Question about HP 38G Calculator
Fix decimals with HP 38G - HP 38G Calculator
    One Above All:
    The expert with highest point at the last day of the past 12 weeks.
    Top Expert:
  • HP Master
  • 102,366 Answers
Press SHIFT MODES, down-arrow to the "Number Format" line and press [CHOOSE], down-arrow to "Fixed," press ENTER, then press right-arrow and enter the desired number of digits to the right of the decimal point.
Posted on Jan 01, 2011
HP 12 C display does not show entire numbers. How do I fix?
If you mean it is not showing everything after the decimal point, you can change that by pressing the [f] key followed by the number of decimal places to display. For example, to restrict it to 2 places, press [f][2]. If you want to see 4 places, press [f][4].
To show all possible decimal places, use the sequence [f][9].
From the manual (http://www.hp.com/ctg/Manual/c00363319.pdf):
"To display a different number of decimal places, press f followed by a digit key (0 through 9) specifying the number of decimal places. In the following examples, notice how the displayed form of the number inside the calculator - 14.87456320 - is rounded to the specified number of digits."
25096057-rvrejqbjq4zuw4cbinsyjvsy-5-0.png "Although nine decimal places were
specified after f, only eight are
displayed since the display can
show a total of only 10 digits. "
The standard display format, plus the specified number of decimal places, remain in effect until you change them; they are not reset each time the calculator is turned on. However, if Continuous Memory is reset, when the calculator is next turned on numbers will be displayed in the standard display format with two decimal places
shown.
If a calculated answer is either too small or too large to be displayed in the standard display format, the display format automatically switches to scientific notation. The display returns to the standard display format for all numbers that can be displayed in that format.
Sep 12, 2014 | HP 12c Calculator
HP 14B need to set decimal point
Shift (yellow) button and DISP (above close parenthesis).
N button.
Will show FIX _
Input required number of decimal places
That's it!
Feb 13, 2014 | Office Equipment & Supplies
Change decimials on hp 17bii
If you want to change the radix mark, press DSP then the softkey corresponding to the one you want. If you want to change the displayed number of decimal places, press DSP then [FIX] then select the number of digits you want after the decimal point and press INPUT.
Nov 11, 2013 | HP Office Equipment & Supplies
HP 3G reset
Press and hold the ON and the top-row-third-key-from-the-left keys simultaneously, and then release them.If that doesn't do it, press and hold the ON, top-row-leftmost, and top-row-right-most keys simultaneously, and then release them.It that doesn't do it, turn the calculator over. Straighten a paper clip and poke it into the small hole below the bump (upper-right). Hold it there for a second and then remove. (You may have to do one or both of the keyboard steps above as well).
Apr 09, 2012 | HP 38G Calculator
How do i change from scientific to decimal in a HP 11 C?
Press f [FIX] and the desired number of digits to the right of the decimal point. [FIX] is on the 7 key.
Jul 22, 2011 | HP Office Equipment & Supplies
The display shows comas and misplaced decimals instead of properly placed decimals. For example 4258.32 reads as 4.258,32. How do I fix this on the HP-12c calculator? Thanks
Press and hold the decimal point key then press and release the ON key to swap the radix marks between US and European modes.
Oct 17, 2010 | HP 12c Calculator
There is a comma where the decimal point should be and vise versa.
From HP12c FAQ:
This document describes how to change the display of the decimal point on the HP 12C Calculator from a comma back to a decimal point. Instructions
  1. Turn off the calculator.
  2. Hold down the decimal point.
  3. Continue to hold the decimal point key, while turning on the calculator.
The comma should change back to a decimal point. Explanation The comma is the European equivalent of the decimal point. *
For more information about your machine (data sheets, learning modules, manuals, FAQs, etc), check this link:
http://h10010.www1.hp.com/wwpc/us/en/sm/WF05a/215348-215348-64232-20036-215349-33525.html
Aug 08, 2009 | HP 12c Calculator
I want to increase the number of decimal places
I found this solution on the HP website. Turn it on, and do what it says. Then turn it off and back on again, and the extra decimal places should show.
http://h10025.www1.hp.com/ewfrf/wc/document?dlc=en&lc=en&cc=us&docname=bpia5183 Introduction This document describes how to set the desired number of decimal places on the HP 12C Calculator in standard format and in scientific notation. Instructions for standard format
  1. Press and release the gold PREFIX key (f).
  2. Press the number key for the desired number of decimal places (0 through 9).
The display will show the specified number of decimal places. The answer will be rounded to the number of digits selected.
Mar 25, 2009 | HP 12c Calculator
Hp 49g+
TO GET ALWAYS DECIMAL NUMBERS PRESS MODE KEY; PRESS CAS (F3 KEY); USE THE4  SILVER BUTTONS TO GET TO THE NUMERIC OPTION--THEN PRESS F3 (the check mark).  Finally hit OK (f6) twice to get back.
May 15, 2008 | HP 49g+ Calculator
mukhtar21 shaikh
mukhtar21 shaikh
