Question about Samsung CLP 300 Laser Printer
Faint printout My printouts have a faint streak from top to bottom near the center of the document. The black ink is faded, in particular. I've tried taking the imaging unit out and cleaning the inside of the printer. I've also tried emptying the waste toner container. I still have the same problem, and I can't find any information about how to clean the print heads. Please help.
  • 1 more comment
  • M Johnson Jul 24, 2008
    Yes. I'm noticing all of what you have described above after all of the reviews that I have read already. Thanks for answering my question. I'll check out the Konica-Minolta and the Xerox-Phaser.
  • Anonymous Jul 29, 2008
    I have replaced the black ink toner, it now does not print the left side of any prints, thought it was a faulty toner, so I bought a 2nd one, still the same.
    How do you fix this?
  • Anonymous Mar 14, 2014
    i have a kodak espoffice 2170 and the black is streaked and faint even after running diagnostics and taking the print head out and soaking it in hot water. any suggestions?
Thanks. I looked at the transfer belt last night and, yes indeed, it did in fact have scratches on it. I think I'm just going to get rid of the whole thing. When i add everything up -- toner, parts, etc. -- it equals a new printer. Any suggestions on one of quality? Thanks for taking the time to explain how the laser works from the inside, too. I was wondering about that. I'll have to read it a couple of times to get it, but I was wondering about that. :) Take care.
Posted on Jul 19, 2008
    Scholar:
  • 68 Answers
So we all understand; there is no ink your printer. In an inkjet printer, liquid pigment is sprayed from print heads directly on the paper where it dries and makes an image. Your printer has toner, which is a pigmented powder. I'm sure you found this when you cleaned the waste toner container.
The simple:
A laser printer draws an image on a rotating drum which then rolls into a tub of toner. Anywhere the laser hit, toner sticks, where it didn't hit, it doesn't stick. The drum rolls over a piece of paper (transfer belt with 1-pass color) and the toner rubs off onto the paper - it's still powder. The paper then goes through an oven (developing drum or fuser) which melts the toner onto the paper. BaM! Out comes your document.
A consistent line going from top to bottom of every page printed means one of the following:
1) A band of evil is thinly encircling the imaging drum causing it to pick up toner where it has not been hit by the laser. Check the imaging drum for lines that match the ones on your paper. Replace if necessary.
2) The transfer belt has a line of evil on it. Look at the belt in the right light in order to see scratches and such. Replace as necessary.
3) If your streak is an anti-streak, which is the LACK of toner. You need a new imaging drum. It's damaged. Unless it's a smudge, then its the fuser.
You can clean things inside very carefully with a cloth, but I always use compressed air. The CLP-300 is very compact and cheap and is not really made to be repaired. Replace the parts, or throw it away.
I understand that at this time July 18, 2008, you can purchase this unit for as low as $99 US after mail-in rebate. Check your local or online (newegg) retailer.
Questions? Ask. Good Luck.
Posted on Jul 18, 2008
  • Pavel Jul 22, 2008
    When trolling for a new laser printer, you will often find the age-old inkjet printer scam: Cheap printer, expensive supplies.
    Most often, more money spent means higher quality build, faster print speeds, and lower-cost supplies. Also, the better printers tend to have larger toner loads, (maybe 4x) but will cost twice as much. It's tough to pay $200 bucks for each toner color for a home printer.
    I've had good luck with the Konica-Minolta and the Xerox-Phaser.
    That's all I can say about that. Read reviews online. They are everywhere.
My print outs are having lines across them
You need to have your printer go thru head cleaning cycle. Check to make sure the ink is not leaking from the cartridge. Are you using OEM ink or second hand?
Jun 20, 2014 | HiTi P720L Photo Printer
I bought some cheap toner and noticed almost immediately streaking and missing lines. I replaced it with HP toner but now black won't print at all.
If your printouts are streaked or faded, missing black or other colors, have blurred or fuzzy text, or ink streaks or smears, or show other problems, please refer to the link below for troubleshooting steps for print quality issues.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01957673&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=2512009
Apr 03, 2011 | HP Officejet Pro L7680 All-In-One Printer
My epson LX 300 printout... my epson LX 300 print out faint documents(faint printout).what is the problem?
hi...this is catridge problem.
the catridge may be about to finish and the mixing is not properly taking place.
the outlet from the catridge may be blocked so reqired amount of ink is not flowing out from it.
please change the catridge it wil be fine
if my answer wqas useful please rate me
Jul 13, 2010 | Epson LX-300 Matrix Printer
Black color has faded to unreadable Have replaced all components
chean the black cartridege with a cleanex and tap it to see if ink will come outm if it does bor then it has dried out and needs replacement.
Jan 11, 2010 | Dell 5100cn Laser Printer
HP L7700 officejet printer leaves streaks on black ink lines only. Have cleaned heads repeatedly, changed black and color cartridges - nothing works.
Print in grayscale (black area streaking only) If the streaks are in a black area of a black and white printout, change to grayscale printing.
NOTE: This step does not apply to color printouts.
  1. In the application you are printing from, click File , and then click Print .
  2. Make sure the printer is selected and click Properties .
  3. Click the Color tab, and select Print Grayscale and High Quality .
Nov 28, 2009 | HP Office Equipment & Supplies
Black ink problem with printout on hp7780
Always try replacing the ink cartridges first.
It sounds like the print heads in the 7780 are bad. Don't confuse the ink cartridges with print heads. The cartridges fit inside the print heads. You will need to change the heads. Here is a link to HP's how-to.
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c00841890&tmp_track_link=ot_faqs/top_issues/en_us/c00841890/loc:1&lc=en&dlc=en&cc=us&lang=en&product=2512010
Could have the same problem with the Dell.
Jun 01, 2009 | HP Officejet Pro L7780 All-In-One InkJet...
Faded-out streak
check your ink levels. if its the ink that came with the printer it is probable running out of ink. they do not give a full cartridge with printers, only about 3rd full. also try cleaning the heads. and try changing your printer settings/prefrences to less ink, more drytime see if that helps.
Apr 26, 2009 | HP LaserJet 1018 Printer
OKI C5200 - Faded black print area
Trying cleaning the black LED's that are on the top portion of the open clamshell. Use rubbing alcohol on a rag and wipe each bar x4/. These units charge the drum surface where print is going. This should work.
Jun 12, 2008 | Samsung OKIDATA - OKI C5200n - Printer
Black streaks on printout
Your fuser is worn out. Needs to be replaced.
Mar 27, 2008 | HP LaserJet 5p Printer
Consistent, faded and streaking vertical lines across entire page, from top to bottom.
Toner issue getting to drum - use gen toner cart.
or Drum blade stuffed (lines are down page fro top to bottom- replace drum assy
Drum has been exposed to light faint or blank across copies repeated 4 times down page - replace drum assy
or upper fuser roller stuffed, down page, smudgy print -  replace fuser
LSU(laser) or boards rarely cause issues
Oct 25, 2007 | Samsung ML 2010 Laser Printer
Samsung CLP 300 Laser Printer Logo
1,149 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
