Question about Dell Studio Slim-Tower Desktop Computer
Dell 540s wont turn on when i push the power button lightlights up then goes back off light on back then turns off fans start to turn on then goes off computer does not turn on.after this when you push power button it does nothing.unplug drain power then does same thing all over again.please help
  • 3,940 Answers
Generally a no post, since the system will not stay on, you simplify the system configuration by removing all external connections except power, then see if the system will stay on. If it does, add items back one at a time till you ID the issue.
If no change with external items disconnected, then issue is internal. remove any expansion cards and try again, if issue resolved, the add one at a time to isolate fault. If still no go, try ram modules individually. if still no go, disconnect power to all drives, see if system will stay running with drives disconnected. if still no go, then it is either the power supply or the motherboard. replace the power supply 1st since it is cheapest to replace
Posted on Jan 01, 2011
Dell optiplex 380 won't turn on
steve it can be many things.3-4 but you don't give enough information
Apr 03, 2013 | Dell OptiPlex 380 MT Desktop Computer...
Gateway gt4016 wont turn on you can hear the fan and light flicks on for a second but then nothing changed the power supply nothing
try rebooting your coumpter is in sleep mode it takes a long time but you will get it back on .... keep pushing the power button aventally it will start up
Jun 30, 2012 | Gateway GT4016 Desktop PC
I have a dell inspiron 530 with the quad core an everytime i start it up it goes into windows for about 10-15 mins an the monitor screen just goes blank an the keyboard lights go off an when i push the...
it sounds like your motherboard is shutting itself off to protect itself from overheating or some other system failure. you should verify all your fans are running at the correct speed. if it seems like everything is running fine, you can probably turn that off in bios. obviously if there is something wrong with the fans, then you need to replace them. Another options is maybe the processor is getting too hot which is why it's shutting down. open the case and remove the heat sync from the board so you can see the processor. clean the thermal paste off the processor and apply a new generous layer. put the heat sync back on and then try and restart. make sure before you do ANY of this you unplug the computer! good luck and let me know if it works!
Jan 27, 2012 | Dell Inspiron 530 Desktop Computer
While attempting to connect my laptop to my vizio tv it shut down and wont start back up. power just gone!
I think it's just like on a projector. Your have to dupplicate screen, on most laptops it's Fn key + F5... or just find the icon from the photo below on your keyboard:
May 14, 2017 | Dell Inspiron dndon023 Notebook
Push power button and the power light turns amber and lights up then shuts off. the light in back of the computer is light green and it starts to turn on then dies
The fact that ity is trying to start and shuts off after ..it seams that it is the CPU fan to blame ...If the fan fails to start the CPU will turn the computer down instantly due to the temperature limit ..(in 1 or 2 sec ) ..
so ...open it up ..and see if the fan is spinning ...on start ..and if it is not ...check the connection with the board or replace it ..
(by the way ..this may also be a CPU failure ..and need another one ) ..
Aug 31, 2011 | Dell Inspiron 518 Desktop Computer
When i push the power button, inspiron 1525, it turns
try this.... go to start | run | control
go to power options
on the advanced tab there will be a option called
"when i press the power button on my computer"
select the "shutdown" option
click apply and ok
then try shutdown your machine using the power button
Dec 22, 2009 | Dell Inspiron 1525 Notebook
Dell XPS400 No Start!!
If you fan isn't turning like it should, it is definitely a power supply issue. Go out and purchase a power supply with 250-300 watts...thats a good standard wattage!!
May 12, 2009 | Dell XPS 200 PC Desktop
Dell loptop wont turn on
take out ur batteries, clean the terminals with spirit or light alcohol, then re-insert it. better u use direct power supply but be sure to check that the power is beig supplied and the terminals/sockets are cleaned.
did this helped u. if not, tell me, when u push the power on button of ur notebook, does anything happens, like the fans start spinning or light went on. does the screen turn on or does something appears on the screen?
if nothing is happenng after pressing the power button, then this is a clear case of problem with ur power recieving section of the notebook. go to your pc dealer.
Jan 03, 2009 | Dell Inspiron 6000 Notebook
Dell Latitude C510/610 wont turn on
I have more of a suspicion of the CPU fan than the hard drive, right now. If a hard drive goes bad, the system will wake up, go through it's POST (Power On Self Test), and then tell you there's an issue with the hard drive. If the CPU fan goes bad, the system turns on, sees an RPM of 0 on the fan, then turns back off. That hypothesis also fits in with the slowness you were seeing. If a CPU starts to overheat (because the fan isn't running well), it will start to throttle the clock speed down in an attempt to produce less heat.
Unfortunately, it sounds like your laptop may be in need of a professional repair facility.
Mar 07, 2008 | Dell Latitude D600 Notebook
Dell Studio Slim-Tower Desktop Computer   Logo
1,010 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
