Question about Xerox Phaser 8400 Laser Printer
Error message 08,035.42:23057
Shows up every time I power on. Is there a website for a description of the errors? Xerox says visit a support center for everything it seems.
Thanks!
8,035.4x: CAP_FAULT_MOVEUP_STALL
The media path drive module has stalled while moving the wiper down.
Posably a broken tooth in the gearing mechanism as it is out of sync
not something you can fix
Posted on Jul 18, 2008
Xerox problems
Hi Anonymous,
I suspect your question has answer by now.
If not, just visit the www.xerox.com website.
Regards.
Jul 29, 2014 | Xerox STANDARD CAPACITY MAINTENANCE KIT...
Workcentre 7242, it was showing 01-333 fault at first but after correction another error 010-319 how can i sort out this error code
Error 010-333 for this machine is "Fuser Center Thermistor Overtemp (Over temperature) or Overheat Error"
Error 010-319 for this machine doesn't seem to exist (Yes - I know you've got it - hence the problem post.)
Error 010-319 for other Workstation models (7655, 7665, 7675, 7755, 7765, 7775) is "Fuser Heat Control problem *NOTE: This code must be cleared from Diagnostic Mode"
As regards fixing this error the Xerox website should be helpful
Feb 16, 2014 | Xerox Office Equipment & Supplies
On the 8560, what does the error code 07,010.43:14070 mean??
In the Xerox support website that error indicates that the printer needs to be turned off and call for xerox assistance. Does not specify the problem.
Although, this website refers to this problem.
http://www.fortwayneprinterrepair.com/wordpress/2011/09/25/xerox-phaser-8400-8500-8550-8560-07010-43-error-message/
If the printer has only one year old, the best solution will be to call for xerox assistance because it is under warranty.... I think...
Aug 08, 2012 | Xerox Phaser 8560MFP Laser Printer
13387.48:16806 error code on Xerox Workcenter C2424
From the Xerox Solution center --
Solutions for : Fault Codes 13,XXX.4X: Thermal Error Related Fault Codes: 13,xxx.4x Solutions ranked by relevance:
  1. Make Sure the Room Temperature is Within Operating Temperature Specifications
  2. Make Sure the Power Source is Not Causing the Behavior
A previous firm I worked at had these units. Do not plug them into a surge protector of backup power supply system.
Mar 22, 2011 | Office Equipment & Supplies
What is the Xerox Phaser 8400 printer error code 07.010.43:43923? Much appreciated. Thank you.
Try this:
The printer has encountered an error state without the benefit of a code. Turn the printer off for 30 seconds, then power back on.
If the Printer Error message returns, press the i button on the printer's front panel. The actual error or fault number should be displayed. Note the error or message and search the knowledge base for the error.
Also:
Based on the problem description provided, we have determined that your printer needs service.
Please turn your printer off and use one of the methods below to make arrangements for service:
If using the local service provider website, please perform the following steps:
  1. Enter your zip code in the space provided.
  2. Choose a mileage distance. The search will locate a Service Provider within the specified range if available.
  3. Click Go. The web site will return a list of Authorized Service Providers (ASP) with their company name, address, phone number, and fax number.
Feb 12, 2011 | Xerox Phaser 8400 Laser Printer
7,010.43:40975 error message for the Xerox Phaser 8500 printer.
The printhead is stuck in the tilted position. Did you have a power outage or turn it off by unpuging it? Not hard to fix but you have to tear it down and rehome everything. sometimes if you turn it off and turn it back on it will find home on itself. But rehomeing it works every time. If you dont know how to do this call a service center.
Apr 28, 2010 | Xerox Phaser 8500/DN Printer
Error code 07.009.42 what should I do?
07,009.42 Error indicates that the printhead was unable to tilt normally on its axis.
This is most likely caused by a cracked drum maintenance camshaft. The drum maintenance camshaft is driven by the process drive motor on the right side of the printer. It raises and lowers the maintenance kit against the drum to oil and clean the drum. The camshaft has 2 lobes on it. These lobes crack over time and cause several different error conditions. The camshaft part # 401100380 is only about US$20 from Xerox but can be very difficult to replace. Also look at the pivot plate assembly. Slide out the drum maintenance kit. If you look inside the cavity the plate that the maintenance kit sits on is called the pivot plate. If the drum maintenance pivot plate is white plastic it should also be replaced with the new style black plastic plate. This requires removing the process drive gears assembly. Note that reinstalling the assembly requires the gears to be accurately timed. This repair should only be performed by a qualified technician.
Mar 24, 2010 | Xerox Phaser 8400 Laser Printer
Xerox PE220 workcenter shows LSU Error message.
XEROX WORKCENTER PE220 , ITS SHOWING LSU ERROR . ITS NOT PRINTING OR COPYING ANYTHING . PLEASE GIVE SOLUTION
Dec 17, 2009 | Xerox Phaser 8500/DN Printer
Xerox DC12 Error code 9-355
That is a magenta toner empty message, either the magenta is empty of there is an issue with the magenta toner dispencing.
May 07, 2008 | Xerox DocuColor 12 Color Copier
Standard Deviation
I want to calculate a standard deviation on BA II plus
Apr 23, 2008 | Texas Instruments BA-II Plus Calculator
Xerox Phaser 8400 Laser Printer Logo
511 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
