Question about Matsushita Computers & Internet
Our Matsushita NAIS PLC FP1-C40 showing Program LED lit. What is the procedure to put PLC back in to RUN mode.
4 Suggested Answers
e-Guru
  • 3917 Answers
SOURCE: How can I download the PLC software program from a SPC120s PLC?
Check this site. They assist with the download:
http://www.ttintl.com/english/contactdemo.html
Thanks
Posted on Dec 26, 2009
  • 760 Answers
SOURCE: when i download the hw conf. in the plc im151
Re-check your hardware configuration.Make sure you correctly configured each slot ast to the type of hardware that is there. Make sure your program is not calling for a function (block transfer etc) to a module that isn't there.
Posted on Jul 25, 2010
yashthakkar
SOURCE: We are facing one problem
Sir, Please Check the PLC coding..........
Posted on Aug 09, 2011
Try to program and it comes error L5
PAGE 63-64 in link Describe "LS" error.
7
Belts stop turning and "err
LS" or "err OS" is displayed
Calibration
Re-calibrate machine. (See Calibration Procedures, Pg 26)
SPEED
SENSOR
1. Cycle power off and on
2. Put the machine in calibration mode (see Calibration
procedures, Pg 26) but do not start the calibration routine.
3. Remove right rear base plastic cover to allow access to
LED board. Caution: Machine is on. Current is active!!
4. Locate LED D on the motor controller board. LED may
be lit or unlit.
5. Manually advance the treadle with your foot, and check
if LED D is blinking.
6. If LED D is not blinking, then the speed sensor is not sup
plying a signal. Check that the speed sensor is connected
securely to P1 on the motor controller. If sensor is con
nected and LED D still does not flash replace sensor.
I/O cables
If LED D is flashing when the belts are turning but err LS
or OS persists, check for signs of visible damage to any of
the three I/O calbes and connections. If no visible damage
check continuity using a multi-meter. If a multi-meter is
not available replace all three cables.
Electronics
If all I/O cables are functioning properly, LED D indicates
speed sensor is functioning, and err LS or OS persists
problem is in either the upper electronics board or the
motor controller board. With machine on check LED A
on the controller board. If it is dimly lit replace upper
electronics (000-4430). If it is not lit at all replace motor
controller.
http://download.nautilus.com/supportdocs/AM_OM/Bowflex/BFX_TC5300_6000_OM_AM_RevA_web.pdf
Jun 04, 2014 | Bowflex Treadclimber TC5300
This machine was spinning with an uneven load and stopped working so I emptied the machine and took it apart. I found the shock absorber on the tub needed to be put back together so I fixed that problem...
The error E68 means the ccu has sensed a stuck button on the console. MANY times this is a false error and means that either the ccu or interface must be replaced, but SOMETIMES, there really is a stuck button. TRy to run a diagnostic using the instructions I have provided below, let me know if you need any help with it.
1. Press and hold Select and Cancel buttons simultaneously for 6 seconds to reset the control. The buzzer will sound
1 time and "rES" will be shown briefly in the display.
2. Immediately after, rotate cycle selector knob 5 turns counter-clockwise to the second position from the bottom.
Press and hold the Options and Cancel buttons simultaneously for 2 seconds. The control will enter test mode,
the buzzer will sound 3 times and all LED's will rapidly flash.
After entering the test mode, the cycle selector knob can now be rotated to select the following tests:
Rotate the cycle selector knob clockwise from the starting position:
0 turns: All LED's will flash.
1 turn: Drive motor runs; heat source is on. Drying LED is lit. "H" and the control thermistor reading will toggle
back and forth in the display.
2 turns: Drive motor runs; heat source is off. Cool Down LED is lit and "AF" (Air Fluff) is displayed.
3 turns: Drive motor runs; heat source is off. Drying and Cool Down LED's are lit and numbers appear in the
display showing moisture sensor readings. Opening the door (press in on door switch plunger) and placing
a finger on the both moisture sense bars at the same time will make the numbers decrease. In controls that
do not have a digit display, the More Dry LED should be ON. Opening the door (press in on door switch
plunger) and placing a finger on the both moisture sense bars at the same time will make the Damp LED
come on.
4 turns: Drive motor runs; heat source is off.
Key test:
a. When the Temperature key is pressed, all the temperature LED's should light.
b. When the Dryness key is pressed, all the dryness level LED's should light.
c. When the Options or Select key is pressed, all the Option LED's should light.
d. When the Start/Pause key is pressed, all the cycle status LED's should light.
e. When the Cancel key is pressed, all the cycle status LED's should light.
5 turns: Drive motor runs; heat source is off. Cool Down LED is lit. Control thermistor reading is displayed.
6 turns: Drive motor runs; heat source is on. Drying LED is lit. Control thermistor reading is displayed.
