Question about Toshiba Satellite L500 Series Notebook
Key board wont always work sometimes if I remove the battery it comes on now the mouse isnt working properly when I do get the keyboard working and use the mouse it makes the writing on the screen either go smaller or larger
    Brigadier General:
  • 8,909 Answers
Ensure you have no virus in the laptop and after running Norton Anti Virus or Windows Essentials, go online to www.toshiba.com and download updated drivers.
That will fix your problem.
Posted on Jan 01, 2011
I have a micro kb985w mouse and key board and they are not working. How do I fix the problem? Thank you
1.check all batteries.
2. press the connect in the proper sequence. base, mouse , then base, keyboard. (should be listed in the manual) sometimes its base, mouse , keyboard.
3. hook up a old keyboard to boot into windows before you try using the keyboard mouse. (you can run two sets at the same time without an issue)
Aug 25, 2010 | Micro Innovations Wireless...
Logitech CE0560 keyboard and mouse; first keyboard
First put new batterys in the mouse and key board. if you don't have a tester use a flashlight. pen light. push the remote pickup. light will blinknext push key board button and the mouse next. then try it and see if it works.
sometimes do the mouse first, Then the key board
Aug 10, 2009 | Computers & Internet
My mouse batteries died and since then hasnt worked.
check your batterys with a flashlight after that push the buton on your recever. then push the keyboad reset and last do the mouse. if that don't do it switch and do the mouse first then the key board. keep close to the recever it works better
Aug 04, 2009 | Lenovo Mini Wireless Laser N10 Mouse
How to turn keyboard and mouse on
make sure there is new batteries in both the mouse and keyboard. Also the wireless receiever that connects to the computer is responding as well.
After you get new batteries put in and also have the receiever plugged in. press the caps lock, num lock keys and see if they light up on the receiver. If they light up then things are working, if they don't then bring up the notepad and see if any of the keys show up in notepad when you type and also see if the cursor on the screen moves for your mouse.
Hopefully both of them will work once you change batteries. If both don't work after changing batteries then you'll need to get a new wireless keyboard/mouse kit.
Jun 29, 2009 | Logitech Wireless Access Duo Optical...
Mouse pad and keyboard wont do any thing, i can plug in a wireless mouse and the mouse will move but the key board still doesent work
Good morning! please check/review the cable connector connections of you're mouse & keyboard, it might be interchanged to its proper port terminal. If still not working, try to use another mouse & keyboard. best regards
May 09, 2009 | Computers & Internet
My wireless dell mouse isnt working I changed the batteries and still the cursor isnt moving?
there is usually some sort of connect button on both the mouse and then receiver unit that is plugged into the computer, sometimes you have to hold down the connect buttons on each unit simultaneously so that they will connect, i dont know if you have done this or not, otherwise it is always possible that you have a bad mouse, if this is one of those usb wireless mice try moving the usb receiver to a different port and let windows reinitialize it
Feb 20, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Logitech LX310 keyboard / mouse (wireless)
Firstly, try changing the batteries in the keyboard.
If still has issues, try moving the receiver to another area. Try to remove from other sources of interference such as Monitors, Speakers and Power Supplies.
If this doesn't work, try using a non-wireless mouse, and see if the keyboard still has issues.
If all this fails, then I would consider replacment.
Oct 20, 2008 | Logitech 967437-0403 Keyboard
How to make logitech keyboard & mouse work??
Hi there: I was also facing the same problem. But when you see on back of the keyboard the instructions are there. or follow these steps.
1. insert new batteries both in keyboard and mouse. 2. decide what device you want to connect 1st (Lets connect Keyboard first) 3. Pres and Hold the connect button for both key board and receiver for about 5 secs. 4. don't press any key on key board till 10 secs (During this time it trying to connect with receiver) 5. Check the key board connectivity if it works then take it away or put it behind some barrier so that when you are connecting the mouse it don't interrupt. 6. now for the mouse do the same process as you have connected the keyboard.(step 3 & 4) 7. now check both key board and mouse they will work fine. Thanks
Sep 21, 2008 | Logitech 967461-0403-PK Keyboard/Mouse
Keyboard wont work on my dell desktop
check out for the key board pins wheather its good,and its connected properly,check out the green led in the keyboard wheather is glowing or not ii the light is not glowing then its not getting the power supply remove the pin and connect it again ...if u still face the prob change the keyboard
Apr 04, 2008 | Logitech Cordless Desktop MX3200 Laser...
Keyboard problem
in my opinion.your boards ps2 and serial port are not woking properly.(there may be short on pins) if u have U S B card u can stall in pc slot of you board. where u can connect usb key board/mouse and other deviouse.
Aug 23, 2007 | Toshiba Satellite R15-S822 Tablet PC
Toshiba Satellite L500 Series Notebook Logo
81 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
