Fisher & Paykel Aquasmart WL80T65CW1 LCD Display Module Replacement fault code 9 - I know this is the machine size setting fault. All the previous solutions posted seem to be for the LED version which has different buttons. Can anyone advise the keystrokes for the LCD version please.
3 Suggested Answers
SOURCE: fisher@paykel aquasmart WL80T65CW1 fault code245
hi my fisher & paykel aquasmart has a message saying fault 49 what does this mean?
Posted on Nov 18, 2009
  • 713 Answers
SOURCE: Fisher & Paykel Washing Machine WL80T65CW1 Fault 9
sounds like a size error . when you changed the display did you size your machine to the new display module?did you get the re-size set of instructions with the new display board? ring up where you brought the display from and i"m sure they can help. if not reply back and i will guide you thru it.
Posted on May 27, 2010
I have a fisher and paykel top loading washing machine and I get an error code 9.
javascript:;To size set a L.C.D AquaSmartâ„¢ machine:
1. Press and hold the left
SCROLL
button, then press the
HIGH EFFICIENCY
button until two
beeps are heard.
2. Press the
SCROLL
button to select the machine size (600 for WL70, 650 for WL80).
3. Press the
POWER
button
Apr 12, 2015 | Fisher and Paykel Aquasmart wl80t65c
Last month my aquasmart had fault code 130 payed repairman $180 to fix it now it has fault code 105 your webpage is very unhelpful knowing whats wrong with my aquasmart which is less than 5 years old
Did you look up your manual to help with the problem?
AquaSmart2 8kg - this is a link to download your manual
The good thing is that if you got Fisher & Paykel to come out, they offer a warranty on their service - so call them again and tell them the situation - they should come out for free....
Sep 15, 2014 | Fisher and Paykel Aquasmart wl80t65c
Fisher and paykel washing machine fault code 9 how to fix
All replaced electronic boards need resizing.
Going by your post your have an AquaSmart machine
Here are some details to resize an AquaSmart machine
Aug 03, 2014 | Fisher and Paykel WL26CW1 Top Load Washer
250. (11111010) SmartPump Loss Of Sync
This fault is normally as a result of the pump not starting. This fault is usually caused by an
object that has gotten into the pump, and is either under or on top of the impeller, which is
causing the motor to stall when it is trying to start.
Primary Source: Pump Stator Windings Open Circuit.
Action: Measure the resistances of the pump stator. For more information
refer to the AquaSmart service manual.
Secondary Source: Pump System.
Action: Follow procedures as for Fault Code 249.
Tertiary Source: Motor Control Module.
Action: Replace Motor Control Module.
Apr 27, 2013 | Fisher and Paykel WA37T26G Top Load Washer
Aquasmart Fisher & Paykel
You will need a technician to fix this,
Fisher & Paykel aquasmart washing machine display panel not working
You need to size set the LCD panel to your motor controller.
1. Press and hold the left SCROLL button,Then press HIGH EFFICIENCY button until two beeps are heard.
2. Press the SCROLL button to select machine size
(600 for WL70,650 for WL80).
3. Press the POWER button to set in memory.
Mar 05, 2013 | Fisher and Paykel Aquasmart wl80t65c
Error 105
Try to get a Rotor position sensor as they are cheaper.
105. (01101001) Comms Error Time Out
These faults are reported when the Display Module detects an error in the communications
between the Display Module and the Motor Control Module.
Primary Source: Display Module.
Action: Replace Display Module.
Secondary Source: Motor Control Module.
Tertiary Source: Rotor Position Sensor
Action: Replace Rotor position Sensor. If this corrects the fault refit the
original Display Module and/or Motor Control Module.
Feb 21, 2013 | Fisher and Paykel Aquasmart wl80t65c
May 26, 2010 | Washing Machines
Fisher@paykel aquasmart WL80T65CW1 fault code245 and code49
Sep 03, 2008 | Washing Machines
Washing Machines Logo
180 people viewed this question
Top Washing Machines Experts