7-11 turns: All LED's will flash
To EXIT test mode, press and hold the Select and Cancel buttons simultaneously for 6 seconds or disconnect power
from dryer. Dryer will be reset for regular operation.
If you cant even enter this mode at all, your interface will have to be replaced. There is no way to determine whether its the intrface OR ccu, but in my experience, it's usualy the interface that ends up needing replacement. Here is the part to order.
Nov 10, 2012 | Frigidaire Affinity ATF8000FS
Need the wiring diagram for the FP1 Header on LGA775 672M01-1.1-8EKSH DDR2 SATA Motherboard
http://www.ascendtech.us/foxconn-lga775-672m01-1-1-8eksh-ddr2_i_mb4672m0118eksh.aspx
Better photos,
http://www.ebay.com/itm/FOXCONN-LGA775-672M01-8EKSH-DDR2-SATA-PCIE-MOTHERBOARD-/250896116650
Go to the photo under the Specifications. Shows a Top view, and the Front Panel header. (FP1)
Note the colored areas on FP1 for the different contact pins.
The pins in the Red area should be for the Power On switch.
Suggest take an LED with two wires, and Briefly touch those two pins.
Power supply comes on touch the pins in the other colored areas.
1) LED light stays on? That's the two pins for the Power On LED.
2) LED light blinks? That's the two pins for the HarDDrive activity LED light.
3) Computer restarts? That's the two pins for the Restart switch.
(IF a Restart switch is used)
Regards,
joecoolvette
(Voltage used? 5 Volts DC
In comparison two D cell flashlight batteries store 3 Volts DC )
Oct 15, 2012 | Computers & Internet
When i download the hw conf. in the plc im151 pn/dp after that plc mode is in stop and all modules sf led glowing(group error) Please tell me the solution
Mar 09, 2010 | Siemens ENERGY & AUTOMATION W0404MB1200CT...
Need codec (?) so that I can playback video files taken with my Xacti C40
I use VLC from www.videolan.org that is a free and open source software.
May 12, 2008 | Sanyo Xacti C40 Camcorder
Where is the FP1 connector on the Foxconn 945G7MA-8KS2?
Hi Sean, FP1 front case connector is located below the battery, bottom right hand corner.
To download you're manual click on this link.
http://www.foxconnchannel.com/support/downloads.aspx?ProductModel=945G7MA-8KS2&TypeID=en-us0000001
Motherboard layout is on Pg. 5
Front Panel Connector: FP1
(Please refer to the 18th item of motherboard layout.)
This motherboard includes one connector for connecting
the front panel switch and LED indicators.
Close up of FP1 found on pg. 15
If I can be of more service, just post & let me know how thing go.
Enjoy!
Mike
Apr 29, 2008 | Foxconn (945G7MA-8KS2) Motherboard
Sanyo plc se15 no light output
i all,hoping you can help with my problem.Ihave been given a sanyo plc se15 projectoe but with no lamp originally,the "lamp"indicator and "lamp replace indicator"were originally lit but when i have installed a new(23hrs use previously) lamp i have no light output and these 2 indicators are still lit! what voltage should i have on the lamp terminals(i a fully qualified electrician btw) is there some sort of reset procedure as i dont have any instructions etc
thanks in advance for any help
Mar 05, 2008 | Sanyo PLC-SW30 Multimedia Projector
Canon printer mp150
can you try to reset, here are the steps
Mp150
Reset Counter
Service mode operation procedures -
1) With the printer powered off but connected to a power source, press the Power button while pressing and holding
the Stop/ Reset button.
2) When the Power LED is lit, press the Stop/Reset button two times while pressing and holding the Power button.
3) When releasing the Power button and the Stop / Reset button (regardless of order), the printer will move into a
service mode. (Waiting for menu selection)
4) When the LED lights in green, press the Stop/Reset button the specified number of time(s) according to the
function listed in the table below.(Each time the Stop/Reset button is pressed, the LED lights alternately in
orange and green, starting with orange.)
The number of the Reset
button pressing
LED Function Remarks
0 time Green Power off
1 time Orange Service pattern print
2 times Green EEPROM print
3 times Orange EEPROM reset
4 times Green Waste ink counter reset See waste ink counter reset
procedures below.
5 times Orange Destination setting See Destination setting
procedures below.
6 times Green Print head deep cleaning
11 times Orange Button / LCD checking
12 or more times Returns to a menu selection
Feb 08, 2008 | Canon PIXMA MP150 All-In-One InkJet...
Computers & Internet Logo
375 people viewed this question
Top Matsushita Computers & Internet Experts
John Anderson
John Anderson
Shaukat Bhutto
Level 1 Expert
Are you a Matsushita Computer and Internet Expert? Answer questions, earn points and help others
