Question about Sony Playstation 3 (PS3) Console
I am trying to get an internet connection with my PS3 so I can play online. I went to network settings and I set it all up manually. I go to test the connection. "Obtain IP Address" succeeded and so does Internet Connection. It then fails at PlayStationNetwork. Is there any thing I can do to fix that?
  • 492 Answers
Yep, and it likely tells you that you need to set your NAT to Type 2, right? This Guide here will show you (with text and images) what you need to do to set your NAT from Type 3 to Type 2:
http://www.pregamelobby.com/ps3-ps2-psone-discussions/5618-how-get-type-2-open-nat-your-ps3.html
Posted on Jan 01, 2011
How do you connect the PS3 to internet (wireless)????
First power on your PS3 , TV , & Router ( if you own the internet connection your going to connect to ) . Then select your User ID upon login . Scroll Left till you hit the Settings Menu , scroll all the way to the bottom & select Network Settings . Now select Internet Connection Settings , select Easy , Wireless , Scan . Now select your Wireless Network from the list that appears , confirm the SSID ( network name ) , & the type of Security Setting ( if you don't know connect a PC to the Wireless Connection & you can see the proper settings there ) , Enter a WPA Key or other type of Encryption if neccesarry , now confirm & test your Connection . It should run through a series of tests from connecting to the network , to a speed test . If all went right you should now be online & ready to game .
Apr 15, 2011 | Sony Playstation 3 (PS3) Console
New play tv wont work via remote play on my psp
To make Play TV on the PSP via the Remote Play work
watch the instructional video here
and detailed information here in full-color
be aware that this whole thing depends on the firmware version of both PSP and PS3
Sep 27, 2008 | Sony Playstation 3 (PS3) Console
Getting error code 8071053d tried rebootin ps3 and internet not working still wont let me play online
The error code indicates that the PS3 is unable to contact the Playstation Network Servers. This may be caused by the PSN (Playstation Network) being under excessive load (often a result of new, significant DLC being released) or a problem with your router or ISP (Internet Service Provider).
  • On your Playstation 3, go to the Settings menu, scroll down to the bottom and select Network Settings, then select Internet Connection Test. If you do not see success for Obtaining IP Address and Internet Connection, then there is a problem with the networking between your PS3 and the internet.
If you both of these connections prove successful, but you are still not able to sign in to the PSN, try:
  • Contact your ISP and see if they have some sort of outage in your area or are somehow hindering your connection to the Playstation Network.
Mar 13, 2011 | Sony Playstation 3 (PS3) Console
What do I need to connect the PS3 to the internet so my boys can play online ? Hardline or will WIFI work ?
Any of the two will work it all depends on preference. If the modem or router is too far from the console then you would most likely want to go wireless. Here are instructions how to do each:
WIRELESS (WIFI):
Step 1: Turn on the PS3
Step 2: Once on main menu go to settings and under settings select "Network Settings"
Step 3: Select "Internet connection settings" if prompted that you will be disconnected from the internet select "Yes".
Step4: Select "Easy" on types of installation.
Step 5: Select "Wireless" to choose what kind of internet connection you want.
Step 6: Select "Scan" to search for internet access points.
Step 7: Select your home connection when the screen comes up with all the found access points. If your home Internet access point requires a password enter the password when prompted and save your settings.
Step 8: Test the connection to check if you configured your settings right if successful you are good to go. If not go back and check your connection settings for your home internet access point. You are now connected to the internet!
HARDLINE (Wired): Must connect ethernet cable to PS3 before turning it on!
Goes like this: Arrows are the cable (===>)
Internet Line ===>Router ===>PS3
Step 3: Go to "Internet Connection" and select it to Enable it.
Step 4: Select "Internet Connection Settings"
Step 5: Select "Internet connection settings" if prompted that you will be disconnected from the internet select "Yes".
Step 6: Select "Easy" on types of installation.
Step 7: PS3 will automatically check your connection network setup and set the settings for you.
Step 8: The settings will appear and press x to save the settings.
Step 9: Test your connection if it was successful you will see succeeded nest to "Obtain IPAddress" and "Internet Connection" you are now connected to the internet!
