You can buy a replacement by either an online store or go to the Bosch web site for a list of authorized dealers.
Hope that helps.
Nov 08, 2010 | Bosch HLK4525GB Convection/Microwave Oven
Bosch Microwave HMT9656AU cuts out
Did you contact a Bosch-authorized service center?
If not, please consult your manual for the number or other contact information for Bosch. They can help you find local, knowledgeable servicers.
There may still be some warranty on some parts.
Or they may help you find local Bosch parts distributors in case you or a friend want to replace the part(s) yourself.
If you do not have your manual, I would contact the dealer where you purchased it to see if they have current contact information for Bosch.
An authorized servicer will have the service manual and is a little less likely to actually test and troubleshoot, instead of just throwing in parts until it works.
Dec 15, 2008 | Bosch HMT9656GB Microwave Oven
Microwave Ovens Logo
130 people viewed this question
Top Microwave Ovens Experts
William Miller
William Miller
Are you a Microwave Oven Expert? Answer questions, earn points and help others
