My Hitachi gives SFT800X Error 4 during the last stage
Failed Windows XP Setup
sounds like a bad hard drive or it has bad sectors.hard drive regenerator software may help
Jun 25, 2017 | Computers & Internet
'Writing Error' during last stages of burning a cd.
could be bad cd's ,but id say your recorder is going bad. you can try cd rw disks they work better in this case. then use a pc to copy to regular cd then reuse the cd rw disk again.
Sep 26, 2013 | Marantz CDR420 CD Recorder
In the middle of baking cycle kneading starts for a little while and damages the loaf. How to fix this programm error?
Most bread machines do a little "punch down" before the final bake stage. The bake stage doesn't really begin until after the final 4-10 seconds of "punch down". Then the bake stage really begins and lasts about one hour.
Apr 01, 2013 | Black & Decker B2300 Bread Machine
Samsung refrigerator error code 8E
8E = OVER CURRENT ERROR
IPM fault signal (this is caused by the overload of the MICOM INTO during motor action).
IPM: Integrated power module. The IPM controls the motor.
If the fault (low signal) happens to be sensed even once during the washing/rinsing stage, the motor stops immediately. However, during the dehydrating stage the signal is to be sensed, when the number of signals reads more than 6 per 500ms during the Washing or Rinsing cycle action.
If the motor stops working, in one direction ten times, "8E" Error is displayed.
During dehydrating, when the overload is sensed, the motor stops working at once and then feeds back to the initial stage of the dehydration unbalance sensing. When the feed back has occcurred twice, Error "8E" is displayed during the dehydrating unbalance sensing, No error happens by overload sensing. When it happens at more than 800rpm, the process is stopped compulsorily. Power Switch OFF can clear the overload error.
Nov 23, 2012 | Samsung RS265TDRS Side by Side...
E8 front loader washing machines
OVER CURRENT ERROR - Display shows 8E.IPM fault signal (this is caused by the overload of the MICOM INTO during motor action).
HOWEVER, the UK White goods website says:
E8
Temp too high on low temp washesNormally this will be the wash temperature thermistor or NTC that's faulty, please contact us if you need the thermistor with the model and serial number.
You can find more about your Samsung Washing Machine error codes at:
http://www.keepingupappliances.com/repair-help/appliance-repair/washing-machine-help/samsung-washing-machine-error-codes/
or
http://www.ukwhitegoods.co.uk/help/fix-it-yourself/fault-codes/laundry-fault-codes/3069-samsung-washing-machine-fault-codes.html
Jun 21, 2011 | Samsung Washing Machines
My samsung washing machine model WA13513 13.5kg load had 8E error message popping out from the screen. Is the computer board damaged?
OVER CURRENT ERROR – Display shows 8E. IPM fault signal (this is caused by the overload of the MICOM INTO during motor action).
If the motor stops working, in one direction ten times, “8E” Error is displayed.
During dehydrating, when the overload is sensed, the motor stops working at once and then feeds back to the initial stage of the dehydration unbalance sensing. When the feed back has occcurred twice, Error “8E” is displayed during the dehydrating unbalance sensing, No error happens by overload sensing. When it happens at more than 800rpm, the process is stopped compulsorily. Power SIW OFF can clear the overload error.
would advise calling a tech... hope this helps.
Oct 25, 2009 | Washing Machines
E8 error code
8E - OVER CURRENT ERROR
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
May 02, 2009 | Washing Machines
Message on screen 8E, Motor won't start on spin cycle. Model no Q1435(C/S/V)
This is what I found:
11. OVER CURRENT ERROR - Display shows 8E .
- IPM fault signal (that is caused by the overload of MICOM INT0 during motor action) is sensed.
IPM : Integrated power module. , IPM controls motor.
- If the fault signal (low signal) happens to be sensed even one time during cleansing/rinsing stage,
the motor stops immediately. However, during dehydrating stage the signal is to be sensed
when the number of signal is more than 6 for 500ms.
- During Cleansing or Rinsing
When the overload is sensed, the motor stops immediately and then proceeds to the next water-flow action.
If the stopping of the motor working is happens in one direction ten times,
- During dehydrating
When the overload is sensed, the motor stops to work at once and then feeds back to the initial
When the feed back is continuously happened 2 times, "8E" Error is displayed
During the dehydrating unbalance sensing, No error happens by overload sensing.
-Power S/W Off can clear the overload error.
in short: imbalance problem
In a german forum one guy solved the problem by replacing the motor electronics. I am currently experiencing the same problem. I keep you posted.
May 08, 2008 | Washing Machines
Hitachi Ultravision Digital TV dark picture
Looks like
1. A Cold solder in the Video Output stage power supply.
2. A bad Electrolytic Capacitor in the above Video Output stage.
I generally do not waste time in attempting to locate faulty capacitors. There will be only 6-8 pf them in the above stage / section,m and the klot of them would collectivelyt not cost more than 3-4 $ equivalent, in india. Just blindly replace the lot, and the set is ready in 30 mins.
Dunno how much they will cost in your country. Try to look for a 100mfd, 160V Capacitor. Close your eyes and replace. generally does the trick.
Nov 13, 2007 | Hitachi 32UDX10S 32" TV
Washing Machines Logo
41 people viewed this question
Top Washing Machines Experts
Gerry Harvey
Gerry Harvey