Feb 26, 2011 | Sony Playstation 3 (PS3) Console
Have problem going online, after inputting all info the first time it logged on fine and a atomatice update took place. But after that, the next time i switched on and the ps3 try to log online , a error...
Once you have all the wireless settings of the router, you are ready to connect the play station or the x-box to the wireless network.
Play Station
Now go to the settings page of the PLAY STATION
NETWORK SETTINGS ==>
INTERNET CONNECTION SETTINGS ==>
WIRELESS SETTINGS ==>
If you get confirmation screen displayed stating that you will be disconnected from the Internet. click YES ==>
select EASY ==>
select WIRELESS ==>
SCAN ==>
you will see your SSID ( wireless network name)==>
select the security settings ( router wireless settings)==>
enter the KEY ==>
select the IP address settings EASY ==>
save your settings ==>
Test the connection .
Jan 23, 2011 | Sony Playstation 3 (PS3) Console
Cant get online when i run a test it fails on playstation net work then afterwards says you have been disconnected from media server
If you are using a router, the problem probably has to do with the router. In order to find out, disconnect your PS3 from the router and plug it directly into you modem. If your modem is not near your playstation 3 then move it close to the PS3. The modem plugs directly into your cable line so there is a good chance that the television you play your PS3 on has a cable connection. One you have connected your PS3 to your modem, press the reset button on the modem. Turn your PS3 on and go directly to your network settings. Click on Internet Connection Test (do not bother trying to set up a connection manually) If you are getting a connection then you are ready to go.
Thank you!
May 18, 2010 | Sony Playstation 3 (PS3) Console
Had my ps3 for year and half now, never played online (80710102)
Ok first off create a psn account online via computer, this is free of charge. Then after that connect your ps3 via cable to your modem. turn it on and access network settings. Then select internet connection settings, select easy. After it is finished select test connection. Should this time out it means you have a faulty connector somewhere, try checking your cables and the ports on the ps3 and modem. But if it states connected, back out and go to network via your ps3 dashboard then select sign in and enter your account info from your psn account.
Dec 08, 2009 | Sony Video Game Consoles & Games
Can't get internet on ps3
Okay, i'll see if i know what we're talking about here. There are a couple of things you could try. For one, try logging into your router, (usually at 192.168.0.1 and looking in the Client or Address lists for a PS3, or whatever you have named it, and then see if you can either disconnect or renew it. Then, redo the whole WiFi setup on the PS3 setting all the settings as you would but leave the IP settings as they are (should be Auto). If that still doesn't work, go into the PS3's connection settings and manually set an IP address. My suggestion is to use the same address as an already connected (and working computer), but change the last number. Whatever you do, make sure there are not two of the same IP address on the router. Hope this helps...
Nov 08, 2009 | Sony Playstation 3 (PS3) Console
My ps3 will not connect to my wireless internet
Try setting a static ip address on the PS3:-
First you need to find a Windows wired or wireless device already connected to the network in order to find out the required settings
Windows XP
1. Click start --> (sometimes settings) --> Control Panel --> Network Connections
2. Double click on the active connection which will say connected underneath
3. Click Support
4. Click Details
5. Now the IP Address, Subnet Mask, Default Gateway, Primary DNS and Alternate DNS which are displayed should be noted.
Windows Vista
1. Click Start --> Control Panel --> Network and Sharing Center
2. Click on "View Status" to the right of your connection
4. Click Details
Set these values under "manual settings" in the PS3 but add 1 to the last number for the IP Address as this has to be unique on your network
Jan 04, 2008 | Sony Playstation 3 (PS3) Console
PS3 Internet Connection/Upgrade System/Online Play
Do an internet connection test. Your NAT type should be either 1 or 2. If not then there are some restricted ports on your router.
I find that putting your PS3 in your router's DMZ (demilitarized zone), solves all connection problems.
Dec 11, 2007 | Sony Playstation 3 (PS3) Console
Sony Playstation 3 (PS3) Console Logo
107 people viewed this question
Top Sony Video Game Consoles & Games Experts
Zhenya Ogorodnikov
shaun taylor
marley mcelhinney
Are you a Sony Video Game Console and Game Expert? Answer questions, earn points and help others
