Windows will not install restart the error code oxo
    Problem Solver:
  • 5 Answers
Hi, Please type the full error code, also please advise if you are seing a blue screen?
Posted on Jan 01, 2011
What battery does an OXO small kitchen timer need?
I'm assuming you're referring to OXO's Magnetic Digital Timer model #1127980. The instructions require a CR2032 (coin-type) battery which is accessed by gently prying the battery cover off with a coin. You can download the instruction booklet here:
http://www.oxo.com/download/1183_gg_1127980_booklet.pdf
Jul 12, 2014 | Oxo Hardware & Accessories
How do I restart my dell- oxo error has now reset user and I don't know password?
You must login in with the administrators account to change other users passwords or retrieve them. If you don't know the administrators password you may have to start from scratch and re-install the O/S.
May 15, 2014 | Computers & Internet
OXO food scale shows erh code
I am having the same problem with the 5lb scale. Turned it on for the first time about 5 days ago and was ok. This morning when I went to use it it gave the ErH code. Would appreciate if any person has an answer. I am waiting for OXO to respond my e-mail.
Apr 14, 2013 | Oxo Good Grips 11-pound Digital Kitchen...
Error code OxO
Download The following iso listed below. It is the latest version of the Kaspersky rescue disk. You need to burn it to a CD with a program like Imgburn (Which is also FREE like the iso file). Then you need to boot from the CD and run the scanner. It should fix you right up.
Kaspersky rescue cd download:
http://majorgeeks.com/downloadget.php?id=6501&file=1&evp=ef4247319d4b536cb88b74d1ae4842b0
Imgburn download:
http://majorgeeks.com/downloadget.php?id=4870&file=15&evp=0636b68877cb69b15faa3374cb1dcd89
Aug 17, 2012 | Microsoft Windows vista ultimate SP2 OEM
Startup repair error code oxo
Download The following iso listed below. It is the latest version of the Kaspersky rescue disk. You need to burn it to a CD with a program like Imgburn (Which is also FREE like the iso file). Then you need to boot from the CD and run the scanner. It should fix you right up...
Imgburn download:
Aug 17, 2012 | Computers & Internet
Cant make MSN video call just get :error OXO
That is common problem with Windows live that happens on some pc's, no need to worry! :) Just uninstall that version and install older one, for example install Windows live messanger 8.0 or above and it will work! :)
And please rate my solution, thx :)
Apr 17, 2011 | Computers & Internet
The drivers for this device are not installed. (Code 28)
  1. Restart your computer if you haven't done so already.
    There is always the slim chance that the Code 28 error you're seeing in Device Manager was caused by a fluke with Device Manager or in your BIOS. If that's the case, a reboot might fix the Code 28.
  2. Did you install a device or make a change in Device Manager just before you noticed the Code 28? If so, it's very possible that the change you made caused the Code 28 error.
    Undo the change, restart your PC, and then check again for the Code 28 error.
    Depending on the changes you made, some solutions might include:
  3. Update the drivers for the device. Installing the latest manufacturer supplied drivers for a device with the Code 28 error is the most likely solution to the problem.
    Important: Make sure you install the drivers for the correct operating system. For example, if you're using Windows 7 32-bit, install the drivers designed for that specific version of Windows. Many Code 28 errors are caused by attempting to install the wrong drivers for a device.
  4. Install the latest Windows service pack. Microsoft regularly releases service packs and other patches for their operating systems, one of which may contain a fix for the cause of the Code 28 error.
    Note: I do know that certain service packs for Windows Vista and Windows 2000 have contained specific fixes for some instances of the Code 28 error in Device Manager.
  5. Replace the hardware. As a last resort, you may need to replace the hardware that has the Code 28 error.
    It's also possible that the device is not compatible with this version of Windows. You can check the Windows HCL to be sure.
    Note: If you still think there is still a software/operating system component to this Code 28 error, you could try a repair install of Windows. If that doesn't work, try a clean install of Windows. I don't recommend doing either of those more drastic options before you try replacing the hardware, but you may have to if you're out of other options.
Mar 01, 2011 | HP Computers & Internet
Error: code0x80070017
When you install Windows 7 (or Vista) you may get the following message:
Error 0x80070017 Windows cannot copy files required for installation. These files may be corrupt or missing. Make sure all files required for installtion are available, and restart the installation Error code: 0x80070017
This can be displayed with error code 0x80070017 or error code 0x80070570 in Windows 7 or Vista
The cause is very simple and you can probably guess from the error code in the screenshot above. The cause is that Windows cannot verify the files.
Simple Solution
  • Burn or get a new copy of the disk (Burn at a slow Speed 2x and use a quality media like (Verbatim)
  • Or if you have a current Windows installation you can install from the hard drive or from a USB drive
Check out my article on installing Windows 7 using a USB Key USB-stick-from-windows-xp/">Install Windows 7 from USB Drive
Dec 25, 2010 | Computers & Internet
Error code 10 Device cannot restart
Generally a code 10 refers to a dead component unfortunately.Although the card will be recognised.
Aug 29, 2006 | U.S. Robotics MAXg USR5417 802.11g/b...
Computers & Internet Logo
198 people viewed this question
David Payne
David Payne
