Question about GE Profile 26.6 cu. ft. Side-by-Side Refrigerator with Dispenser TFX27PRBWW
GE profile refrg. with ice maker
Any type of Ice is not coming out when you push on the dispense lever. You only hear lots of noise. Lots of clumps of ice getting stuck out side the ice maker and makes it difficult to open the freezer door. However, inside the ice maker is plenty of ice.
    Sergeant:
    Champion:
  • 330 Answers
Too much ice, maybe the ice maker didn't connect right, the gears moves but the spring inside the ice maker won't move.
Posted on Jul 21, 2008
Ge Profile Stainless Steel 26 ft Refrigerator ice maker dispenser
try pulling out the ice bucket, remove all ice and look for signs of damage on the auger mechanism... most of the time the ice tends to clump up and that prevents the auger from moving freely.
Mar 24, 2010 | GE Profile 26.6 cu. ft. Side-by-Side...
Ge Profile ice maker not working
you either have a bad water valve, which it is sticking open or B. the ice maker is not shutting the valve off.
Apr 12, 2009 | GE Profile 26.6 cu. ft. Side-by-Side...
Icemaker makes ice; door dispenser cranks, but no ice dispensed
sounds like either the dispenser motor is bad or the dispenser yoke is stripped. remove the bucket from the freezer. you will see a u shaped yoke in the rear of the disp area. this should be fairly hard to turn by hand if it turns easily then the motor gears are bad if the yoke slips on the motor shaft then you have a stripped yoke. hope that helps. peyton...
Jan 20, 2009 | GE (PSS26MSRSS) Side by Side Refrigerator
I have a GE Profile side/side refrigerator which was delivered on 4/19/08. When the ice comes down the chute it makes a lot of noise - so much noise that you cannot hear another person speak within the...
Hello azcowgirl19
Welcome to fixya,
You said, You have a GE Profile side/side refrigerator which was delivered on 4/19/08. When the ice comes down the chute it makes a lot of noise - so much noise that you cannot hear another person speak within the same room. Is there anyway that this clattering can be cushioned?
Also, the ice seems to clump up into a large ball and when it tries to go threw the coils, it shakes and rattles the entire appliance. Other than removing the lg clump of ice is there anyway to prevent this?
Yes I do recognize the problem.
The ice maker has a couple of defective parts in it!
Lucky for you you still have a warranty for this GE Profile fridge and did not waste anytime looking into it!
In the USA, Call GE at 1(800) GE CARES , and tell them the ice maker has multiple problems so they can service it while you still have your full parts and labor warranty!
Let me know how it goes!
Please remember to leave a rating at our site before you leave!
Thank You, Huuum
Sep 30, 2008 | GE Refrigerators
Ge profile refrigerator ice maker
I have a GE Profile PSW26P Stainless Steel Side by Side refrigerator that makes plenty of ice but will not dipense when the lever is pushed. The dispenser makes not sound when engaged. What do you think the problem is.
Sep 28, 2008 | GE Profile PSW26P Stainless Steel Side by...
Ice cubes melting then refreezing in clumps
check the flap door to see if it is slightly open letting warm air in
Aug 08, 2008 | GE Profile 26.6 cu. ft. Side-by-Side...
GE profile refrigerator model # TBX25PR
See if ice is jammed up in the tunnel the ice is pushed through.
Will the motor turn the auger with all the ice removed.
Jan 25, 2008 | Refrigerators
Ice dispenser in door clogged up or frozen
I see this a lot with people who mainly used crushed ice.  It will leave small pieces of ice behind and add up to a clogged situation.  If you mainly used crushed ice you will need to run full cubes thru every so often to keep the chute clear.  Another cause of this would be the flapper door on the dispenser doesn't close completely and warm air gets in and melts the ice in the bin so it clumps together and won't dispense.  In this case you may need to replace the solenoid that shuts the door and/or the door.  Let me know what you find.
Oct 15, 2007 | GE Profile 26.6 cu. ft. Side-by-Side...
Refrigerators Logo
327 people viewed this question
Top Refrigerators Experts
Sal De GO PATS
Charles T Nevin
Charles T Nevin
Andrew Taylor
Andrew Taylor
