Question about Refrigerators
Whirlpool wbm502ix no inside lights, low temperature after long time door was open.
  • 4 Answers
Cold
Posted on Jan 01, 2011
Hi! I've got a problem with My Samsung cooltech plus fridge! Every 3min it rings 4 times nearly and the lamp inside the fridge doesn't work !! And the temperature is not low only in the fridge
It's probably telling you that a door is open (which would also explain why it's not getting cold, and probably the light just burnt out from being on for a long time). Check for things blocking the door from closing all the way, and look around the part where the door seals shut against the main part of the fridge.
Aug 03, 2016 | Samsung Refrigerators
My whirlpool refrigerator freezer section around the blower fan is frosting up I changed the defrost heater and it still the same model number wrf560seym00. What next to try.
You may have an air leak around the door seal or the ice chute door is stuck slightly open causing compressor to run all the time as moisture from outside fridge to collect on fan shroud and evaporator. Are you defrosting normally or temperature rising inside fridge?
Appliance 911 Sea Breeze
Sep 18, 2015 | Whirlpool Refrigerators
How do I stop the refrigerator from beeping 3 times every so many seconds. Also the light turns off,but turns on again whe door is open and closed?
it has a timer or a temperature control that reads when the temperature rises because the door has been open too long or is not shut properly ( door seals failed). This timer chimes to let you know that the door has not closed properly or sealed properly. Call a refrigeration specialist to check out the problem as the food could go off if the temperature cannot be kept low enough.
Jan 05, 2015 | Cars & Trucks
Why do the Automatic cycles on my Whirlpool Duet Electric Dryer not always work?
In some dryer's the control panel relies on a thermistor rather than a CYCLING thermostat to regulate the drum's air temperature by monitoring the component's resistance changes; resistance goes down as temperature increases and up when temperature decreases. Once the drum's air temperature reaches a certain level required to dry clothes, the control panel shuts off the heater. The panel will turn the heater on again and begin another heating cycle when the thermistor indicates that more heat is needed to keep the air temperature constant inside the drum
Lastly check your moister sensor. ( located inside the dryer door usually) Especially if machine seems to shut down early and clothes are still wet.
Test with a meter at room temperature and it should show continuity.
A failed moisture sensor will affect the dryer run time in the automatic moisture sensing cycle but it will not affect the heating of the dryer or the timed cycle. Which are reflected by the thermostats.
Read more :http://www.ehow.com/info_12203962_check-dryer-thermistor.htmlGOD IS So GOOD !!!! AND THAT'S WHY MY ADVICE IS FREE
Jul 30, 2014 | Whirlpool Dryers
Whirlpool regrigerator door auto locks
As far as I'm aware, refrigerator doors don't have auto locks on them. What you're describing sounds like the door has a fantastic seal from a temperature change between the inside of the fridge and the room around it. When there is a drastic change, (usually warm) the refrigerator seal will seem to stick. This will wear off over time, or when the temperature changes.
Jul 28, 2013 | Whirlpool ED5VHGXM Side by Side...
Whirlpool Quiet Partner II clean light blinks 7 times
The clean light flashing 7 times is an error code indicating an issue with the wash temperature. If the control does not detect a 4*F temperature rise in the main wash cycle, it will display the fault as the clean light flashing 7 times. There are several things that could cause the water not to heat, including the water being too hot coming in, an open door switch, or a faulty component in the heater circuit. The most common cause is the door switch not closing properly. This can be due to a loading issue or a latch issue. If upon visual inspection of the heating element no obvious defects are found, I would recommend resetting the control and running another cycle, paying close attention to door closure. If the light begins flashing again, you likely have a component failure. The heat circuit consists of several components including the element, control, door switch and tub thermostat(s). Reset the control by pressing teh following buttons within 5 seconds.
Hit Temp Wash Heated Dry Hi Temp Wash Heated Dry
Mar 02, 2012 | Whirlpool Dishwashers
Refrigerator creates water that runs out when you open the door. Where is the water comming from and how do I stop it.
Check the inside temperature settings and make sure they are not to low as this will cause the water issue. Its coming from condensation.
Nov 13, 2010 | Whirlpool EL7ATRR Refrigerator
Freezer door opens when we close the refrigerator door.
That usually indicates one of two things. (A) You door gasket has gone bad and needs to be replaced, or (B) the temperature in the freezer is not low enough to cause a good seal. You can check the temperature with a thermometer. It should be atleast below 10 F but preferably around zero F.
Nov 08, 2010 | Whirlpool Refrigerators
Inside light on fridge/freezer not working.
OK, the digital logic being out reminds me of the possibility the mother board or circuit board has gone out. If you can get the complete model number on inside of fresh food compartment door frame, near bottom of door, I will be able to help you better. While I wait I will try to look up similar models and get better answers for you. Thanks, Sea Breeze
Mar 20, 2009 | Whirlpool 25.6 cu. ft. Side-by-Side...
Whirlpool Gs5shaxnb02 Ice maker
the most comon problem is the ice machine in the freezer actuates at low teperatures. actuation is when the unit goes into harvest the ice. if your freezer is not aciving low enough temperature the ice machine stops working ' check to ensure the condensor under the fridge is not pluged with dust .Also make shure there is adiquit air flow around the ice machine. hope this helped someone .
http://www.whirlpool.com/custserv/index.jsp
Jul 29, 2008 | Whirlpool GS6NBEXR Side by Side...
Refrigerators Logo
Top Refrigerators Experts
John Tripp
John Tripp
Brian Coughlan
