Question about Acer Aspire 3680 Laptop
Computers power pack - Acer Aspire 3680 Laptop
  • Killswitsh Jan 01, 2011
    Can we have a little morre overview on the problem to have a better understanding please.
  • Gowtam Rajashekar
    Gowtam Rajashekar Jan 01, 2011
    Hi Odeifrancis,
    I would request you to explain the issue more indetail so that I cunderstand and help you with the solution.
    Thank you
    gowtam1402@live.com
    091-9916828137
2005 350z. It cranks, but why doesn't it start?
Check ignition wires, crankcase sensor, ignition coil, computer for spark issue..
Mar 20, 2016 | Nissan Cars & Trucks
My aceraspire4330 wont power on
you can try the power system check by doing the following:
To verify the symptom of the problem, power on the computer using each of the following power sources:
1. Remove the battery pack.
2. Connect the power adapter and check that power is supplied.
3. Disconnect the power adapter and install the charged battery pack; then check that power is supplied by
the battery pack.
If you suspect a power problem, see the appropriate power supply check in the following list:
"Check the Power Adapter"
"Check the Battery Pack"
Unplug the power adapter cable from the computer and measure the output voltage at the plug of the power
adapter cable. See the following figure
1. If the voltage is not correct, replace the power adapter.
2. If the voltage is within the range, do the following:
* Replace the System board.
* If the voltage is not correct, go to the next step.
NOTE: An audible noise from the power adapter does not always indicate a defect.
3. If the power-on indicator does not light up, check the power cord of the power adapter for correct
continuity and installation.
4. If the operational charge does not work, see "Check the Battery Pack"
Pin 1: +19 to +20.5V (Centre pin)
Pin 2: 0V, Ground (Shielding / Surround)
To check the battery pack, do the following:
From Software:
1. Check out the Power Management in control Panel
2. In Power Meter, confirm that if the parameters shown in the screen for Current Power Source and Total Battery Power Remaining are correct.
3. Repeat the steps 1 and 2, for both battery and adapter.
4. This helps you identify first the problem is on recharging or discharging.
From Hardware:
1. Power off the computer.
2. Remove the battery pack and measure the voltage between battery terminals 1(+) and 6(ground).
(Terminal 1 is closest to the edge, Terminal 6 is closest to centre)
3. If the voltage is still less than 7.5 Vdc after recharging, replace the battery.
To check the battery charge operation, use a discharged battery pack or a battery pack that has less than 50% of the total power remaining when installed in the computer. If the battery status indicator does not light up, remove the battery pack and let it return to room temperature.
Re-install the battery pack.
If the charge indicator still does not light up, replace the battery pack. If the charge indicator still does not light up, replace the DC/DC charger board.
Jan 20, 2015 | Acer Aspire One PC Notebook
I switched the Pc on after connecting all cables, the monitor didn't come on thats when i found that the power pack must have died as icould smell a bit of burning. the motherboard light is on ( green )...
most power supply units will fit you can get a larger wattage output eg: heavy duty if you have added any more devices to your computer more RAM,a larger hard drive,more cd/dvd drives these added will put a greater need for wattage output on the PSU
you should check all the electrical connections before you make a decision and make sure they are the same as as the ones that you will need to run your computer also
check the measurements inside the frame to make absolutely sure it will fit
you can get lots of PSU
Feb 24, 2011 | Alienware PC Systems Alienware True 480...
Have a p4 machine doesnt power on when the cpu power connector is connected
this problem is always associated with power pack, i will advice you change the power pack.
May 19, 2010 | Intel Computers: P4 3.0GHz Mid Tower...
Not charging
Remove the primary battery pack and travel battery pack (if applicable) and plug the computer
into an AC outlet using the AC adapter. If the computer starts up, one of the battery packs
may need to be replaced.
if the computer does not start with a/c power connected. ensure the power outlet is providing power, otherwise you problem may be the motherboard, cpu or memory. please provide more details (ex. lights on and color, any beep secuences heard, procedure attempted, age of computer, how the problem came to be)
Apr 19, 2010 | HP Pavilion dv6000z PC Notebook
1800FP green LED is on, screen is black
power pack has issues could be a chip on the power pack or some capacitors on the power pack. the power pack supplies power to the inverter.
Feb 20, 2009 | Dell UltraSharp 1800FP 18.1" LCD Flat...
Acer Laptop Aspire 5050
Hi, you can do a simple check to establish which is at fault, your battery or power pack.
If your computer runs OK on the power pack then the battery is at fault. If the computer will not run on the power pack then the power pack is the cause.
Regards mistyman
Aug 14, 2008 | Acer Computers & Internet
MY COMPUTER IS NOT COMING UP AFTER POWER OUTAGE
when you put the power pack does the power pack roll if yes change the board if does not comes up change the ram if you follow these process am very sure it will work
Jul 17, 2008 | E-Machines eMachines Desktop PC
My Acer keeps loosing power
hmm...sounds like you are suffering from a dirty power issue. how old is your house?
Mar 11, 2008 | Acer TravelMate 2300 Notebook
Power
check the power pack to see if it has the required output voltage, usually 12-15 volts. solidstate power packs are prone to failure. The LCD screens require between 2 and 4 amps to power them. A strain on some power packs. Gary(Honkity Hank)
Sep 18, 2007 | AOC LM929 (Black) 19" LCD Monitor
Acer Aspire 3680 Laptop Logo
12 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
Alun Cox
