Hi, My LG Home stereo posibly experienced a small power surge (all clocks in house were blinking) and now has defaulted to some odd functions and will not receive radio stations or transfer sound to the speakers.
    President:
  • 2,047 Answers
This definitely was as a result of a power surge but the type of power surge seems irregular you should report the surge to the authorities.
Then as regards the radio defaulting to odd functions most likely the function which your unit defaulted to are the functions with which the unit was shipped from the factory. Usually the settings just have to be made and your unit is back to normal function the advised settings can be found in your user manual.
If after setting the unit still does not receive radio then the surge must have damaged the FM receiver console inside the unit and this will have to be replaced by an expert.
Hope this solution has been helpful?
Posted on Jan 01, 2011
I have a Storm cat generator, and it made my stereo start smoking?
do you have a surge protector on stereo generators can send hi surges of electricity sometimes and or did you plug into correct power level
Jul 10, 2017 | Electrical Supplies
I recently replaced my Intermatic EJ500 with a new unit, I noticed it works perfectly fine for one day then the batteries that control the timer drain completely the following day, what could it be?
Line voltage usually controls the timer functions when properly wired until a power outage occurs; then battery power takes over until utility power is restored. Should utility power be off for an extended period of time, eventually the battery will drain completely
Double check to make sure you wired your wall switch timer properly.
Make sure there are no loose wiring connections.
Even though you purchased a new replacement timer wall switch, it could be a manufacturer's defect.
Has your home electrical system experienced any signal spikes? Electronic components are very sensitive to impulse spikes/surges and can be damaged very easily.
If you are experiencing surges or spikes, perhaps investing in a whole house surge protection system (Intermatic IG series) would be the way to go as well. It'll protect all your electronic devices and appliances through-out the house.
Feb 12, 2017 | Intermatic Hardware & Accessories
Hi my lg TV keeps blinking on the odd occasion , is there a setting to stop this
If you mean the brightness keeps altering check that it is not set to AUTO in the settings, this is the default setting to comply with the Energy standards. Switch it to OFF.
Nov 07, 2014 | LG 55 55LW5600 3D LCD TV
I try to set the clock on the oven but pressing the CLOCK touch pad or the TIME-TEMP pad has no affect. It is completely nonresponsive.
It sound like the board is faulty, its quite common after power surges can cause damage to small circuit boards like clocks, I would recommend changing it as the clock will also provide timing for switch on at a set time cook for time as well.
http://dacor.com/Search.aspx?query=ECS227 Epicure Electric
Hope this is helpful
Regards
John
Oct 31, 2014 | Dacor ECS227 Epicure Electric Double Oven
Panasonic Home Theater System ....No power
Likely a power surge hit your house while away. This happens when power turns back on or lightning hits close to your house. If insured, call insurance company about it. You may be covered for replacement or have deductible applied. Small appliances like this are most susceptible to power surge. There is not enough protection designed in.. The best protection is surge module on main breaker panel or buy a protected power strip to protect high value electronics.
Apr 16, 2014 | Panasonic Audio Players & Recorders
My lg tv won't turn on after a lightening storm
Your surge protector did not function properly, contact the manufacturer of the power strip.
Jul 05, 2012 | LG 55 55LW5600 3D LCD TV
I have an LG 42lg50 TV that was working fine earlier today, While I was out of the house an Thunderstorm came up and power failed at least twice. I come back home to find my TV not working properly. The...
An electrical pulse from the thunderstorm has affected your TV. (Was it on a surge protector?)
There is a small possibility that it will come back.
Unplug the television and let it sit for an hour or more and then re-plug it.
If you need to get a new TV, also get a good surge protector such as Panamax.
Jun 14, 2010 | LG 42LG50 42 in. LCD HDTV
We have a Hotpoint RB787 Electric Kitchen Range. We experienced electrical issues/ power surge and now the oven part of the stove does not work. top still works and only indicators for the top burners...
you will need to replace the control board that contains the clock readout,any power surges ruins these electronics instantly,this can be replaced by removing the rear cover on the back of the unit and remove screws securing the electronic module
Jan 08, 2010 | Hotpoint RB787 Electric Kitchen Range
The radio does not search on even numbers (89,8) only on odds numbers (89,9) is it posible to chance that?? My car is 2006 Tacoma
Why? North American radio stations are only broadcast on "odd" frequencies - x.1, x.3, etc.
Jul 12, 2009 | 2008 Toyota Tacoma
HOW DO YOU CHANGE THE TIME ON A DEH-P59001B PIONEER STEREO
Its not the select button, you must have the power off and hold the function button down for about 5 seconds, display will change and you will be able to navigate your way to the clock from there. Hope this helps.
May 02, 2009 | Pioneer DEH-P5900IB CD Player
52 people viewed this question
 Grubhead
Grubhead
