Question about Olympus Stylus Tough 6010 / ? TOUGH-6010 Digital Camera
I was trying to upload pics from my OLYMPUS TOUGH 6010. after i connect my cam to my laptop, its not being read as a removable disk. what should i do? the messages shown on the cam screen is "one moment" and on the laptop i cant find it. please help.ty
When set to video-mode, my Olympus uTough 6010 will not focus, and all videos come out blurry
hi your lens unit is getting defective. check with repair shop or factory. this case you should send to olympus factory. ( recommending.)...it is depend on repair cost wise on your problem. good luck with you!
May 22, 2011 | Olympus Stylus Tough 6010 / ? TOUGH-6010...
The screen on my olympus u tough-6010 is always black, i can take photos, and turn it on but cant see the screen. PLEASE HELP ! i really enjoy using this camera underwater. i use it carefully, but before...
If the photographs that are taken can be downloaded and viewed on the PC , then the fault is with the LCD screen, If there is a possibility that water has seeped into the LCD and damaged or the LCD is faulty .
To remove will require good care as there is heavy sealing and must be done professionally. take estimate from an Olympus store or use as it is assuming the picture with experience.
May 05, 2011 | Olympus Stylus Tough 6010 / ? TOUGH-6010...
My olympus telling me that CARD-COVER IS OPEN ...and its NOT. there for my olympus display the warning .and now i can not do anything with it PLZ HELP
i alsi face the same problem. when i open the batt cover, there's a drop of water at the bottom. then my pics and lcd went awry/haze. have you fixed it? coz i want to know the solution.
Nov 05, 2010 | Olympus Stylus Tough 6010 / ? TOUGH-6010...
How to set date for Olympus Stylus Tough 6010 / µ TOUGH-6010 Digital Camera?
Olympus
I have here a copy of your camera manual for easier explanation on how to set a date for your camera. (see page 13 of 83) Hope this could help you be familiar with your camera feature.
Thank you.
Aug 07, 2010 | Olympus Stylus Tough 6010 / ? TOUGH-6010...
How do i take off write protected on an olympus 6010
It's not the camera, it's the memory card. SD cards have a slide switch along one edge. The position farthest from the contacts locks the card, protecting it from writes. The position nearest the contacts unlocks the card. If the switch is already in the proper position, slide it fully the other way and then back again.
If that doesn't work, try another card.
Feb 18, 2010 | Olympus Stylus Tough 6010 / ? TOUGH-6010...
My Olympus tough 6010 wont bring the screen on and its making a beeping sound i cant get it to work battery is charged
Hello
Thank you for using FixYa for your problem
Always check the batteries first, try another freah set but if is it still giving the same fault, your camera is faulty.
It should be taken to an authorized repair centre for a repair estimate. Very few digital cameras have any user-serviceable parts.
Please rate our solutions and if you still have problems please call back for more ideas to help you
Thanks
Richard Scott
Technical Support
New Zealand
Dec 03, 2009 | Olympus Stylus Tough 6010 / ? TOUGH-6010...
Olympus Stylus Tough 6010 / ? TOUGH-6010 Digital Camera Logo
252 people viewed this question
Top Olympus Cameras Experts
Steven Wander
Steven Wander
Jerry Greenberg
Jerry Greenberg
Are you an Olympus Camera Expert? Answer questions, earn points and help others
