Question about Microtek scanmaker 3840
There's only black image in the preview... scans but has black image only
When scanning a color picture it comes through in black and white what am i doing wrong?
Change the Options on your HP Scanning Software to Scan in Colour or Else:
In this case u have to scan and Preview the scanned images using Windows Photo Gallery.....
Click on File and Click on Import from scanner or Camera...........
Then again click on Import...........It will scan and preview the Applications to u....
Thanku.......
Good Luck!@@!
Sep 23, 2011 | HP Deskjet F4140 All-In-One InkJet Printer
How do I scan with HP psc 1210
Answer is on this link:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c02455373&lc=en&dlc=en&cc=us&product=90764#N305
Click on this link or copy and paste the complete link into your browser.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it and give a testimonial for my response. Thanks, Joe
Jan 24, 2011 | HP PSC 1210 All-In-One InkJet Printer
How do I scan a picture and email it?
Hi
You can start a scan from your computer or from your HP OfficeJet.
to scan an original from your Windows computer
1 Load your original either on the glass or in the automatic document feeder
(ADF).
2 Press Start Scan.
A scan of the original appears in the HP Preview window.
3 In the HP Preview, you can edit the scanned image. When you have
finished, click Accept.
For more information about making changes to an image during the
preview, see adjust an image during the preview in scan pictures and
documents in the HP Photo & Imaging Help for more information.
The HP OfficeJet does a final scan of the original and sends the image to
the HP Photo & Imaging Gallery.
If i helped you pls vote me
Sep 07, 2010 | HP OfficeJet 6110 All-In-One InkJet...
The scan comes out as a solid black image both in the preview and in the actual scan.
This is a preview from a related model, you must set the profile to photo and the color format of your reference. Hope this helps.
Nov 18, 2009 | Brother MFC 4800 All-In-One Laser Printer
My Lexmark P4350 printer is not scanning images to my computer?
To scan a document, please follow the steps given below:
1. Go to "Start," "All Programs," Lexmark 4300 Series, "Lexmark All-in-One Center."
To see how an image will look after it is scanned, click "Preview Now."
2. Click "Scan," "Send scanned image to."
If scanning an image, choose a graphics program such as "Lexmark Photo Editor," "MS Paint," etc.
If you wish to "Scan to OCR," choose a text program such as "MS Word," "WordPad," etc.
Once the image is scanned, the "Abbyy OCR" software will open automatically.
3. To begin the scanning process, click "Scan Now."
4. To view the additional options, click "See More Scan Settings."
To indicate what type of image is being scanned, select the "Option" next to the type of object you are scanning. Your settings will be optimized for that object type.
To indicate how the scan will be used, select the relevant option from the menu. Your resolution and other settings will be optimized based on your selection.
5. To revert back to the normal All-in-One main page, click "Hide Extra Scan Settings."
6. Under "Display Advanced Scan Settings"; you can see change settings, which will affect the outcome of your scan.
May 11, 2009 | Lexmark P4350 All-In-One InkJet Printer
Canon mp630 scanner
You can save the scanned data on a USB memory or a memory card by using the control panel.
IMPORTANT
- You can not use USB memory card and memory card simultaneously.
1 .Select Scan (Scan) on page HOME (HOME) and then press the OK button.
The screen where you select where the data should be saved is displayed.
2 .Turn the USB memory card direct print port or memory card into the slot.
3 .Select USB flash drive (USB flash drive) or memory card (Memory card) and then press the OK button.
4 .Select Save on USB disk (Save to USB flash). The screenshot Scan documents (Scan document) is displayed.
5. State the necessary settings and then press the OK button.
6. Place the original on the glass plate as shown on the LCD screen.
7. Press the [color] (Color) for scanning in color, or button [Black] (Black) for scanning in black and white.
When the preview is enabled, press the OK button after viewing the preview pane on the LCD screen.
The machine starts scanning and the scanned data is stored either on the USB memory card. Remove the original from the glass plate, the scan is complete.
REFERENCE
- You can only scan images continuously when you select PDF. Continue to scan the confirmation screen. You can save up to 100 pages of images in a PDF file.
- If the USB memory card or memory card becomes full while images are scanned, saved only images that are already scanned.
- You can save up to 2000 files of scanned data in both JPEG and PDF formats.
- Folder and filename of the scanned data stored on USB memory or memory card is as follows:
• Folder Name: (extensions: PDF): CANON_SC \ DOCUMENT \ 0001
• Folder Name: (File Extension: JPG): CANON_SC \ IMAGE \ 0001
• Filename: Serial number, starting from "SCN_0001"
• File dates: 01/01/2008
Mar 28, 2009 | Canon Office Equipment & Supplies
Negative Scanning Problem Using Epson Scan Software
Make sure the rectangular slots at either end of the film frame are not obstructed or covered in any way. When I attempted to scan color negatives I had the same darkness problem in the scanned image. When I cleared those rectangular slots, everything was fine. I hope this helps.
Sep 28, 2008 | Epson Perfection 1670 Flatbed Scanner
Scanned image only prints in black and white
it's tricky / annoying:
you have a preview ...
you have some of the (3) images checked
but also you have some of these images selected (blue outline)
now:
when you select (I don't mean the checking) an image you'll have to set the scanning params
again - or check them ...
if you select an image, and then set the params (like "color"), your scanned image will be in color
also resolution is the same way ..
especially after crating preview .. it'll be set to 300 Dpi
so after seecting one for scanning - check the resolution too :)
jepe
Sep 03, 2008 | Canon CanoScan 5000F Flatbed Scanner
Photos
Does this help? You obviously have to insert the media type into the media slot on the far right.(omoademola) Using the top control panel Printing tasks Scanning/Copying/Faxing tasks Troubleshooting
The top control panel lets you print an image from a photo card, scan a document or image, and copy a document or image with the press of a button.
Button/Light: Function: 1 Power : Turns the All-In-One on or off. 2 Copy: light Illuminates when Copy Mode is selected. 3 Mode: Changes the copy, scan, or photo card mode. 4 Scan: light Illuminates when Scan Mode is selected. 5 Photo Card: light Illuminates when Photo Card Mode is selected. 6 Rotate: Rotates the image 90 degrees. 7 LCD Panel: Number of Copies- this changes the copy count. Note: This feature is not active in Scan Mode. 8 Display: Shows copy, scan, and photo card selections. 9 Resize: Enlarges or reduces the size of the image. 10 Page Preview: Shows a preview of the output. 11 Select: Secures an option. 12 Menu: Provides options for image. 13 Arrow : Scrolls left, right, up, or down. 14 Stop/Clear: Cancels a print job or clears a selection. 15 Color Start: Initiates color copy, scan, or photo card output. 16 Black Start: Initiates black copy, scan, or photo card output.
Jan 10, 2008 | Lexmark P4350 All-In-One InkJet Printer
Microtek scanmaker 3840 Logo
106 people viewed this question
Top Microtek Office Equipment & Supplies Experts
Tony
shelmnot
Are you a Microtek Office Equipment and Supply Expert? Answer questions, earn points and help others
