Question about Wurlitzer Crosley WR18 Mini-Bubbler CD Player CD Player
Hello... I have a Crosley jukebox that has neon tubes and bubble tubes. I've noticed recently that the right top bubble tube isn't bubbling as well as the other three. The bubbles don't even make it 1/2 way up the tube anymore.. but are still bubbling. The vacuum space is still there. Any idea what the issue could be?
  • 211 Answers
SOURCE: Wurlitzer OMT CD Jukebox
It's a blown fuse on the amp.
You have to undo the cover plate at the top and then flex it to unhook the bottom. Once it is off you'll see the fuses.
Posted on Jan 01, 2009
  • 98 Answers
SOURCE: The fluid leaked out of one of the tubes that
I can sell you a replacement bubble tube. They are fairly easy to replace. I just need to know which one you need, straight, small curved or large curved. Rod Stebelton, tech@wurlitzer-ohio.com.
Posted on Dec 24, 2009
Testimonial: "It was the answer I needed to fix my problem. Thanks! "
  • 98 Answers
SOURCE: I broke one of the glass bubble tubes. How can I
I have bubble tubes in stock. You just need to tell me which one you need. I can tell you the replacement procedure also. Please email tech@wurlitzer-ohio.com.
Posted on Feb 07, 2010
SOURCE: How do i replace lights on bubble tubes? They
You can order bubble tubes and damaged front plastics from Deer Park Dist (618) 427-3761. Once you get the parts, remove the back of the unit. You will be able to see all the screws which hold on the front plastics. Removing the screws and the plastics to get easy access to the bubble tubes. A long screwdirver is helpful. The magnets in the speakers will grab the screws and the screwdriver from you.
Posted on Nov 02, 2010
bayyagg
  • 1672 Answers
SOURCE: A couple of the bubble tubes are no longer
Hmmmmm...........
First open the back panel and check if the air pump still works!
There might be disconnected air hoses gong to those tubes!
Check first,,,,, then tell wut u notice!
Hope that clears the air of trouble!
Posted on Dec 04, 2010
How do i take a broken bubble tube from front left side, out and put a new one in,
Undo the 3 'metal' bands by unscrewing from the back. Then squeeze the top of the plastic and pull. It fits like a tyre in a slot on each side. Then you can get to the bubble tube.
May 13, 2011 | Wurlitzer Jukebox 1015 One More Time...
The bubble tube is broke
Hello brittpierce,
Remove the broken tube ASAP and clean off any oil from the surfaces to avoid staining.
Check out www.victoryglass.com for a spare part or contact a Wurlitzer distributor in your country.
Regards
Alan Hood
ami-man
UK
Apr 07, 2011 | Wurlitzer Jukebox 1015 One More Time...
Rock-ola cd jukebox bubbles wont bubble?????
They are probably made like the old Christmas tree bubble lights. These had a solution, I think it might have been calcium chloride and they were heated at the bottom end of the tube by an incandescent lamp that ran pretty hot. The lamps in your unit might be burnt out. I remember we had to tap the tubes lightly to get them to start bubbling sometimes.
Feb 16, 2011 | Wurlitzer Rock-ola Jukebox
How do i replace lights on bubble tubes? They bubble but no lights.
May 12, 2010 | Wurlitzer Crosley WR18 Mini-Bubbler CD...
I broke one of the glass bubble tubes. How can I get an replacment tube for my 1015 One More Time Black Onyx juke bos
Feb 04, 2010 | Wurlitzer Jukebox 1015 One More Time...
The fluid leaked out of one of the tubes that bubbles
Dec 18, 2009 | Wurlitzer Jukebox 1015 One More Time...
Hi the bubbles have stopped working on the right side, what can i do to resolve ?
If both bubble tubes has stopped working on one side then the problem is more likely to be a power issue. Somehow the power is not getting to the tube heaters. On the Wurlitzer OMT there is a small module on the inside of the main door that distributes the power to the various bubble tubes and the page turner (CD models). If the plug is loose or the wire is broken then that could cause one side to be off.
Nov 01, 2009 | Wurlitzer Jukebox 1015 One More Time...
Going to move my Wurlitzer 1015 300 miles. What do I have to do to stabalize the unit on the inside? Ron
If this is the original 1015 jukebox from 1945/46, plays either 24 X 45RPM or 78RPM records, then you need to remove all the records and their trays, secure the tone arm with some tape to its post, make sure the amplifier is locked in place, and then I would put an old sleeping bag or similar (pillow) into the space to the right of the record stack to prevent the turntable platter from banging up when you lay the machine on its back for transportation. Put a bit of tape on the straight bubble tubes to stop them from sliding out of their heaters - do this at the top of the tube and just leave the tape in place permanently.
When you arrive, first make sure that all the bubble tubes are in place, seated in their heaters, then check for loose parts, check the amp's tubes are seated, remove pillow, remove tape from tone arm, load records, cross your fingers and turn it back on.
Oct 15, 2009 | Wurlitzer Jukebox CD Player
Wurlitzer Crosley WR18 Mini-Bubbler CD Player CD Player Logo
51 people viewed this question
Top Wurlitzer Audio Players & Recorders Experts
phil
Donald Chadwick
Donald Chadwick
Level 1 Expert
Are you a Wurlitzer Audio Player and Recorder Expert? Answer questions, earn points and help others
