Air con aint working its pushing out hot air not cold???
  • 472 Answers
Need more info have you changed thermostat lately or done anything to it... if not make sure you have checked breakers and all are good no tripped breakers... on some homes by code it is required to also have a breaker or disconnect outside next to outdoor unit make sure it is good... is your outside unit running and if so is the larger of the two copper lines cold if not and outdoor unit is running then one of two probels you either have a leak and freon has leaked out or your compressor is not starting either due to a bad capacitor or wiring on compressor may have burnt at the compressor terminals.... good luck
Posted on Jan 01, 2011
Cruze - hot air from driver side and cold from passenger
Do yourself a favor an take it to repair shop before you mess it up or hurt yourself !
May 14, 2015 | Cars & Trucks
Ac fan works but does not get cold
Check the air con drive belt is still OK.
Check to see if there is a slight change in the engine sound when the air con is switched on and off while idling - I'd get someone to do the switching while I listened under the hood.
If there's no change in sound (assuming whatever had to be switched on to enable air con to go, eg fan was operating) I'd check the fuse(s) for the air con.
If the fuse is ok, and you've already charged up the freon (not quite sure what you were saying there), I'd be taking it to an air con specialist.
May 26, 2014 | 1995 Buick Century
Air conditioning wires getting hot
It is not the fuse, it is caused by high resistance in the circuit, rewire the AC circuit with a stand alone fuse.
Apr 24, 2012 | 1988 Renault 21
Audi A3 2tdi 2005 - hot air, cold air and air con not working -
You may need to reset basic settings for the control module using a scan tool , reading the logged faults stored in the control module is needeed also .
Jun 24, 2010 | 2005 Audi A3
I have a peugeot 307 sport disel with dual climate control. The drivers side is working fine. The passenger side only blows warm air. It looks like the dial dosnot work. Thi shappend when the blow fan and...
behind the dash at either side are small motors for opening and closing flaps to allow hot or cold air flow. the motor turn a small plastic gear, the teeth on the plastic gear wear smooth and the frce of the blowing air pushes the flap to the warm position. its an awkward job to repair as the whole dash and heater box has to come out to do it
May 20, 2010 | Heating & Cooling
Nissan xterra..2000
your air con needs re gasing
Jul 07, 2009 | 2000 Nissan Xterra
Hot air blows unless the temp is turned down to 66 degress
well ? Does It get cold @ 66 Degrees? And If so.. Aint 66 degrees cold?
Mar 15, 2009 | 2004 Honda Odyssey
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
